[postgis-tickets] r16830 - run_test.pl: --extension doesn't imply --raster anymore
Sandro Santilli strk at kbt.io
Sat Sep 22 03:39:09 PDT 2018
Author: strk
Date: 2018-09-22 03:39:09 -0700 (Sat, 22 Sep 2018)
New Revision: 16830
   trunk/regress/run_test.pl
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl	2018-09-22 10:37:45 UTC (rev 16829)
+++ trunk/regress/run_test.pl	2018-09-22 10:39:09 UTC (rev 16830)
@@ -106,11 +106,6 @@
   print "Upgrade path: ${OPT_UPGRADE_FROM} --> ${OPT_UPGRADE_TO}\n";
-if ( $OPT_EXTENSIONS )
-	$OPT_WITH_RASTER = 1; # implied (TODO: drop implication !)
 # Split-raster extension was introduced in PostGIS-3.0.0
 sub has_split_raster_ext
