[postgis-tickets] r17758 - Split "check" into "check-regress" and "check-unit"
Sandro Santilli strk at kbt.io
Thu Aug 22 06:37:00 PDT 2019
Author: strk
Date: 2019-08-22 06:36:59 -0700 (Thu, 22 Aug 2019)
New Revision: 17758
   trunk/GNUmakefile.in
   trunk/deps/Makefile.in
   trunk/doc/Makefile.in
   trunk/extensions/Makefile.in
   trunk/liblwgeom/Makefile.in
   trunk/libpgcommon/Makefile.in
   trunk/loader/Makefile.in
   trunk/postgis/Makefile.in
   trunk/raster/Makefile.in
   trunk/raster/test/Makefile.in
   trunk/regress/Makefile.in
   trunk/topology/Makefile.in
   trunk/topology/test/Makefile.in
   trunk/utils/Makefile.in
Makes "installcheck" only run "check-regress"
Closes #4487
Modified: trunk/GNUmakefile.in
--- trunk/GNUmakefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/GNUmakefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -16,7 +16,7 @@
 PERL = @PERL@
 # todo: add more rules here, like uninstall, clean...
-all install uninstall noop clean distclean check:
+all install uninstall noop clean distclean check-unit check-regress:
 	for s in $(SUBDIRS); do \
 		echo "---- Making $@ in $${s}"; \
 		$(MAKE) -C $${s} $@ || exit 1; \
@@ -39,7 +39,7 @@
 # TODO: drop 'test' target..
 test: check
-check: all docs-check check-no-trailing-blanks
+check: all docs-check check-no-trailing-blanks check-unit check-regress
 check-no-trailing-blanks:
 	! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
@@ -53,7 +53,7 @@
 installcheck: installcheck-base installcheck-upgrade
 installcheck-base:
-	RUNTESTFLAGS="$(RUNTESTFLAGS) --extension" $(MAKE) check
+	RUNTESTFLAGS="$(RUNTESTFLAGS) --extension" $(MAKE) check-regress
 # only run upgrade test if RUNTESTFLAGS was not already doing that
 installcheck-upgrade: installcheck-upgrade-byfunc
@@ -60,7 +60,7 @@
 	if test -z `echo "$(RUNTESTFLAGS)" | grep -- --upgrade`; then \
 		RUNTESTFLAGS="$(RUNTESTFLAGS) --extension \
 			--upgrade-path unpackaged--$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)" \
-			$(MAKE) check; \
+			$(MAKE) check-regress; \
 	fi
@@ -68,7 +68,7 @@
 			--upgrade-path unpackaged--$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)!" \
-			$(MAKE) check; \
 	fi
 distclean: distclean-local
Modified: trunk/deps/Makefile.in
--- trunk/deps/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/deps/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -40,7 +40,7 @@
 uninstall:
-check:
+check check-unit check-regress:
 clean:
 	$(MAKE) -C wagyu $@
Modified: trunk/doc/Makefile.in
--- trunk/doc/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/doc/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -420,10 +420,13 @@
+check: check-unit
+check-regress:
 ifeq ($(XMLLINT),)
-check: requirements_not_met_xmllint
+check-unit: requirements_not_met_xmllint
 else
-check: $(XML_INPUTS)
+check-unit: $(XML_INPUTS)
 	$(XMLLINT) --loaddtd --xinclude --valid postgis-out.xml > /dev/null
 endif
Modified: trunk/extensions/Makefile.in
--- trunk/extensions/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/extensions/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -37,6 +37,6 @@
 	rm -f Makefile
-check:
 	@echo "Nothing to check"
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/liblwgeom/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -193,7 +193,11 @@
 	rm -f liblwgeom.h Makefile
 	rm -f Makefile
-check: liblwgeom.la
+check: check-unit
+check-regress:
+check-unit: liblwgeom.la
 	$(MAKE) -C cunit check
 # Command to build each of the .lo files
Modified: trunk/libpgcommon/Makefile.in
--- trunk/libpgcommon/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/libpgcommon/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -53,7 +53,11 @@
 	$(MAKE) -C cunit distclean
 	rm -f Makefile
-check: libpgcommon.a
+check: check-unit
+check-regress:
+check-unit: libpgcommon.a
 # Command to build each of the .o files
Modified: trunk/loader/Makefile.in
--- trunk/loader/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/loader/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -153,7 +153,11 @@
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(SHP2PGSQL-CLI)"
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(SHP2PGSQL-GUI)"
-check:
+# TODO: move here what's currently run from regress/loader and
+# regress/dumper ?
+check-regress:
+check-unit:
 clean:
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/postgis/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -271,4 +271,8 @@
 distclean: clean
 	rm -f Makefile
+check-unit:
+check-regress:
 maintainer-clean: distclean
Modified: trunk/raster/Makefile.in
--- trunk/raster/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/raster/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -62,8 +62,5 @@
 	$(MAKE) -C scripts $@
 	rm -f raster_config.h Makefile
-core-check:
+check check-unit check-regress core-check:
 	$(MAKE) -C test $@
-check:
-	$(MAKE) -C test $@
Modified: trunk/raster/test/Makefile.in
--- trunk/raster/test/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/raster/test/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -11,10 +11,14 @@
 all: check
-core-check:
+check: check-unit check-regress
+core-check: check-unit
+check-unit:
-check: core-check
+check-regress:
 	$(MAKE) -C regress check
 clean:
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/regress/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -39,7 +39,11 @@
 all install uninstall:
-check: staged-install
+check: check-regress
+check-unit:
+check-regress: staged-install
 	$(MAKE) -C core check
 ifeq ($(HAVE_SFCGAL),yes)
 	$(MAKE) -C sfcgal check
Modified: trunk/topology/Makefile.in
--- trunk/topology/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/topology/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -133,10 +133,12 @@
 uninstall_topology.sql: topology.sql ../utils/create_undef.pl
 	$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
-check-local: topology.sql
-	$(MAKE) -C test check
+check-unit:
-check: check-local
+check-regress: topology.sql
+	$(MAKE) -C test $@
 distclean: clean
 	rm -f Makefile test/Makefile
Modified: trunk/topology/test/Makefile.in
--- trunk/topology/test/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/topology/test/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -84,7 +84,9 @@
 TESTS_EXPECTED = $(TESTS:.sql=_expected)
-check: topo_predicates.sql load_topology.sql load_topology-4326.sql $(TESTS) $(TESTS_EXPECTED)
+check-regress: topo_predicates.sql load_topology.sql load_topology-4326.sql $(TESTS) $(TESTS_EXPECTED)
 	$(MAKE) -C ../../regress staged-install
 	$(PERL) ../../regress/run_test.pl --topology $(RUNTESTFLAGS) $(TESTS)
Modified: trunk/utils/Makefile.in
--- trunk/utils/Makefile.in	2019-08-22 12:13:42 UTC (rev 17757)
+++ trunk/utils/Makefile.in	2019-08-22 13:36:59 UTC (rev 17758)
@@ -77,4 +77,4 @@
 	rm -f Makefile
 # And there's nothing to check
-check:
