[postgis-tickets] [PostGIS] #3807: Change PostGIS library name to drop the minor
PostGIS trac at osgeo.org
Sun Sep 30 23:46:34 PDT 2018
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 3.0.0
 Component:  postgis   |    Version:  2.3.x
Resolution:  fixed     |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16854" 16854]:
 #!CommitTicketReference repository="" revision="16854"
 Add new configure switch --with-library-minor-version, change default
 behavior to not include minor version in extension library files.
 Closes #3807
 Also fix link in docs that points to old postgis.org
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3807#comment:6>
