[postgis-tickets] r17674 - Triangle and TIN output support
Darafei komzpa at gmail.com
Sun Aug 4 04:43:42 PDT 2019
Author: komzpa
Date: 2019-08-04 04:43:42 -0700 (Sun, 04 Aug 2019)
New Revision: 17674
   trunk/NEWS
   trunk/liblwgeom/lwgeom_median.c
   trunk/liblwgeom/lwin_twkb.c
   trunk/liblwgeom/lwin_wkb.c
   trunk/liblwgeom/lwiterator.c
   trunk/liblwgeom/lwmval.c
   trunk/liblwgeom/lwout_geojson.c
   trunk/liblwgeom/lwout_kml.c
   trunk/liblwgeom/lwout_twkb.c
   trunk/liblwgeom/lwout_wkb.c
   trunk/liblwgeom/lwstroke.c
   trunk/liblwgeom/measures.c
   trunk/liblwgeom/measures3d.c
   trunk/postgis/geobuf.c
   trunk/postgis/lwgeom_out_geobuf.c
   trunk/postgis/lwgeom_transform.c
   trunk/postgis/mvt.c
   trunk/regress/core/geometric_median_expected
   trunk/regress/core/out_geometry_expected
   trunk/regress/core/regress_proj_expected
   trunk/regress/core/tickets.sql
   trunk/regress/core/tickets_expected
Make all the "Unsupported geometry type" name themselves by __func__.
In case output format doesn't know about TIN/Triangle, output them as GeometryCollection/Polygon.
Closes #4399
Closes https://github.com/postgis/postgis/pull/454
Modified: trunk/NEWS
--- trunk/NEWS	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/NEWS	2019-08-04 11:43:42 UTC (rev 17674)
@@ -195,6 +195,8 @@
            ones faster. (Darafei Praliaskouski)
   - #4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
   - #4410, More descriptive error messages about SRID mismatch (Darafei Praliaskouski)
+  - #4399, TIN and Triangle output support in all output functions (Darafei
+           Praliaskouski)
 * Fixes *
   - #4342, Move deprecated functions into legacy.sql file
Modified: trunk/liblwgeom/lwgeom_median.c
--- trunk/liblwgeom/lwgeom_median.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwgeom_median.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -279,7 +279,7 @@
 LWPOINT*
 lwgeom_median(const LWGEOM* g, double tol, uint32_t max_iter, char fail_if_not_converged)
-	switch( lwgeom_get_type(g) )
+	switch (g->type)
 		case POINTTYPE:
 			return lwpoint_clone(lwgeom_as_lwpoint(g));
@@ -286,7 +286,7 @@
 		case MULTIPOINTTYPE:
 			return lwmpoint_median(lwgeom_as_lwmpoint(g), tol, max_iter, fail_if_not_converged);
 		default:
-			lwerror("Unsupported geometry type in lwgeom_median");
+			lwerror("%s: Unsupported geometry type: %s", __func__, lwtype_name(g->type));
 			return NULL;
Modified: trunk/liblwgeom/lwin_twkb.c
--- trunk/liblwgeom/lwin_twkb.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwin_twkb.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -631,14 +631,12 @@
 			break;
 		/* Unknown type! */
 		default:
-			lwerror("Unsupported geometry type: %s [%d]", lwtype_name(s->lwtype), s->lwtype);
+			lwerror("%s: Unsupported geometry type: %s", __func__, lwtype_name(s->lwtype));
 			break;
 	if ( has_bbox )
 		geom->bbox = gbox_clone(&bbox);
 	return geom;
Modified: trunk/liblwgeom/lwin_wkb.c
--- trunk/liblwgeom/lwin_wkb.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwin_wkb.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -745,7 +745,7 @@
 		/* Unknown type! */
 		default:
 	/* Return value to keep compiler happy. */
Modified: trunk/liblwgeom/lwiterator.c
