[postgis-tickets] [PostGIS] #4375: Need to resetup postgis-sync
PostGIS trac at osgeo.org
Sat Apr 13 21:51:10 PDT 2019
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  new
  Priority:  blocker     |  Milestone:  Management 2.0
 Component:  management  |    Version:  trunk
Resolution:              |   Keywords:
Comment (by robe):
 okay now I remember you said you were running this on an osgeo server
 osgeo6?  So probably wasn't running on debbie and I was just seeing an
 attempt.
 But I did try to start doing it on new debbie, and when it was running the
 make init
 It errored out with:
 Author: komzpa not defined in /home/postgis-git-synch/repository-sync-
 scripts/authors.git file
 Which is really odd as I was expecting martin's name to come up
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4375#comment:2>
