[postgis-tickets] [SCM] PostGIS branch master updated. e18a0b84dfa0995f3f78d52227aceb3b3e494a52
rmrodriguez at carto.com rmrodriguez at carto.com
Wed Dec 11 01:42:07 PST 2019
The commit message is referencing a wrong PR. The one closed was
https://github.com/postgis/postgis/pull/514
On Wed, Dec 11, 2019 at 10:38 AM <git at osgeo.org> wrote:
> This is an automated email from the git hooks/post-receive script. It was
> generated because a ref change was pushed to the repository containing
> the project "PostGIS".
> The branch, master has been updated
>        via  e18a0b84dfa0995f3f78d52227aceb3b3e494a52 (commit)
>       from  722e45c2dd5c8cc367f0093bc750724687ca2273 (commit)
> Those revisions listed above that are new to this repository have
> not appeared on any other notification email; so we list those
> revisions in full, below.
> - Log -----------------------------------------------------------------
> commit e18a0b84dfa0995f3f78d52227aceb3b3e494a52
> Author: Yuri Astrakhan <YuriAstrakhan at gmail.com>
> Date:   Wed Nov 13 21:41:49 2019 -0500
>     Add ST_TileEnvelope margin argument
>     Increase or decrease if negative tile envelope by a given margin
>     percentage. The result is always clipped according to bounds argument.
>     Closes #4601
>     Closes https://github.com/CartoDB/cartodb/pull/15169
>     Signed-off-by: Raúl Marín <git at rmr.ninja>
> diff --git a/NEWS b/NEWS
> index 72a22b0..dea80ab 100644
> --- a/NEWS
> +++ b/NEWS
> @@ -8,8 +8,10 @@ PostGIS 3.1.0
>  * Breaking changes *
>    - #4577, Drop support for PostgreSQL 9.5 (Raúl Marín)
>    - #4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)
> +  - #4601, ST_TileEnvelope signature changed.
>  * New features *
> +  - #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
>  * Enhancements *
>    - #4539, Unify libm includes (Raúl Marín)
> diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
> index 87ef1ea..4b8e9a7 100644
> --- a/doc/reference_constructor.xml
> +++ b/doc/reference_constructor.xml
> @@ -771,6 +771,7 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
>                         <paramdef><type>integer</type> <parameter>tileX</parameter></paramdef>
>                         <paramdef><type>integer</type> <parameter>tileY</parameter></paramdef>
>                         <paramdef choice="opt"><type>geometry</type> <parameter>bounds=SRID=3857;LINESTRING(-20037508.342789 -20037508.342789,20037508.342789 20037508.342789)</parameter></paramdef>
> +                       <paramdef choice="opt"><type>float</type> <parameter>margin=0.0</parameter></paramdef>
>                   </funcprototype>
>                  </funcsynopsis>
>                 </refsynopsisdiv>
> @@ -780,7 +781,10 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
>                         <para>Creates a rectangular Polygon in <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> (SRID:3857) using the <ulink url="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</ulink>. By default, the bounds are the in EPSG:3857 using the standard range of the Web Mercator system (-20037508.342789, 20037508.342789). The optional bounds parameter can be used to generate envelopes for any tiling scheme: provide a geometry that has the SRID and extent of the initial "zoom level zero" square within which the tile system is to be inscribed.</para>
> +                       <para>The optional margin parameter can be used to grow a tile by the given percentage, e.g. margin=0.125 grows the tile by 12.5%, which is equivalent to buffer=512 when extent is 4096, as used in <xref linkend="ST_AsMVTGeom" />. This is useful to create a tile buffer -- to include data lying outside of the tile's visible area, but whose existence affects current tile's rendering. For example, a city name (a geopoint) could be near an edge of a tile, but the text would need to render on two tiles, even though the geopoint is located in the visible area of just one tile. Using an expanded tile in a search would include the city geopoint for both tiles. Use negative value to shrink the tile instead. Values less than -0.5 are prohibited because that would eliminate the tile completely. Do not use margin with ST_AsMVTGeom(). See example in <xref linkend="ST_AsMVT" />.</para>
