[postgis-tickets] [PostGIS] #4365: Debbie is very sick
PostGIS trac at osgeo.org
Mon Apr 8 09:52:16 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 whoops that didn't work.
 the fallocate kept on creating an 8GB swap file. so switched to something
 I found listed which seems to make the doc build move
 swapoff -a
 dd if=/dev/zero of=/swap bs=1024 count=1048576
 chmod 0600 /swap
 mkswap /swap
 swapon /swap
 I'm not sure if debbie ever had a swap space, I talked to atlantic about
 this and their comment:
 By default out Cloud Servers normally do not have a swap or swapfile
 added. I believe on some of the newer Debian/Ubuntu servers, we did for a
 short time have a swapfile added, but this was removed so everything is
 kept the same (ie: no swap). You are more than welcome to add a swap file
 if that helps performance, but there are some applications that do not do
 well with swap, like some Java apps, which is why it is off by default. I
 hope this helps explain what you were seeing. Let us know if we can be of
 any further assistance.
 So it could be she had one before and things went south when it was taken
 out or she's never had one and something is amiss.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4365#comment:2>
