[postgis-tickets] [PostGIS] #4482: Missing Windows dependencies
PostGIS trac at osgeo.org
Sat Aug 24 21:48:09 PDT 2019
  Reporter:  joshuabogue            |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.5.3
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:                         |   Keywords:  windows builds
Changes (by robe):
 * milestone:  PostGIS 2.5.4 => PostGIS 2.5.3
Comment:
 I've pushed out a 2.5.3 PostGIS release on stackbuilder for 64-bit
 PostgreSQL 9.6, 10,11 which has curl built with the new ssl libraries.
 That should fix the issue.
 Still working on the 32-bit builds and 9.5.  I'll close after I've
 packaged those. https://postgis.net/windows_downloads/
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4482#comment:6>
