[postgis-tickets] [PostGIS] #4384: Change srid uses to int32_t
PostGIS trac at osgeo.org
Wed Apr 24 03:44:28 PDT 2019
  Reporter:  Algunenano   |      Owner:  Algunenano
      Type:  enhancement  |     Status:  closed
  Priority:  low          |  Milestone:  PostGIS 3.0.0
 Component:  liblwgeom    |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17410" 17410]:
 #!CommitTicketReference repository="" revision="17410"
 Always use int32_t for srid
 The main declaration was already using it, but some
 places still had int or mistakenly used uint32_t
 Closes #4384
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4384#comment:1>
