[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 ST_AsGeoJSON
PostGIS trac at osgeo.org
Wed Aug 21 23:27:37 PDT 2019
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by strk):
 Ok I see what you mean by "tag". Yes, changing back would fix {{{ A>C }}}
 but break {{{ B>C }}} and keep {{{ A>B }}} broken. If {{{ A }}} is just an
 {{{ alpha }}} tag we can say those are not really supported and move on.
 Alternatively, we'll need to drop the function in the {{{
 postgis_before_upgrade.sql }}} file, so it is created anew, but that would
 break in case there's any view using the function.
 How I'm running the test is written in the first comment, but to simplify,
 it is:
 {{{ regress/run_test.pl -v --upgrade --upgrade-path 3.0.0alpha3--
 3.0.0alpha5dev }}}
 or something along those lines (note that current run_test.pl also
 supports ":auto" for the target version of an upgrade
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:7>
