[postgis-tickets] r17398 - ST_Union: allow to input more than 1GB of geometries.
Darafei komzpa at gmail.com
Thu Apr 18 12:56:30 PDT 2019
Author: komzpa
Date: 2019-04-18 12:56:30 -0700 (Thu, 18 Apr 2019)
New Revision: 17398
   trunk/NEWS
   trunk/postgis/lwgeom_accum.c
   trunk/postgis/lwgeom_geos.c
   trunk/postgis/postgis.sql.in
Output still has to be below 1GB due to postgres tuple length limit.
Closes #4340
Closes https://github.com/postgis/postgis/pull/394
Modified: trunk/NEWS
--- trunk/NEWS	2019-04-18 05:35:07 UTC (rev 17397)
+++ trunk/NEWS	2019-04-18 19:56:30 UTC (rev 17398)
@@ -89,6 +89,8 @@
   - #4295, Allow GEOMETRYCOLLECTION in ST_Overlaps, ST_Contains, ST_ContainsProperly,
            ST_Covers, ST_CoveredBy, ST_Crosses, ST_Touches, ST_Disjoint, ST_Relate,
            ST_Equals (Esteban Zimányi)
+  - #4340, ST_Union aggregate now can handle more than 1 GB of geometries
+           (Darafei Praliaskouski)
   - #4378, Allow passing TINs as input to GEOS-backed functions (Darafei
            Praliaskouski)
Modified: trunk/postgis/lwgeom_accum.c
--- trunk/postgis/lwgeom_accum.c	2019-04-18 05:35:07 UTC (rev 17397)
+++ trunk/postgis/lwgeom_accum.c	2019-04-18 19:56:30 UTC (rev 17398)
@@ -175,31 +175,6 @@
-* The "union" final function passes the geometry[] to a union
-* conversion before returning the result.
-PG_FUNCTION_INFO_V1(pgis_geometry_union_finalfn);
-Datum
-pgis_geometry_union_finalfn(PG_FUNCTION_ARGS)
-	pgis_abs *p;
-	Datum result = 0;
-	Datum geometry_array = 0;
-	if (PG_ARGISNULL(0))
-		PG_RETURN_NULL();   /* returns null iff no input values */
-	p = (pgis_abs*) PG_GETARG_POINTER(0);
-	geometry_array = pgis_accum_finalfn(p, CurrentMemoryContext, fcinfo);
-	result = PGISDirectFunctionCall1( pgis_union_geometry_array, geometry_array );
-	if (!result)
-		PG_RETURN_NULL();
-	PG_RETURN_DATUM(result);
 * The "collect" final function passes the geometry[] to a geometrycollection
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2019-04-18 05:35:07 UTC (rev 17397)
+++ trunk/postgis/lwgeom_geos.c	2019-04-18 19:56:30 UTC (rev 17398)
@@ -508,6 +508,161 @@
 	PG_RETURN_POINTER(gser_out);
+typedef struct UnionBuildState
+	MemoryContext mcontext; /* where all the temp stuff is kept */
+	GEOSGeometry **geoms;   /* collected GEOS geometries*/
+	int empty_type;
+	uint32_t alen;   /* allocated length of above arrays */
+	uint32_t ngeoms; /* number of valid entries in above arrays */
+	int32_t srid;
+	bool is3d;
+} UnionBuildState;
+PG_FUNCTION_INFO_V1(pgis_geometry_union_transfn);
+Datum pgis_geometry_union_transfn(PG_FUNCTION_ARGS)
+	MemoryContext aggcontext;
+	UnionBuildState *state;
+	GSERIALIZED *gser_in;
+	uint32_t curgeom;
+	GEOSGeometry *g;
+	if (!AggCheckCallContext(fcinfo, &aggcontext))
+		/* cannot be called directly because of dummy-type argument */
+		elog(ERROR, "%s called in non-aggregate context", __func__);
+		aggcontext = NULL; /* keep compiler quiet */
+	if (!PG_ARGISNULL(0))
+		state = (UnionBuildState *)PG_GETARG_POINTER(0);
+	else
+		MemoryContext old = MemoryContextSwitchTo(aggcontext);
+		state = (UnionBuildState *)palloc(sizeof(UnionBuildState));
+		state->mcontext = aggcontext;
+		state->alen = 10;
+		state->ngeoms = 0;
+		state->geoms = palloc(sizeof(GEOSGeometry *) * state->alen);
+		state->is3d = false;
+		state->srid = 0;
+		state->empty_type = 0;
+		initGEOS(lwpgnotice, lwgeom_geos_error);
