[postgis-tickets] [PostGIS] #4368: Reorder struct layouts to minimize padding
PostGIS trac at osgeo.org
Mon Apr 8 09:39:10 PDT 2019
 Reporter:  Algunenano   |      Owner:  Algunenano
     Type:  enhancement  |     Status:  assigned
 Priority:  medium       |  Milestone:  PostGIS 3.0.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 The current LWGEOM structs have too much padding which makes them bigger
 than what they could be.
 For example, currently they look like this:
 typedef struct
     uint8_t type;
     uint8_t flags;
     GBOX *bbox;
     int32_t srid;
     void *data;
 LWGEOM;
 When you build them in a 64 bit machine which I'm considering the default,
 the struct looks like this:
     uint8_t type;     /* 1 byte */
     uint8_t flags;    /* 1 byte */
                       /* 6 bytes padding */
     GBOX *bbox;       /* 8 bytes */
     int32_t srid;     /* 4 bytes */
                       /* 4 bytes padding */
     void *data;       /* 8 bytes */
 For a total of 32 bytes.
 I'm proposing to use this instead:
         char pad[2];   /* 2 bytes of padding */
 So the new way uses 24 bytes instead (25% less). I expect this to have a
 impact in big multigeometries as it reduces their memory footprint which
 should improve performance. OTOH, I want to test it first as changing the
 position of certain elements might be harmful in certain scenarios.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4368>
