[postgis-tickets] r16851 - minor wording changes
Regina Obe lr at pcorp.us
Fri Sep 28 09:59:52 PDT 2018
Author: robe
Date: 2018-09-28 09:59:51 -0700 (Fri, 28 Sep 2018)
New Revision: 16851
   trunk/extensions/postgis/unpackage_raster_if_needed.sql
Modified: trunk/extensions/postgis/unpackage_raster_if_needed.sql
--- trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-09-28 15:36:11 UTC (rev 16850)
+++ trunk/extensions/postgis/unpackage_raster_if_needed.sql	2018-09-28 16:59:51 UTC (rev 16851)
@@ -15,8 +15,8 @@
 		$unpackage$;
 		RAISE WARNING 'PostGIS Raster functionality have been unpackaged'
-		USING HINT = 'type `SELECT postgis_extensions_upgrade(); to repackage.'
-								 ' If you want to drop raster after, run: DROP EXTENSION postgis_raster;';
+		USING HINT = 'type `SELECT postgis_extensions_upgrade(); to finish the upgrade.'
+						' After upgrading, if you want to drop raster, run: DROP EXTENSION postgis_raster;';
 	END IF;
 END
 $unpackage_if_needed$ LANGUAGE 'plpgsql';