+		MemoryContextSwitchTo(old);
+	/* do we have geometry to push? */
+	if (!PG_ARGISNULL(1))
+		gser_in = PG_GETARG_GSERIALIZED_P(1);
+		if (state->ngeoms > 0)
+			if (state->srid != gserialized_get_srid(gser_in))
+				for (curgeom = 0; curgeom < state->ngeoms; curgeom++)
+					GEOSGeom_destroy(state->geoms[curgeom]);
+			error_if_srid_mismatch(state->srid, gserialized_get_srid(gser_in));
+		if (!gserialized_is_empty(gser_in))
+			if (state->ngeoms == 0)
+				state->srid = gserialized_get_srid(gser_in);
+				state->is3d = gserialized_has_z(gser_in);
+			g = POSTGIS2GEOS(gser_in);
+			if (!g)
+				HANDLE_GEOS_ERROR("One of the geometries in the set could not be converted to GEOS");
+			curgeom = state->ngeoms;
+			state->ngeoms++;
+			if (state->ngeoms > state->alen)
+				state->alen *= 2;
+				state->geoms = repalloc(state->geoms, state->alen);
+			state->geoms[curgeom] = g;
+		else
+			int gser_type = gserialized_get_type(gser_in);
+			if (gser_type > state->empty_type)
+				state->empty_type = gser_type;
+	PG_RETURN_POINTER(state);
+PG_FUNCTION_INFO_V1(pgis_geometry_union_finalfn);
+Datum pgis_geometry_union_finalfn(PG_FUNCTION_ARGS)
+	GSERIALIZED *gser_out = NULL;
+	GEOSGeometry *g = NULL;
+	GEOSGeometry *g_union = NULL;
+	if (PG_ARGISNULL(0))
+		PG_RETURN_NULL(); /* returns null iff no input values */
+	** Take our GEOS geometries and turn them into a GEOS collection,
+	** then pass that into cascaded union.
+		g = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, state->geoms, state->ngeoms);
+		if (!g)
+			HANDLE_GEOS_ERROR("Could not create GEOS COLLECTION from geometry array");
+		g_union = GEOSUnaryUnion(g);
+		GEOSGeom_destroy(g);
+		if (!g_union)
+			HANDLE_GEOS_ERROR("GEOSUnaryUnion");
+		GEOSSetSRID(g_union, state->srid);
+		gser_out = GEOS2POSTGIS(g_union, state->is3d);
+		GEOSGeom_destroy(g_union);
+	/* No real geometries in our array, any empties? */
+	else
+		/* If it was only empties, we'll return the largest type number */
+		if (state->empty_type > 0)
+			    geometry_serialize(lwgeom_construct_empty(state->empty_type, state->srid, state->is3d, 0)));
+		/* Nothing but NULL, returns NULL */
+		else
+			PG_RETURN_NULL();
+	if (!gser_out)
+		/* Union returned a NULL geometry */
+		PG_RETURN_NULL();
+	PG_RETURN_POINTER(gser_out);
  * @example ST_UnaryUnion {@link #geomunion} SELECT ST_UnaryUnion(
  *      'POLYGON((0 0, 10 0, 0 10, 10 10, 0 0))'
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2019-04-18 05:35:07 UTC (rev 17397)
+++ trunk/postgis/postgis.sql.in	2019-04-18 19:56:30 UTC (rev 17398)
@@ -3820,6 +3820,12 @@
 	AS 'MODULE_PATHNAME'
 	LANGUAGE 'c' _PARALLEL;
+-- Availability: 3.0.0
+CREATE OR REPLACE FUNCTION pgis_geometry_union_transfn(internal, geometry)
+	RETURNS internal
+	AS 'MODULE_PATHNAME'
+	LANGUAGE 'c' _PARALLEL;
 -- Availability: 1.4.0
 -- Changed: 2.5.0 use 'internal' transfer type
 CREATE OR REPLACE FUNCTION pgis_geometry_union_finalfn(internal)
@@ -3873,8 +3879,9 @@
 -- we don't want to force drop of this agg since its often used in views
 -- parallel handling dealt with in postgis_drop_after.sql
 -- Changed: 2.5.0 use 'internal' stype
+-- Changed: 3.0.0 transfn now converts to GEOS
 CREATE AGGREGATE ST_Union (geometry) (
-	sfunc = pgis_geometry_accum_transfn,
+	sfunc = pgis_geometry_union_transfn,
 	stype = internal,
 #if POSTGIS_PGSQL_VERSION >= 96
 	parallel = safe,
