[postgis-tickets] [PostGIS] #4367: Concave Hull Hard failing on debbie and winnie's 32bit
PostGIS trac at osgeo.org
Mon Apr 8 07:45:54 PDT 2019
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.5.3
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 This might be working fine on trunk because we took out the
 concave_hull_hard tests.
 But both debbie and winnie seem to be failing.
 I wouldn't be so alarmed if it was just debbie, as she's still suffering
 from memory issues I'm trying to troubleshoot.
 What concerns me is it's winnie's 32-bit tests failing and I think she's
 the only one that tests 32-bit
 On winnie getting:
  concave_hull_hard .. failed (diff expected obtained:
 /projects/postgis/tmp/2.5.3dev_pg10_geos3.7.1_gdal2.2.4w32/test_35_diff)
 --- concave_hull_hard_expected  2018-10-02 01:02:30.672320700 -0400
 +++ /projects/postgis/tmp/2.5.3dev_pg10_geos3.7.1_gdal2.2.4w32/test_35_out
 2019-03-29 14:41:32.506425100 -0400
 @@ -2,4 +2,3 @@
  ST_ConcaveHull Lines 0.80|t|t
  ST_ConcaveHull Lines 0.80 holes|t|t
  #3638|t|t
 -#3697|t|t
 debbie just hits the roof on the concavehull_hard
 /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_35_diff)
 --- concave_hull_hard_expected  2019-04-08 06:26:53.706696460 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_35_out
 2019-04-08 14:35:01.904674217 +0000
 @@ -2,4 +2,8 @@
  #3638|t|t
 -#3697|t|t
 +server closed the connection unexpectedly
 +       This probably means the server terminated abnormally
 +       before or while processing the request.
 +no connection to the server
 +connection to server was lost
  ctors .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_36_diff)
 --- ctors_expected      2019-04-08 06:26:53.706696460 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_36_out
 2019-04-08 14:35:01.964674245 +0000
 @@ -1,11 +1 @@
 -32749
 -ERROR:  Operation on mixed SRID geometries
 -SRID=3;LINESTRING(0 0,1 1)
 -ST_MakeLine1|LINESTRING(0 0,1 1,10 0)
 -ST_MakeLine_agg1|LINESTRING(0 0,1 1,10 0,20 20,40 4,40 4,40 5,40 5,40
 6,40 6,40 7,40 8)
 -ST_MakeLine_agg2|LINESTRING(0 0,1 0,1 0)
 -BOX(0 0,1 1)
 -BOX3D(0 0 0,1 1 0)
 +psql: FATAL:  the database system is in recovery mode
 and has trouble recovering.  I had to revert debbie back to a 3/11 backup
 to try to debug her memory issues, so don't know when that started with
 her (sometime after 3/11).
 On winnie, issue seems to have started after r17367
 Commit 5de526daad5fa0a9c8c86814f5303f8a45de6d55 by rmrodriguez
 Fix postgis_type_name with (GEOMETRYM,3)
 Patch by Matt Bretl
 References #4361
  git-svn-id: http://svn.osgeo.org/postgis/branches/2.5@17367
 b70326c6-7e19-0410-871a-916f4a2858ee
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4367>
