[postgis-tickets] r17415 - ST_AsGeoJSON(record) implementation from Joe Conway
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 29 09:04:11 PDT 2019
Author: pramsey
Date: 2019-04-29 09:04:10 -0700 (Mon, 29 Apr 2019)
New Revision: 17415
   trunk/.gitignore
   trunk/NEWS
   trunk/doc/reference_output.xml
   trunk/libpgcommon/lwgeom_pg.c
   trunk/libpgcommon/lwgeom_pg.h
   trunk/postgis/Makefile.in
   trunk/postgis/postgis.sql.in
Closes #1833
Modified: trunk/.gitignore
--- trunk/.gitignore	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/.gitignore	2019-04-29 16:04:10 UTC (rev 17415)
@@ -109,7 +109,10 @@
 postgis/legacy.sql
 postgis/postgis.sql
 postgis/postgis_proc_set_search_path.sql
+postgis/postgis_for_extension.sql
 postgis/postgis_upgrade.sql*
+postgis/postgis_upgrade_for_extension.sql
+postgis/postgis_upgrade_for_extension.sql.in
 postgis/sfcgal_upgrade.sql*
 postgis/sqldefines.h
 postgis/uninstall_legacy.sql
@@ -126,8 +129,10 @@
 raster/rt_pg/rtpostgis_drop.sql
 raster/rt_pg/rtpostgis_legacy.sql
 raster/rt_pg/rtpostgis_proc_set_search_path.sql
+raster/rt_pg/rtpostgis_for_extension.sql
 raster/rt_pg/rtpostgis_upgrade.sql.in
 raster/rt_pg/rtpostgis_upgrade*.sql
+raster/rt_pg/rtpostgis_upgrade_for_extension.sql.in
 raster/rt_pg/uninstall_rtpostgis.sql
 raster/scripts/Makefile
 raster/scripts/python/Makefile
Modified: trunk/NEWS
--- trunk/NEWS	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/NEWS	2019-04-29 16:04:10 UTC (rev 17415)
@@ -31,6 +31,7 @@
            Libre de Bruxelles (ULB), Darafei Praliaskouski)
   - #4171, ST_3DLineInterpolatePoint (Julien Cabieces, Vincent Mora)
   - #4311, Introduce `--with-wagyu` as an option for MVT polygons (Raúl Marín)
+  - #1833, ST_AsGeoJSON(row) generates full GeoJSON Features (Joe Conway)
 * Enhancements and fixes *
   - #4342, Move deprecated functions into legacy.sql file
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/doc/reference_output.xml	2019-04-29 16:04:10 UTC (rev 17415)
@@ -329,6 +329,13 @@
 		<funcsynopsis>
 			<funcprototype>
 				<funcdef>text <function>ST_AsGeoJSON</function></funcdef>
+				<paramdef><type>record </type> <parameter>feature</parameter></paramdef>
+				<paramdef choice="opt"><type>text </type> <parameter>geomcolumnname</parameter></paramdef>
+				<paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
+				<paramdef choice="opt"><type>boolean </type> <parameter>prettyprint=false</parameter></paramdef>
+			</funcprototype>
+			<funcprototype>
+				<funcdef>text <function>ST_AsGeoJSON</function></funcdef>
 				<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
 				<paramdef choice="opt"><type>integer </type> <parameter>options=0</parameter></paramdef>
@@ -345,15 +352,13 @@
 	  <refsection>
 		<title>Description</title>
-		  <para>Return the geometry as a GeoJSON element. (Cf <ulink
-			url="http://geojson.org/geojson-spec.html">GeoJSON specifications 1.0</ulink>). 2D and 3D Geometries are both supported. GeoJSON only support SFS 1.1 geometry type (no curve
+		  <para>Return the geometry as a GeoJSON "geometry" object, or the row as a GeoJSON "feature" object. (Cf <ulink
+			url="https://tools.ietf.org/html/rfc7946">GeoJSON specifications RFC 7946</ulink>). 2D and 3D Geometries are both supported. GeoJSON only support SFS 1.1 geometry types (no curve
 			support for example).</para>
-			<para>The <varname>gj_version</varname> parameter is the major version of the GeoJSON spec. If specified, must be 1.  This represents the spec version of GeoJSON.</para>
+			<para>The maxdecimaldigits argument may be used to reduce the maximum number of decimal places used in output (defaults to 15). If you are using EPSG:4326 and are outputting the geometry only for display, <varname>maxdecimaldigits</varname>=6 can be a good choice for many maps.</para>
-			<para>The third argument may be used to reduce the maximum number	of decimal places used in output (defaults to 15). If you are using EPSG:4326 and are outputting the geometry only for display, <varname>maxdecimaldigits</varname>=6 can be a good choice for many maps.</para>
-			<para>The last <varname>options</varname> argument could be used to add BBOX or CRS in GeoJSON output:
+			<para>The <varname>options</varname> argument could be used to add BBOX or CRS in GeoJSON output:
 			  <itemizedlist>
 				<listitem>
 				  <para>0: means no option (default value)</para>
@@ -400,31 +405,9 @@
 		<para>ST_AsGeoJSON only builds geometry. You need to build the rest of Feature from your Postgres table yourself:</para>
 		<programlisting>
-select row_to_json(fc)
-from (
-    select
-        'FeatureCollection' as "type",
-        array_to_json(array_agg(f)) as "features"
-    from (
-        select
-            'Feature' as "type",
-            ST_AsGeoJSON(ST_Transform(way, 4326), 6) :: json as "geometry",
-                select json_strip_nulls(row_to_json(t))
