[postgis-tickets] r17737 - Update postgis_extensions_upgrade docs to reflect new return value
Sandro Santilli strk at kbt.io
Tue Aug 20 07:03:39 PDT 2019
Author: strk
Date: 2019-08-20 07:03:39 -0700 (Tue, 20 Aug 2019)
New Revision: 17737
   trunk/doc/reference_version.xml
Modified: trunk/doc/reference_version.xml
--- trunk/doc/reference_version.xml	2019-08-20 11:38:06 UTC (rev 17736)
+++ trunk/doc/reference_version.xml	2019-08-20 14:03:39 UTC (rev 17737)
@@ -58,13 +58,9 @@
 NOTICE:  Extension postgis_topology is not available or not packagable for some reason
 NOTICE:  Extension postgis_tiger_geocoder is not available or not packagable for some reason
-							   postgis_extensions_upgrade
-POSTGIS="3.0.0dev r16878" [EXTENSION] PGSQL="96"
-GEOS="3.8.0dev-CAPI-1.11.0 a67b6f86" SFCGAL="1.3.5" PROJ="Rel. 4.9.3,
-15 August 2016" GDAL="GDAL 2.3.0dev, released 2017/99/99"
-LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" TOPOLOGY
-[UNPACKAGED!] RASTER
+                    postgis_extensions_upgrade
+ Upgrade completed, run SELECT postgis_full_version(); for details
 (1 row)</screen>
 	  </refsection>