--- trunk/liblwgeom/lwiterator.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwiterator.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -100,14 +100,12 @@
 		LWPOLY* p = lwgeom_as_lwpoly(g);
 		int i;
 		for (i = p->nrings - 1; i >= 0; i--)
 			n = prepend_node(p->rings[i], n);
 		return n;
 	default:
-		lwerror("Unsupported geometry type for lwpointiterator");
 	return NULL;
Modified: trunk/liblwgeom/lwmval.c
--- trunk/liblwgeom/lwmval.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwmval.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -212,7 +212,7 @@
 		/* Unknown type! */
 		default:
-			lwerror("Unsupported geometry type: %s [%d] in function %s", lwtype_name((geom)->type), (geom)->type, __func__);
+			lwerror("%s: Unsupported geometry type: %s", __func__, lwtype_name(geom->type));
 	return geom_out;
@@ -258,7 +258,7 @@
 			/* Unknown type! */
 			default:
 	/*Shouldn't be possible*/
Modified: trunk/liblwgeom/lwout_geojson.c
--- trunk/liblwgeom/lwout_geojson.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwout_geojson.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -30,11 +30,12 @@
 static char *asgeojson_point(const LWPOINT *point, char *srs, GBOX *bbox, int precision);
 static char *asgeojson_line(const LWLINE *line, char *srs, GBOX *bbox, int precision);
+static char *asgeojson_triangle(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision);
 static char *asgeojson_poly(const LWPOLY *poly, char *srs, GBOX *bbox, int precision);
-static char * asgeojson_multipoint(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int precision);
-static char * asgeojson_multiline(const LWMLINE *mline, char *srs, GBOX *bbox, int precision);
-static char * asgeojson_multipolygon(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int precision);
-static char * asgeojson_collection(const LWCOLLECTION *col, char *srs, GBOX *bbox, int precision);
+static char *asgeojson_multipoint(const LWMPOINT *mpoint, char *srs, GBOX *bbox, int precision);
+static char *asgeojson_multiline(const LWMLINE *mline, char *srs, GBOX *bbox, int precision);
+static char *asgeojson_multipolygon(const LWMPOLY *mpoly, char *srs, GBOX *bbox, int precision);
+static char *asgeojson_collection(const LWCOLLECTION *col, char *srs, GBOX *bbox, int precision);
 static size_t asgeojson_geom_size(const LWGEOM *geom, GBOX *bbox, int precision);
 static size_t asgeojson_geom_buf(const LWGEOM *geom, char *output, GBOX *bbox, int precision);
@@ -75,6 +76,9 @@
 		return asgeojson_multiline((LWMLINE*)geom, srs, bbox, precision);
 	case MULTIPOLYGONTYPE:
 		return asgeojson_multipolygon((LWMPOLY*)geom, srs, bbox, precision);
+	case TRIANGLETYPE:
+		return asgeojson_triangle((LWTRIANGLE *)geom, srs, bbox, precision);
+	case TINTYPE:
 	case COLLECTIONTYPE:
 		return asgeojson_collection((LWCOLLECTION*)geom, srs, bbox, precision);
 	default:
@@ -209,8 +213,56 @@
 	return output;
+ * Triangle Geometry
+static size_t
+asgeojson_triangle_size(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision)
+	int size;
+	size = sizeof("{'type':'Polygon',");
+	if (srs)
+		size += asgeojson_srs_size(srs);
+	if (bbox)
+		size += asgeojson_bbox_size(FLAGS_GET_Z(tri->flags), precision);
+	size += sizeof("'coordinates':[[]]}");
+	size += pointArray_geojson_size(tri->points, precision);