-                from (
-                    select
-                        osm_id,
-                        "natural",
-                        place
-                ) t
-            ) as "properties"
-        from planet_osm_point
-        where
-            "natural" is not null
-            or place is not null
-        limit 10
-    ) as f
-) as fc;
+SELECT planet_osm_point.*
+FROM planet_osm_point
+LIMIT 10;
 					   st_asgeojson
 {"type":"FeatureCollection","features":[{"type":"Feature","geometry":{"type":"Point","coordinates":[23.569251,51.541599]},"properties":{"osm_id":3424148658,"place":"locality"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.625174,51.511718]},"properties":{"osm_id":4322036818,"place":"locality"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.613928,51.5417]},"properties":{"osm_id":242979330,"place":"hamlet"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.586361,51.563272]},"properties":{"osm_id":3424148656,"place":"locality"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.605488,51.553886]},"properties":{"osm_id":242979323,"place":"village"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.6067,51.57609]},"properties":{"osm_id":242979327,"place":"village"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.636533,51.575683]},"properties":{"osm_id":5737800420,"place":"locality"}},{"type":"F
 eature","geometry":{"type":"Point","coordinates":[23.656733,51.518733]},"properties":{"osm_id":5737802397,"place":"locality"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.672542,51.504584]},"properties":{"osm_id":242979320,"place":"hamlet"}},{"type":"Feature","geometry":{"type":"Point","coordinates":[23.574094,51.63389]},"properties":{"osm_id":242979333,"place":"village"}}]}
@@ -433,17 +416,19 @@
 		<programlisting>SELECT ST_AsGeoJSON(geom) from fe_edges limit 1;
 					   st_asgeojson
 {"type":"MultiLineString","coordinates":[[[-89.734634999999997,31.492072000000000],
 [-89.734955999999997,31.492237999999997]]]}
 (1 row)</programlisting>
-<para>You can also use it with 3D geometries:</para>
+<para>You can also use the function with 3D geometries:</para>
 <programlisting>SELECT ST_AsGeoJSON('LINESTRING(1 2 3, 4 5 6)');
 st_asgeojson
  {"type":"LineString","coordinates":[[1,2,3],[4,5,6]]}</programlisting>
-	  </refsection>
+  </refsection>
   <refsection>
     <title>See Also</title>
Modified: trunk/libpgcommon/lwgeom_pg.c
--- trunk/libpgcommon/lwgeom_pg.c	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/libpgcommon/lwgeom_pg.c	2019-04-29 16:04:10 UTC (rev 17415)
@@ -20,6 +20,7 @@
 #include <executor/spi.h>
 #include <utils/guc.h>
 #include <utils/guc_tables.h>
+#include <catalog/namespace.h>
 #include "../postgis_config.h"
 #include "liblwgeom.h"
@@ -31,6 +32,34 @@
 #define PGC_ERRMSG_MAXLEN 2048 //256
+/* Global cache to hold GEOMETRYOID */
+Oid GEOMETRYOID = InvalidOid;
+Oid GEOGRAPHYOID = InvalidOid;
+Oid postgis_geometry_oid(void)
+	if (GEOMETRYOID == InvalidOid) {
+		Oid typoid = TypenameGetTypid("geometry");
+		if (OidIsValid(typoid) && get_typisdefined(typoid))
+			GEOMETRYOID = typoid;
+	return GEOMETRYOID;
+Oid postgis_geography_oid(void)
+	if (GEOGRAPHYOID == InvalidOid) {
+		Oid typoid = TypenameGetTypid("geography");
+			GEOGRAPHYOID = typoid;
+	return GEOGRAPHYOID;
  * Error message parsing functions
Modified: trunk/libpgcommon/lwgeom_pg.h
--- trunk/libpgcommon/lwgeom_pg.h	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/libpgcommon/lwgeom_pg.h	2019-04-29 16:04:10 UTC (rev 17415)
@@ -23,6 +23,12 @@
 #include "pgsql_compat.h"
+/* Globals to hold GEOMETRYOID, GEOGRAPHYOID */
+extern Oid GEOMETRYOID;
+extern Oid GEOGRAPHYOID;
+Oid postgis_geometry_oid(void);
+Oid postgis_geography_oid(void);
 /* Install PosgreSQL handlers for liblwgeom use */
 void pg_install_lwgeom_handlers(void);
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/postgis/Makefile.in	2019-04-29 16:04:10 UTC (rev 17415)
@@ -125,6 +125,7 @@
 	lwgeom_out_mvt.o \
 	geobuf.o \
 	lwgeom_out_geobuf.o \
+	lwgeom_out_geojson.o \
 	postgis_legacy.o
 # Objects to build using PGXS
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2019-04-24 11:07:56 UTC (rev 17414)
+++ trunk/postgis/postgis.sql.in	2019-04-29 16:04:10 UTC (rev 17415)
@@ -4587,11 +4587,18 @@
 -- ST_AsGeoJson(geom, precision, options) / version=1
 -- Changed 2.0.0 to use default args and named args
 CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
-	RETURNS TEXT
+	RETURNS text
 	AS 'MODULE_PATHNAME','LWGEOM_asGeoJson'
-	LANGUAGE 'c' IMMUTABLE STRICT  _PARALLEL
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
 	_COST_LOW;
+-- Availability: 3.0.0
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 15, pretty_print bool DEFAULT false)
+	RETURNS text
+	AS 'MODULE_PATHNAME','ST_AsGeoJsonRow'
+	LANGUAGE 'c' STABLE STRICT _PARALLEL
+	_COST_LOW;
 -- Mapbox Vector Tile OUTPUT
 -- Availability: 2.4.0
