[postgis-tickets] [PostGIS] #4370: Remove ST_ForceRHR
PostGIS trac at osgeo.org
Wed Apr 10 08:31:14 PDT 2019
  Reporter:  dbaston      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.0.0
 Component:  postgis      |    Version:  trunk
Resolution:               |   Keywords:
Comment (by dbaston):
 The term "right-hand rule" is commonly understood to mean the opposite; if
 you hold your right hand with your thumb facing your face, your fingers
 curl in a counter-clockwise direction. See for example the GeoJSON spec:
 https://tools.ietf.org/html/rfc7946#section-3.1.6
 Or the GDAL documentation:
 https://www.gdal.org/drv_geojson.html
 See also #3689
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4370#comment:3>
