[postgis-tickets] [PostGIS] #4383: Sanitizer warnings
PostGIS trac at osgeo.org
Wed Apr 24 04:02:22 PDT 2019
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.0.0
 Component:  postgis     |    Version:  trunk
Resolution:              |   Keywords:
Comment (by Raul Marin):
 In [changeset:"17412" 17412]:
 #!CommitTicketReference repository="" revision="17412"
 lwout_wkb.c: Address implicit type conversion with value change
 lwout_wkb.c:288:16: runtime error: implicit conversion from type 'char' of
 value -16 (8-bit, signed) to type 'uint8_t' (aka 'unsigned char') changed
 the value to 240 (8-bit, unsigned)
 lwout_wkb.c:654:27: runtime error: implicit conversion from type
 'uint32_t' (aka 'unsigned int') of value 2147483663 (32-bit, unsigned) to
 type 'int' changed the value to -2147483633 (32-bit, signed)
 lwout_wkb.c:213:16: runtime error: implicit conversion from type 'char' of
 value -128 (8-bit, signed) to type 'uint8_t' (aka 'unsigned char') changed
 the value to 128 (8-bit, unsigned)
 lwout_wkb.c:607:27: runtime error: implicit conversion from type
 'uint32_t' (aka 'unsigned int') of value 2147483651 (32-bit, unsigned) to
 type 'int' changed the value to -2147483645 (32-bit, signed)
 References #4383
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4383#comment:3>
