[postgis-tickets] r16853 - fix windows links should point at postgis.net and not postgis.org
Regina Obe lr at pcorp.us
Sun Sep 30 11:05:56 PDT 2018
Author: robe
Date: 2018-09-30 23:05:56 -0700 (Sun, 30 Sep 2018)
New Revision: 16853
   branches/2.5/doc/installation.xml
Modified: branches/2.5/doc/installation.xml
--- branches/2.5/doc/installation.xml	2018-10-01 05:47:06 UTC (rev 16852)
+++ branches/2.5/doc/installation.xml	2018-10-01 06:05:56 UTC (rev 16853)
@@ -314,8 +314,8 @@
 	  <para>This section includes general compilation instructions, if you are compiling for Windows etc
 		or another OS, you may find additional more detailed help at <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiInstall">PostGIS User contributed compile guides</ulink> and <ulink url="http://trac.osgeo.org/postgis/wiki/DevWikiMain">PostGIS Dev Wiki</ulink>.</para>
 	  <para>Pre-Built Packages for various OS are listed in <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiPackages">PostGIS Pre-built Packages</ulink></para>
-	  <para>If you are a windows user, you can get stable builds via Stackbuilder or <ulink url="http://www.postgis.org/download/windows/">PostGIS Windows download site</ulink>
-	  We also have <ulink url="http://www.postgis.org/download/windows/experimental.php">very bleeding-edge windows experimental builds</ulink> that are built usually once or twice a week or whenever anything exciting happens.  You can
+	  <para>If you are a windows user, you can get stable builds via Stackbuilder or <ulink url="https://postgis.net/windows_downloads">PostGIS Windows download site</ulink>
+	  We also have <ulink url="https://postgis.net/windows_downloads">very bleeding-edge windows experimental builds</ulink> that are built usually once or twice a week or whenever anything exciting happens.  You can
 	  use these to experiment with the in progress releases of PostGIS</para>
 	</note>
