[postgis-tickets] [PostGIS] #4386: [upgrade] ERROR: cannot drop function st_union(geometry) because other objects depend on it
PostGIS trac at osgeo.org
Mon Apr 29 01:51:41 PDT 2019
  Reporter:  strk                   |      Owner:  komzpa
      Type:  defect                 |     Status:  assigned
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 NOTE: #4352 would fix this case when running against PostgreSQL 12 or
 higher (just for the record, we still want to support older versions)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4386#comment:2>
