[postgis-tickets] [PostGIS] #4374: undefined reference to `geod_init'
PostGIS trac at osgeo.org
Sat Apr 13 09:49:45 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Changes (by robe):
 * owner:  pramsey => strk
 * component:  postgis => build/upgrade/install
Comment:
 I think the problem may be I installed the 5.2 binaries but an older
 development lib and since 3.0 takes advantage of > 5. enhancements, 2.5
 problem doesn't care about these new function.
 Going to try to remove and reinstall proj
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4374#comment:1>
