[postgis-tickets] [PostGIS] #4356: Remove ST_Accum
PostGIS trac at osgeo.org
Wed Apr 17 22:35:08 PDT 2019
  Reporter:  komzpa   |      Owner:  komzpa
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by komzpa):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17397" 17397]:
 #!CommitTicketReference repository="" revision="17397"
 Remove ST_Accum. Please use array_agg instead.
 Closes #4356
 Closes https://github.com/postgis/postgis/pull/393
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4356#comment:1>
