[postgis-tickets] r17381 - TRUNCATE spatial_ref_sys upfront when running out_geography test
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri Apr 12 23:28:44 PDT 2019
This is very very bad. I had my dev thing down when tried to debug
tickets.sql by playing it against different installs - when I'm superuser I
succeed in removing spatial_ref_sys.
Can we instead check that we don't ever try to insert overlapping srids
there?
On Wed, Apr 10, 2019 at 7:15 PM Sandro Santilli <strk at kbt.io> wrote:
> Author: strk
> Date: 2019-04-10 09:15:55 -0700 (Wed, 10 Apr 2019)
> New Revision: 17381
> Modified:
>    trunk/regress/core/out_geography.sql
> Log:
> .. this should probably be done upfront for all tests...
> Modified: trunk/regress/core/out_geography.sql
> --- trunk/regress/core/out_geography.sql        2019-04-10 16:15:46 UTC
> (rev 17380)
> +++ trunk/regress/core/out_geography.sql        2019-04-10 16:15:55 UTC
> (rev 17381)
> @@ -2,6 +2,9 @@
>  -- spatial_ref_sys data
> +TRUNCATE spatial_ref_sys;
>  INSERT INTO "spatial_ref_sys"
> ("srid","auth_name","auth_srid","proj4text") VALUES
> (4326,'EPSG',4326,'+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
>  INSERT INTO "spatial_ref_sys" ("srid", "proj4text") VALUES (102189,
> '+proj=tmerc +lat_0=4.599047222222222 +lon_0=-74.08091666666667 +k=1.000000
> +x_0=1000000 +y_0=1000000 +ellps=intl +towgs84=307,304,-318,0,0,0,0
> +units=m +no_defs ');
> postgis-tickets mailing list
> postgis-tickets at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-tickets/attachments/20190413/95f1374a/attachment.html>
