[postgis-tickets] [PostGIS] #4097: binary upgrade fail going from 10 (2.4) to 11 (head) (2.5)
PostGIS trac at osgeo.org
Sun Sep 23 12:31:47 PDT 2018
  Reporter:  robe                   |      Owner:  robe
      Type:  task                   |     Status:  assigned
  Priority:  blocker                |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 Okay someone took out this function so upgrade (by flipping the lib
 binaary) fails
 pg_restore: [archiver (db)] Error from TOC entry 1175; 1255 17673 FUNCTION
 st_asbinary("public"."raster", boolean) postgres
 pg_restore: [archiver (db)] could not execute query: ERROR:  could not
 find function "RASTER_to_binary" in file
 "C:/ming64gcc81/projects/postgresql/rel/pg11w64gcc81/lib/rtpostgis-2.4.dll"
     Command was: CREATE FUNCTION "public"."st_asbinary"("public"."raster",
 "outasin" boolean DEFAULT false) RETURNS "bytea"
     LANGUAGE "c" IMMUTABLE STRICT PARALLEL SAFE
     AS '$libdir/rtpostgis-2.4', 'RASTER_to_binary';
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4097#comment:6>