+	return size;
+static size_t
+asgeojson_triangle_buf(const LWTRIANGLE *tri, char *srs, char *output, GBOX *bbox, int precision)
+	char *ptr = output;
+	ptr += sprintf(ptr, "{\"type\":\"Polygon\",");
+	if (srs)
+		ptr += asgeojson_srs_buf(ptr, srs);
+	if (bbox)
+		ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(tri->flags), precision);
+	ptr += sprintf(ptr, "\"coordinates\":[[");
+	ptr += pointArray_to_geojson(tri->points, ptr, precision);
+	ptr += sprintf(ptr, "]]}");
+	return (ptr - output);
+static char *
+asgeojson_triangle(const LWTRIANGLE *tri, char *srs, GBOX *bbox, int precision)
+	char *output;
+	int size;
+	size = asgeojson_triangle_size(tri, srs, bbox, precision);
+	output = lwalloc(size);
+	asgeojson_triangle_buf(tri, srs, output, bbox, precision);
+	return output;
  * Line Geometry
@@ -288,6 +340,7 @@
 asgeojson_poly_buf(const LWPOLY *poly, char *srs, char *output, GBOX *bbox, int precision)
 	uint32_t i;
 	char *ptr=output;
@@ -599,40 +652,26 @@
 static size_t
-	int type = geom->type;
-	size_t size = 0;
-	switch (type)
+	switch (geom->type)
 	case POINTTYPE:
-		size = asgeojson_point_size((LWPOINT*)geom, NULL, bbox, precision);
-		break;
+		return asgeojson_point_size((LWPOINT *)geom, NULL, bbox, precision);
 	case LINETYPE:
-		size = asgeojson_line_size((LWLINE*)geom, NULL, bbox, precision);
-		break;
+		return asgeojson_line_size((LWLINE *)geom, NULL, bbox, precision);
+		return asgeojson_triangle_size((LWTRIANGLE *)geom, NULL, bbox, precision);
 	case POLYGONTYPE:
-		size = asgeojson_poly_size((LWPOLY*)geom, NULL, bbox, precision);
-		break;
+		return asgeojson_poly_size((LWPOLY *)geom, NULL, bbox, precision);
-		size = asgeojson_multipoint_size((LWMPOINT*)geom, NULL, bbox, precision);
-		break;
+		return asgeojson_multipoint_size((LWMPOINT *)geom, NULL, bbox, precision);
 	case MULTILINETYPE:
-		size = asgeojson_multiline_size((LWMLINE*)geom, NULL, bbox, precision);
-		break;
+		return asgeojson_multiline_size((LWMLINE *)geom, NULL, bbox, precision);
-		size = asgeojson_multipolygon_size((LWMPOLY*)geom, NULL, bbox, precision);
-		break;
+		return asgeojson_multipolygon_size((LWMPOLY *)geom, NULL, bbox, precision);
 	default:
 		lwerror("GeoJson: geometry not supported.");
+		return 0;
-	return size;
@@ -656,6 +695,10 @@
 		ptr += asgeojson_poly_buf((LWPOLY*)geom, NULL, ptr, bbox, precision);
 		break;
+		ptr += asgeojson_triangle_buf((LWTRIANGLE *)geom, NULL, ptr, bbox, precision);
+		break;
 		ptr += asgeojson_multipoint_buf((LWMPOINT*)geom, NULL, ptr, bbox, precision);
 		break;
Modified: trunk/liblwgeom/lwout_kml.c
--- trunk/liblwgeom/lwout_kml.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwout_kml.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -30,6 +30,7 @@
 static int lwgeom_to_kml2_sb(const LWGEOM *geom, int precision, const char *prefix, stringbuffer_t *sb);
 static int lwpoint_to_kml2_sb(const LWPOINT *point, int precision, const char *prefix, stringbuffer_t *sb);
 static int lwline_to_kml2_sb(const LWLINE *line, int precision, const char *prefix, stringbuffer_t *sb);
+static int lwtriangle_to_kml2_sb(const LWTRIANGLE *tri, int precision, const char *prefix, stringbuffer_t *sb);
 static int lwpoly_to_kml2_sb(const LWPOLY *poly, int precision, const char *prefix, stringbuffer_t *sb);
 static int lwcollection_to_kml2_sb(const LWCOLLECTION *col, int precision, const char *prefix, stringbuffer_t *sb);
 static int ptarray_to_kml2_sb(const POINTARRAY *pa, int precision, stringbuffer_t *sb);
@@ -76,6 +77,9 @@
 	case LINETYPE:
 		return lwline_to_kml2_sb((LWLINE*)geom, precision, prefix, sb);
+		return lwtriangle_to_kml2_sb((LWTRIANGLE *)geom, precision, prefix, sb);
 	case POLYGONTYPE:
 		return lwpoly_to_kml2_sb((LWPOLY*)geom, precision, prefix, sb);
@@ -82,6 +86,7 @@
 	case MULTILINETYPE:
+	case TINTYPE:
 		return lwcollection_to_kml2_sb((LWCOLLECTION*)geom, precision, prefix, sb);
 	default:
@@ -147,6 +152,25 @@
 static int
+lwtriangle_to_kml2_sb(const LWTRIANGLE *tri, int precision, const char *prefix, stringbuffer_t *sb)
+	/* Open polygon */
+	if (stringbuffer_aprintf(
+		sb, "<%sPolygon><%souterBoundaryIs><%sLinearRing><%scoordinates>", prefix, prefix, prefix, prefix) < 0)
+		return LW_FAILURE;
+	/* Coordinate array */
+	if (ptarray_to_kml2_sb(tri->points, precision, sb) == LW_FAILURE)
+	/* Close polygon */
+		sb, "</%scoordinates></%sLinearRing></%souterBoundaryIs></%sPolygon>", prefix, prefix, prefix, prefix) <
+	    0)
+	return LW_SUCCESS;
+static int
 	uint32_t i;
Modified: trunk/liblwgeom/lwout_twkb.c
--- trunk/liblwgeom/lwout_twkb.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwout_twkb.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -42,6 +42,7 @@
 		case LINETYPE:
 			twkb_type = WKB_LINESTRING_TYPE;
 			break;
 		case POLYGONTYPE:
 			twkb_type = WKB_POLYGON_TYPE;
 			break;
@@ -54,12 +55,12 @@
 			twkb_type = WKB_MULTIPOLYGON_TYPE;
 			break;
+		case TINTYPE:
 			twkb_type = WKB_GEOMETRYCOLLECTION_TYPE;
 			break;
 		default:
-				lwtype_name(geom->type), geom->type);
 	return twkb_type;
@@ -254,6 +255,17 @@
 	return 0;
+static int
+lwtriangle_to_twkb_buf(const LWTRIANGLE *tri, TWKB_GLOBALS *globals, TWKB_STATE *ts)
+	LWDEBUGF(2, "Entered %s", __func__);
+	bytebuffer_append_uvarint(ts->geom_buf, (uint64_t)1);
+	/* Set the coordinates (do write npoints) */
+	ptarray_to_twkb_buf(tri->points, globals, ts, 1, 2);
+	return 0;
 * POLYGONS
@@ -379,6 +391,11 @@
 			LWDEBUGF(4,"Type found is Linestring, %d", geom->type);
 			return lwline_to_twkb_buf((LWLINE*) geom, globals, ts);
+			LWDEBUGF(4, "Type found is Triangle, %d", geom->type);
+			return lwtriangle_to_twkb_buf((LWTRIANGLE *)geom, globals, ts);
 		/* Polygon has 'nrings' and 'rings' elements */
 		case POLYGONTYPE:
@@ -395,6 +412,7 @@
 			return lwmulti_to_twkb_buf((LWCOLLECTION*)geom, globals, ts);
+		case TINTYPE:
 			LWDEBUGF(4,"Type found is collection, %d", geom->type);
 			return lwcollection_to_twkb_buf((LWCOLLECTION*) geom, globals, ts);
@@ -401,7 +419,7 @@
 		/* Unknown type! */
 		default:
-			lwerror("Unsupported geometry type: %s [%d]", lwtype_name((geom)->type), (geom)->type);
 	return 0;
Modified: trunk/liblwgeom/lwout_wkb.c
--- trunk/liblwgeom/lwout_wkb.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwout_wkb.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -131,8 +131,7 @@
 		wkb_type = WKB_TRIANGLE_TYPE;
 		break;
 	default:
 	if ( variant & WKB_EXTENDED )
@@ -723,7 +722,7 @@
 		/* Unknown type! */
 		default:
-			lwerror("Unsupported geometry type: %s [%d]", lwtype_name(geom->type), geom->type);
 	return size;
@@ -771,7 +770,7 @@
 		/* Unknown type! */
 		default:
 	return 0;
Modified: trunk/liblwgeom/lwstroke.c
--- trunk/liblwgeom/lwstroke.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/lwstroke.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -577,8 +577,7 @@
 		else
-			lwerror("Unsupported geometry type %d found.",
-			        geom->type, lwtype_name(geom->type));
 			return NULL;
Modified: trunk/liblwgeom/measures.c
--- trunk/liblwgeom/measures.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/measures.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -390,7 +390,7 @@
 				case CURVEPOLYTYPE:
 					return lw_dist2d_point_curvepoly((LWPOINT *)lwg1, (LWCURVEPOLY *)lwg2, dl);
 				default:
-					lwerror("Unsupported geometry type: %s", lwtype_name(t2));
+					lwerror("%s: Unsupported geometry type: %s", __func__, lwtype_name(t2));
 					return LW_FALSE;
@@ -411,7 +411,7 @@
 				case CURVEPOLYTYPE:
 					return lw_dist2d_line_curvepoly((LWLINE *)lwg1, (LWCURVEPOLY *)lwg2, dl);
 				default:
 					return LW_FALSE;
@@ -433,7 +433,7 @@
 				case CURVEPOLYTYPE:
 					return lw_dist2d_circstring_curvepoly((LWCIRCSTRING *)lwg1, (LWCURVEPOLY *)lwg2, dl);
 				default:
 					return LW_FALSE;
@@ -455,7 +455,7 @@
 					dl->twisted = 1;
 					return lw_dist2d_poly_curvepoly((LWPOLY *)lwg1, (LWCURVEPOLY *)lwg2, dl);
 				default:
 					return LW_FALSE;
@@ -476,13 +476,13 @@
 					dl->twisted = 1;
 					return lw_dist2d_curvepoly_curvepoly((LWCURVEPOLY *)lwg1, (LWCURVEPOLY *)lwg2, dl);
 				default:
 					return LW_FALSE;
 		default:
-			lwerror("Unsupported geometry type: %s", lwtype_name(t1));
+			lwerror("%s: Unsupported geometry type: %s", __func__, lwtype_name(t1));
 			return LW_FALSE;
Modified: trunk/liblwgeom/measures3d.c
--- trunk/liblwgeom/measures3d.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/liblwgeom/measures3d.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -589,7 +589,7 @@
 		else
 			return LW_FALSE;
@@ -617,7 +617,7 @@
 		else
 			return LW_FALSE;
@@ -645,7 +645,7 @@
 		else
 			return LW_FALSE;
@@ -673,7 +673,7 @@
 		else
 			return LW_FALSE;
@@ -680,7 +680,7 @@
 	else
 		return LW_FALSE;
Modified: trunk/postgis/geobuf.c
--- trunk/postgis/geobuf.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/postgis/geobuf.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -253,6 +253,23 @@
 	return geometry;
+static Data__Geometry *
+encode_triangle(struct geobuf_agg_context *ctx, LWTRIANGLE *lwtri)
+	Data__Geometry *geometry = galloc(DATA__GEOMETRY__TYPE__POLYGON);
+	POINTARRAY *pa = lwtri->points;
+	uint32_t len;
+	if (pa->npoints == 0)
+		return geometry;
+	len = pa->npoints - 1;
+	geometry->n_coords = len * ctx->dimensions;
+	geometry->coords = encode_coords(ctx, pa, NULL, len, 0);
+	return geometry;
 static Data__Geometry *encode_mline(struct geobuf_agg_context *ctx,
 	LWMLINE *lwmline)
@@ -415,6 +432,8 @@
 		return encode_point(ctx, (LWPOINT*)lwgeom);
 	case LINETYPE:
 		return encode_line(ctx, (LWLINE*)lwgeom);
+		return encode_triangle(ctx, (LWTRIANGLE *)lwgeom);
 	case POLYGONTYPE:
 		return encode_poly(ctx, (LWPOLY*)lwgeom);
@@ -424,6 +443,7 @@
 		return encode_mpoly(ctx, (LWMPOLY*)lwgeom);
+	case TINTYPE:
 		return encode_collection(ctx, (LWCOLLECTION*)lwgeom);
 	default:
 		elog(ERROR, "encode_geometry: '%s' geometry type not supported",
@@ -465,6 +485,7 @@
 	case POINTTYPE:
 	case LINETYPE:
 		lwline = (LWLINE*) lwgeom;
 		analyze_pa(ctx, lwline->points);
 		break;
@@ -477,6 +498,7 @@
 	case MULTILINETYPE:
+	case TINTYPE:
 		lwcollection = (LWCOLLECTION*) lwgeom;
 		for (i = 0; i < lwcollection->ngeoms; i++)
 			analyze_geometry(ctx, lwcollection->geoms[i]);
Modified: trunk/postgis/lwgeom_out_geobuf.c
--- trunk/postgis/lwgeom_out_geobuf.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/postgis/lwgeom_out_geobuf.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -46,7 +46,7 @@
 Datum pgis_asgeobuf_transfn(PG_FUNCTION_ARGS)
 #if ! (defined HAVE_LIBPROTOBUF && defined HAVE_GEOBUF)
-	elog(ERROR, "Missing libprotobuf-c >= version 1.1");
+	elog(ERROR, "ST_AsGeobuf: Missing libprotobuf-c >= version 1.1");
 	PG_RETURN_NULL();
 #else
 	MemoryContext aggcontext;
@@ -53,7 +53,7 @@
 	struct geobuf_agg_context *ctx;
 	if (!AggCheckCallContext(fcinfo, &aggcontext))
-		elog(ERROR, "pgis_asmvt_transfn: called in non-aggregate context");
+		elog(ERROR, "pgis_asgeobuf_transfn: called in non-aggregate context");
 	MemoryContextSwitchTo(aggcontext);
 	if (PG_ARGISNULL(0)) {
@@ -83,7 +83,7 @@
 Datum pgis_asgeobuf_finalfn(PG_FUNCTION_ARGS)
+	elog(ERROR, "ST_AsGeoBuf: Missing libprotobuf-c >= version 1.1");
 	PG_RETURN_NULL();
 #else
 	uint8_t *buf;
Modified: trunk/postgis/lwgeom_transform.c
--- trunk/postgis/lwgeom_transform.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/postgis/lwgeom_transform.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -56,7 +56,7 @@
 	srid_to = PG_GETARG_INT32(1);
 	if (srid_to == SRID_UNKNOWN)
-		elog(ERROR, "%d is an invalid target SRID", SRID_UNKNOWN);
+		elog(ERROR, "ST_Transform: %d is an invalid target SRID", SRID_UNKNOWN);
 		PG_RETURN_NULL();
@@ -66,7 +66,7 @@
 	if ( srid_from == SRID_UNKNOWN )
 		PG_FREE_IF_COPY(geom, 0);
-		elog(ERROR, "Input geometry has unknown (%d) SRID", SRID_UNKNOWN);
+		elog(ERROR, "ST_Transform: Input geometry has unknown (%d) SRID", SRID_UNKNOWN);
 		PG_RETURN_NULL();
@@ -77,7 +77,7 @@
 	if ( GetPJUsingFCInfo(fcinfo, srid_from, srid_to, &pj) == LW_FAILURE )
-		elog(ERROR, "Failure reading projections from spatial_ref_sys.");
+		elog(ERROR, "ST_Transform: Failure reading projections from spatial_ref_sys.");
 		PG_RETURN_NULL();
@@ -187,7 +187,7 @@
+		elog(ERROR, "ST_AsKML: Input geometry has unknown (%d) SRID", SRID_UNKNOWN);
 		PG_RETURN_NULL();
@@ -217,7 +217,7 @@
 		if (GetPJUsingFCInfo(fcinfo, srid_from, srid_to, &pj) == LW_FAILURE)
+			elog(ERROR, "ST_AsKML: Failure reading projections from spatial_ref_sys.");
 			PG_RETURN_NULL();
 		lwgeom_transform(lwgeom, pj);
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/postgis/mvt.c	2019-08-04 11:43:42 UTC (rev 17674)
@@ -788,11 +788,14 @@
 	case LINETYPE:
 	case POLYGONTYPE:
 		return geom->type;
+		return POLYGONTYPE;
 	case MULTILINETYPE:
 		return geom->type - 3; /* Based on LWTYPE positions */
+	case TINTYPE:
 		uint32_t i;
 		uint8 type = 0;
Modified: trunk/regress/core/geometric_median_expected
--- trunk/regress/core/geometric_median_expected	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/regress/core/geometric_median_expected	2019-08-04 11:43:42 UTC (rev 17674)
@@ -1,5 +1,5 @@
 t1|t
-ERROR:  Unsupported geometry type in lwgeom_median
+ERROR:  lwgeom_median: Unsupported geometry type: LineString
 t3|t
 t4|t
 t5|t
Modified: trunk/regress/core/out_geometry_expected
--- trunk/regress/core/out_geometry_expected	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/regress/core/out_geometry_expected	2019-08-04 11:43:42 UTC (rev 17674)
@@ -32,7 +32,7 @@
 gml_out_curve_04|<gml:MultiCurve><gml:curveMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">5 5 3 5 3 3 0 3</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList srsDimension="2">0 0 2 1 2 2</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:MultiCurve>
 gml_out_curve_05|<gml:MultiSurface><gml:Polygon><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList srsDimension="2">-2 0 -1 -1 0 0 1 -1 2 0 0 2 -2 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">-1 0 0 0.5 1 0 0 1 -1 0</gml:posList></gml:LinearRing></gml:interior></gml:Polygon><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">7 8 10 10 6 14 4 11 7 8</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></gml:MultiSurface>
 ERROR:  Cannot find SRID (10) in spatial_ref_sys
-ERROR:  Input geometry has unknown (0) SRID
+ERROR:  ST_AsKML: Input geometry has unknown (0) SRID
 kml_empty_geom|
 kml_precision_01|<Point><coordinates>1,1</coordinates></Point>
 kml_precision_02|<Point><coordinates>1.1111111,1.1111111</coordinates></Point>
Modified: trunk/regress/core/regress_proj_expected
--- trunk/regress/core/regress_proj_expected	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/regress/core/regress_proj_expected	2019-08-04 11:43:42 UTC (rev 17674)
@@ -5,7 +5,7 @@
 4|SRID=100001;LINESTRING(574600 5316780,573140 5427940)
 5|SRID=100001;LINESTRING(574600 5316780 0 0,573140 5427940 0 0)
 6|16.00000000|48.00000000
+ERROR:  ST_Transform: Input geometry has unknown (0) SRID
 8|SRID=100002;POINT(0 0)
 9|POINT(574600 5316780)
 10|POINT(574600 5316780)
Modified: trunk/regress/core/tickets.sql
--- trunk/regress/core/tickets.sql	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/regress/core/tickets.sql	2019-08-04 11:43:42 UTC (rev 17674)
@@ -1267,3 +1267,39 @@
        p1.geom  >=   p0.geom,
        p1.geom  >    p0.geom
 FROM p0, p1;
+WITH geom AS (
+	SELECT 'TRIANGLE((0 0, 1 1, 0 1, 0 0))'::geometry geom
+	union all
+	SELECT 'TIN(((0 0, 1 1, 0 1, 0 0)))'::geometry geom
+	union all
+	SELECT 'TRIANGLE EMPTY'::geometry geom
+select '#4399', 'ST_AsBinary', ST_AsBinary(geom)::text from geom
+union all
+select '#4399', 'ST_AsEWKB', ST_AsEWKB(geom)::text from geom
+union all
+select '#4399', 'ST_AsEWKT', ST_AsEWKT(geom)::text from geom
+union all
+select '#4399', 'ST_AsGML', ST_AsGML(3,geom)::text from geom
+union all
+select '#4399', 'ST_AsHEXEWKB', ST_AsHEXEWKB(geom)::text from geom
+union all
+select '#4399', 'ST_AsKML', ST_AsKML(ST_SetSRID(geom, 4326))::text from geom
+union all
+select '#4399', 'ST_AsText', ST_AsText(geom)::text from geom
+union all
+select '#4399', 'ST_AsTWKB', ST_AsTWKB(geom)::text from geom
+union all
+select '#4399', 'ST_AsX3D', ST_AsX3D(geom)::text from geom
+union all
+select '#4399', 'ST_GeoHash', ST_GeoHash(geom)::text from geom
+union all
+select '#4399', 'ST_AsGeobuf', ST_AsGeobuf(geom.*)::text from geom
+union all
+select '#4399', 'ST_AsMVTGeom', ST_AsMVTGeom(geom, ST_MakeBox2D(ST_Point(0, 0), ST_Point(32, 32)))::text from geom
+union all
+select '#4399', 'ST_AsGeoJSON', ST_AsGeoJSON(geom)::text from geom;
Modified: trunk/regress/core/tickets_expected
--- trunk/regress/core/tickets_expected	2019-08-04 11:37:34 UTC (rev 17673)
+++ trunk/regress/core/tickets_expected	2019-08-04 11:43:42 UTC (rev 17674)
@@ -391,3 +391,40 @@
 #4176|t
 #4394
 #4445|f|t|t|t|f|t|t|f|f|f|f|f|f|t|t
+#4399|ST_AsBinary|\x0111000000010000000400000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000
+#4399|ST_AsBinary|\x0110000000010000000111000000010000000400000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000
+#4399|ST_AsBinary|\x011100000000000000
+#4399|ST_AsEWKB|\x0111000000010000000400000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000
+#4399|ST_AsEWKB|\x0110000000010000000111000000010000000400000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000
+#4399|ST_AsEWKB|\x011100000000000000
+#4399|ST_AsEWKT|TRIANGLE((0 0,1 1,0 1,0 0))
+#4399|ST_AsEWKT|TIN(((0 0,1 1,0 1,0 0)))
+#4399|ST_AsEWKT|TRIANGLE EMPTY
+#4399|ST_AsGML|<gml:Triangle><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">0 0 1 1 0 1 0 0</gml:posList></gml:LinearRing></gml:exterior></gml:Triangle>
+#4399|ST_AsGML|<gml:Tin><gml:trianglePatches><gml:Triangle><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">0 0 1 1 0 1 0 0</gml:posList></gml:LinearRing></gml:exterior></gml:Triangle></gml:trianglePatches></gml:Tin>
+#4399|ST_AsGML|
+#4399|ST_AsHEXEWKB|0111000000010000000400000000000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F00000000000000000000000000000000
+#4399|ST_AsHEXEWKB|0110000000010000000111000000010000000400000000000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F00000000000000000000000000000000
+#4399|ST_AsHEXEWKB|011100000000000000
+#4399|ST_AsKML|<Polygon><outerBoundaryIs><LinearRing><coordinates>0,0 1,1 0,1 0,0</coordinates></LinearRing></outerBoundaryIs></Polygon>
+#4399|ST_AsKML|<MultiGeometry><Polygon><outerBoundaryIs><LinearRing><coordinates>0,0 1,1 0,1 0,0</coordinates></LinearRing></outerBoundaryIs></Polygon></MultiGeometry>
+#4399|ST_AsKML|
+#4399|ST_AsText|TRIANGLE((0 0,1 1,0 1,0 0))
+#4399|ST_AsText|TIN(((0 0,1 1,0 1,0 0)))
+#4399|ST_AsText|TRIANGLE EMPTY
+#4399|ST_AsTWKB|\x030001040000020201000001
+#4399|ST_AsTWKB|\x070001030001040000020201000001
+#4399|ST_AsTWKB|\x0310
+#4399|ST_AsX3D|0 0 1 1 0 1
+#4399|ST_AsX3D|<IndexedTriangleSet  index='0 1 2'><Coordinate point='0 0 1 1 0 1'/></IndexedTriangleSet>
+#4399|ST_AsX3D|
+#4399|ST_GeoHash|
+#4399|ST_GeoHash|
+#4399|ST_GeoHash|
+#4399|ST_AsGeobuf|\x180022260a0c0a0a08041a060000020201000a100a0e0806220a08041a060000020201000a040a020804
+#4399|ST_AsMVTGeom|011100000001000000040000000000000000000000000000000000B0400000000000000000000000000000AF400000000000006040000000000000AF400000000000000000000000000000B040
+#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}
+#4399|ST_AsGeoJSON|{"type":"GeometryCollection","geometries":[{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}]}
+#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[]]}
