[postgis-tickets] [PostGIS] #4379: Raster unit tests failing with GDAL master
PostGIS trac at osgeo.org
Wed Apr 17 04:58:54 PDT 2019
 Reporter:  Algunenano  |      Owner:  Bborie Park
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:  PostGIS 3.0.0
Component:  raster      |    Version:  trunk
 Keywords:              |
 I'm using both GDAL and PROJ master.
 Run Summary:    Type  Total    Ran Passed Failed Inactive
               suites     12     12    n/a      0        0
                tests     65     65     64      1        0
              asserts  45905  45905  45904      1      n/a
 ./test/cunit/cu_tester test_raster_compute_skewed_raster
 Running test 'test_raster_compute_skewed_raster' in suite 'raster_misc'.
     FAILED - asserts -   4 passed,   1 failed,   5 total.
   1. cu_raster_misc.c:199  - CU_ASSERT_EQUAL(rt_raster_get_width(rast),2)
 199             CU_ASSERT_EQUAL(rt_raster_get_width(rast), 2);
 (gdb) p rast
 $1 = (rt_raster) 0x555555799b70
 (gdb) p *rast
 $2 = {size = 0, version = 0, numBands = 0, scaleX = 1, scaleY = -1, ipX =
 -0.5, ipY = 0, skewX = 0.25, skewY = 0.25, srid = 0, width = 3,
   height = 3, bands = 0x0}
 (gdb) quit
 This works fine with PROJ 5.2 and GDAL 2.3.2 in the same environment.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4379>
