[postgis-tickets] [PostGIS] #4472: ST_AsMVT is being tested even on system without proto-buf installed
PostGIS trac at osgeo.org
Fri Aug 9 15:50:19 PDT 2019
  Reporter:  robe     |      Owner:  komzpa
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17682" 17682]:
 #!CommitTicketReference repository="" revision="17682"
 Move protobuf specific ticket lines to mvt test
 Closes #4472
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4472#comment:2>
