[postgis-tickets] [PostGIS] #4366: PostGIS 2.5 to 3.0 broken
PostGIS trac at osgeo.org
Sun Apr 7 09:11:32 PDT 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 I took debbie out of the dronie line, and reran the job thinking it was a
 false alarm, but I'm still seeing this when it is trying to upgrade from
 2.5-3.0.
 What gives? https://dronie.osgeo.org/postgis/postgis/201/2/2
 regress .. failed (diff expected obtained: /tmp/pgis_reg/test_64_diff)
 --- regress_expected 2019-04-07 15:23:21.077936846 +0000
 +++ /tmp/pgis_reg/test_64_out 2019-04-07 15:35:25.223427766 +0000
 @@ -194,3 +194,7 @@
 224|
 225|BOX(-6 1,3 8)
 226|t
 +unexpected probin|_st_asgeojson:$libdir/postgis-2.5
 +unexpected probin|_st_askml:$libdir/postgis-2.5
 +unexpected probin|_st_buffer:$libdir/postgis-2.5
 +unexpected probin|_st_distance:$libdir/postgis-2.5
 I haven't tried locally to upgrade to confirm it's an issue.
 But seems there is a drop missing somewhere so we have old signatures from
 postgis-2.5 showing up
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4366>
