[postgis-tickets] [PostGIS] #4399: Support TIN in output functions
PostGIS trac at osgeo.org
Sun Aug 4 04:43:43 PDT 2019
  Reporter:  komzpa       |      Owner:  komzpa
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.0.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by komzpa):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17674" 17674]:
 #!CommitTicketReference repository="" revision="17674"
 Triangle and TIN output support
 Make all the "Unsupported geometry type" name themselves by __func__.
 In case output format doesn't know about TIN/Triangle, output them as
 GeometryCollection/Polygon.
 Closes #4399
 Closes https://github.com/postgis/postgis/pull/454
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4399#comment:2>
