[postgis-tickets] [PostGIS] #4375: Need to resetup postgis-sync
PostGIS trac at osgeo.org
Sun Apr 14 22:12:33 PDT 2019
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  blocker     |  Milestone:  Management 2.0
 Component:  management  |    Version:  trunk
Resolution:  fixed       |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 The script is now fixed. Somewhere on the procedure to accept a new
 committer we should write that a commit adding his name in authors.svn and
 authors.git must be performed by an existing committer before anything is
 committed by the new contributor.
 As per the repository-sync-scripts you may want to file a ticket in its
 own repository, but the initial setup is pretty complex as it implies
 fetching data in steps so that every step has new authors (I don't
 remember the details but I'm pretty sure it needs update every time a new
 contributor is granted commit access)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4375#comment:4>
