[postgis-tickets] [PostGIS] #4185: Can't upgrade postgis raster
PostGIS trac at osgeo.org
Fri Sep 21 21:42:14 PDT 2018
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Getting this error on debbie when she tries to upgrade from 2.5.0rc3dev.
 Seems it's only raster upgrade, postgis upgrade is fine
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis VERSION
 '2.5.0rc3dev'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis_raster VERSION
 '2.5.0rc3dev'
 Died at run_test.pl line 1329.
  failed (Error encountered creating EXTENSION POSTGIS_RASTER:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg9.6w64/regress_log)
 createlang: language "plpgsql" is already installed in database
 "postgis_reg"
 CREATE EXTENSION
 ERROR:  could not stat file
 "/var/lib/jenkins/workspace/pg/rel/pg9.6w64/share/postgresql/extension/postgis_raster
 --2.5.0rc3dev.sql": No such file or directory
 I assume the reason is raster is part of postgis in 2.5, so we'll
 definitely need to make accommodations for this in our test script.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4185>
