[postgis-tickets] r17390 - Fix typo in config
Regina Obe lr at pcorp.us
Sat Apr 13 06:59:33 PDT 2019
Author: robe
Date: 2019-04-13 18:59:33 -0700 (Sat, 13 Apr 2019)
New Revision: 17390
   trunk/ci/debbie/postgis_regress.sh
Fix typo in config
Modified: trunk/ci/debbie/postgis_regress.sh
--- trunk/ci/debbie/postgis_regress.sh	2019-04-14 01:42:07 UTC (rev 17389)
+++ trunk/ci/debbie/postgis_regress.sh	2019-04-14 01:59:33 UTC (rev 17390)
@@ -24,7 +24,7 @@
 export PGUSER=postgres
 export PATH="${PGPATH}/bin:$PATH"
-export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
+export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PROJECTS}/sfcgal/rel-${SFCGAL_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
 rm -rf ${WORKSPACE}/tmp/${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 rm -rf ${WORKSPACE}/tmp/${POSTGIS_MAJOR_VERSION}_${POSTGIS_MINOR_VERSION}_pg${PG_VER}w${OS_BUILD}
@@ -64,7 +64,7 @@
     --with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
     --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
     --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config \
-    --with-sfcgal=/var/lib/jenkins/workspace/sfcgal/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD} --without-interrupt-tests \
+    --with-sfcgal=/var/lib/jenkins/workspace/sfcgal/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}/bin/sfcgal-config --without-interrupt-tests \
     --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
 make clean
 make
