[postgis-tickets] [PostGIS] #4377: replace old piecrust
PostGIS trac at osgeo.org
Tue Aug 6 12:15:25 PDT 2019
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  Management 2.0
 Component:  website  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Comment (by komzpa):
 In [changeset:"17678" 17678]:
 #!CommitTicketReference repository="" revision="17678"
 Improve GeoJSON SRID handling.
 If SRID is not specified, set it to 4326 by default on parsing, following
 RFC7946.
 If SRID is not 4326 on serialization, it will be marked in JSON unless
 disabled, making round trips almost lossless.
 Fixes spatial_ref_sys truncation in all the tests.
 Closes #4377
 Closes https://github.com/postgis/postgis/pull/455
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4377#comment:2>
