[postgis-tickets] r16841 - Fix indent
Sandro Santilli strk at kbt.io
Mon Sep 24 03:58:53 PDT 2018
Author: strk
Date: 2018-09-24 03:58:53 -0700 (Mon, 24 Sep 2018)
New Revision: 16841
   trunk/regress/run_test.pl
Fix indent
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl	2018-09-24 10:18:15 UTC (rev 16840)
+++ trunk/regress/run_test.pl	2018-09-24 10:58:53 UTC (rev 16841)
@@ -1509,13 +1509,13 @@
-		else
-			# Raster support was not requested, so drop it if
-			# left unpackaged
+    else
+      # Raster support was not requested, so drop it if
+      # left unpackaged
       if ( $OPT_UPGRADE_FROM
            && ! has_split_raster_ext($OPT_UPGRADE_FROM) )
         $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
         $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
@@ -1531,8 +1531,8 @@
           fail "Error encountered dropping EXTENSION POSTGIS_RASTER on upgrade", $REGRESS_LOG;
           die;
     if ( $OPT_WITH_TOPO )
