[postgis-tickets] [PostGIS] #4372: PROJ 6: 4x slowdown on indexes over ST_Transform
PostGIS trac at osgeo.org
Wed Apr 10 08:32:47 PDT 2019
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  high        |  Milestone:  PostGIS 3.0.0
Component:  postgis     |    Version:  trunk
 Keywords:              |
 # Setup
 # Select version();
                                                  version
  PostgreSQL 11.2 on x86_64-pc-linux-gnu, compiled by clang version 8.0.0
 (tags/RELEASE_800/final), 64-bit
 A table with an index over st_transform.
 The table was created as:
 CREATE TABLE analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4
 AS
  SELECT * FROM (SELECT
  ST_Buffer(the_geom::geography, 50000)::geometry
 the_geom,scalerank,natscale,labelrank,featurecla,name,namepar,namealt,diffascii,nameascii,adm0cap,capalt,capin,worldcity,megacity,sov0name,sov_a3,adm0name,adm0_a3,adm1name,iso_a2,note,latitude,longitude,changed,namediff,diffnote,pop_max,pop_min,pop_other,geonameid,meganame,ls_name,ls_match,checkme,cartodb_id,created_at,updated_at
  FROM (select * from populated_places_simple_reduced) _camshaft_buffer)
 _analysis_create_table_query
  LIMIT 0
 And the index as:
 CREATE INDEX ON
 analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4 USING GIST
 (ST_Transform(the_geom, 3857))
 The table looks like this:
 # \d+ analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4
                   Table
 "public.analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4"
    Column   |           Type           | Collation | Nullable | Default |
 Storage  | Stats target | Description
  the_geom   | geometry                 |           |          |         |
 main     |              |
  scalerank  | integer                  |           |          |         |
 plain    |              |
  natscale   | integer                  |           |          |         |
 plain    |              |
  labelrank  | integer                  |           |          |         |
 plain    |              |
  featurecla | text                     |           |          |         |
 extended |              |
  name       | text                     |           |          |         |
 extended |              |
  namepar    | text                     |           |          |         |
 extended |              |
  namealt    | text                     |           |          |         |
 extended |              |
  diffascii  | integer                  |           |          |         |
 plain    |              |
  nameascii  | text                     |           |          |         |
 extended |              |
  adm0cap    | double precision         |           |          |         |
 plain    |              |
  capalt     | double precision         |           |          |         |
 plain    |              |
  capin      | text                     |           |          |         |
 extended |              |
  worldcity  | double precision         |           |          |         |
 plain    |              |
  megacity   | integer                  |           |          |         |
 plain    |              |
  sov0name   | text                     |           |          |         |
 extended |              |
  sov_a3     | text                     |           |          |         |
 extended |              |
  adm0name   | text                     |           |          |         |
 extended |              |
  adm0_a3    | text                     |           |          |         |
 extended |              |
  adm1name   | text                     |           |          |         |
 extended |              |
  iso_a2     | text                     |           |          |         |
 extended |              |
  note       | text                     |           |          |         |
 extended |              |
  latitude   | double precision         |           |          |         |
 plain    |              |
  longitude  | double precision         |           |          |         |
 plain    |              |
  changed    | double precision         |           |          |         |
 plain    |              |
  namediff   | integer                  |           |          |         |
 plain    |              |
  diffnote   | text                     |           |          |         |
 extended |              |
  pop_max    | integer                  |           |          |         |
 plain    |              |
  pop_min    | integer                  |           |          |         |
 plain    |              |
  pop_other  | integer                  |           |          |         |
 plain    |              |
  geonameid  | double precision         |           |          |         |
 plain    |              |
  meganame   | text                     |           |          |         |
 extended |              |
  ls_name    | text                     |           |          |         |
 extended |              |
  ls_match   | integer                  |           |          |         |
 plain    |              |
  checkme    | integer                  |           |          |         |
 plain    |              |
  cartodb_id | integer                  |           |          |         |
 plain    |              |
  created_at | timestamp with time zone |           |          |         |
 plain    |              |
  updated_at | timestamp with time zone |           |          |         |
 plain    |              |
 Indexes:
     "analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9_st_transform_idx" gist
 (st_transform(the_geom, 3857))
 # Testing with PROJ 5.2 and postgis trunk:
 # INSERT INTO analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4
 SELECT
  FROM (select * from populated_places_simple_reduced) _camshaft_buffer;
 INSERT 0 7313
 Time: 1860.093 ms (00:01.860)
 I've run the same test several times and it always takes ~1.8s.
 perf divided by .so:
 Perf by .so:
 +   82.25%     0.00%  [unknown]
 +   81.89%    18.38%  libc-2.28.so
 +   67.54%    41.42%  postgres
 +   58.06%     6.69%  postgis-3.so
 +   15.06%    13.08%  libproj.so.13.1.1
 +   11.65%     0.56%  libgeos_c.so.1.11.0
 +   11.38%     8.73%  libgeos-3.8.0.so
 +    6.17%     6.06%  libm-2.28.so
 +    3.25%     2.99%  [kernel.kallsyms]
 +    1.90%     0.05%  libpthread-2.28.so
 +    1.84%     1.71%  libstdc++.so.6.0.25
      0.34%     0.34%  ld-2.28.so
      0.00%     0.00%  [vdso]
 # Same with PROJ 6 (just built from master, latest ref is
 fb125618fd18f112ed6f37662b021d07a602ff90), and also postgis trunk (rebuilt
 with the dependency):
 test_windshaft_cartodb_user_1_db=# INSERT INTO
 analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4 SELECT
 INSERT 0 7313
 Time: 7184.529 ms (00:07.185)
 Running it several times shows it always takes ~7.2 secs, that's as slow
 as the build using PROJ 5.2.
 Perf by .so:
 Perf by .so:
 +   87.70%    33.62%  libc-2.28.so
 +   79.96%     0.00%  [unknown]
 +   61.70%    14.32%  postgres
 +   59.86%     1.77%  postgis-3.so
 +   45.09%    25.42%  libproj.so.15.0.0
 +   10.26%     8.80%  libstdc++.so.6.0.25
 +    7.02%     6.98%  [kernel.kallsyms]
 +    3.72%     0.48%  libicuuc.so.64.1
 +    3.48%     3.42%  libgcc_s.so.1
 +    2.94%     0.19%  libgeos_c.so.1.11.0
 +    2.83%     2.29%  libgeos-3.8.0.so
 +    1.95%     1.90%  libm-2.28.so
      1.02%     0.38%  libpthread-2.28.so
      0.37%     0.37%  libsqlite3.so.0.8.6
      0.06%     0.05%  ld-2.28.so
      0.00%     0.00%  libk5crypto.so.3.1
      0.00%     0.00%  libxml2.so.2.9.9
      0.00%     0.00%  [vdso]
 If I run only ST_Transform over the table, the times are more similar;
 proj6 is still slower but not 4x slower:
 Running only ST_Transform (`Select ST_Transform(the_geom, 3857) from
 analysis_2f13a3dbd7_9de00c87a82f0929cfc345d2d9f1d01e05811bc4;`)
 PROJ 5 build:
 Time: 1558.226 ms (00:01.558)
 Time: 1570.106 ms (00:01.570)
 Time: 1565.649 ms (00:01.566)
 PROJ 6 build:
 Time: 1764.034 ms (00:01.764)
 Time: 1710.738 ms (00:01.711)
 Time: 1732.082 ms (00:01.732)
 Have we lost some caching in the proj6 update?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4372>