>                         <para>Availability: 3.0</para>
> +                       <para>Enhanced in 3.1: Added margin parameter.</para>
>                 </refsection>
> @@ -794,7 +798,7 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
>  SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4326) ) );
> -                      st_astext
> +                      st_astext
>   POLYGON((-135 45,-135 67.5,-90 67.5,-90 45,-135 45))
>  </programlisting>
> diff --git a/doc/reference_output.xml b/doc/reference_output.xml
> index 30a87c8..f64b992 100644
> --- a/doc/reference_output.xml
> +++ b/doc/reference_output.xml
> @@ -1189,9 +1189,9 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
>                 <title>Examples</title>
>                 <programlisting><![CDATA[WITH mvtgeom AS
> -  SELECT ST_AsMVTGeom(geom, ST_TileEnvelope(12,513,412)) AS geom, name, description
> +  SELECT ST_AsMVTGeom(geom, ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64) AS geom, name, description
>    FROM points_of_interest
> -  WHERE ST_Intersects(geom, ST_TileEnvelope(12,513,412)
> +  WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
>  SELECT ST_AsMVT(mvtgeom.*)
>  FROM mvtgeom;
> diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
> index adc6d3f..89a395b 100644
> --- a/postgis/lwgeom_functions_basic.c
> +++ b/postgis/lwgeom_functions_basic.c
> @@ -2051,6 +2051,7 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
>         double tileGeoSizeX, tileGeoSizeY;
>         double boundsWidth, boundsHeight;
>         double x1, y1, x2, y2;
> +       double margin;
>         /* This is broken, since 3857 doesn't mean "web mercator", it means
>            the contents of the row in spatial_ref_sys with srid = 3857.
>            For practical purposes this will work, but in good implementation
> @@ -2070,6 +2071,11 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
>                 elog(ERROR, "%s: Empty bounds", __func__);
>         srid = gserialized_get_srid(bounds);
> +       margin = PG_GETARG_FLOAT8(4);
> +       /* shrinking by more than 50% would eliminate the tile outright */
> +       if (margin < -0.5)
> +               elog(ERROR, "%s: Margin must not be less than -50%%, margin=%f", __func__, margin);
>         boundsWidth  = bbox.xmax - bbox.xmin;
>         boundsHeight = bbox.ymax - bbox.ymin;
>         if (boundsWidth <= 0 || boundsHeight <= 0)
> @@ -2088,10 +2094,29 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
>         tileGeoSizeX = boundsWidth / worldTileSize;
>         tileGeoSizeY = boundsHeight / worldTileSize;
> -       x1 = bbox.xmin + tileGeoSizeX * (x);
> -       x2 = bbox.xmin + tileGeoSizeX * (x+1);
> -       y1 = bbox.ymax - tileGeoSizeY * (y+1);
> -       y2 = bbox.ymax - tileGeoSizeY * (y);
> +        * 1 margin (100%) is the same as a single tile width
> +        * if the size of the tile with margins span more than the total number of tiles,
> +        * reset x1/x2 to the bounds
> +       if ((1 + margin * 2) > worldTileSize)
> +               x1 = bbox.xmin;
> +               x2 = bbox.xmax;
> +       else
> +               x1 = bbox.xmin + tileGeoSizeX * (x - margin);
> +               x2 = bbox.xmin + tileGeoSizeX * (x + 1 + margin);
> +       y1 = bbox.ymax - tileGeoSizeY * (y + 1 + margin);
> +       y2 = bbox.ymax - tileGeoSizeY * (y - margin);
> +       /* Clip y-axis to the given bounds */
> +       if (y1 < bbox.ymin) y1 = bbox.ymin;
> +       if (y2 > bbox.ymax) y2 = bbox.ymax;
>         PG_RETURN_POINTER(
>                 geometry_serialize(
> diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
> index 9ad89be..4727552 100644
> --- a/postgis/postgis.sql.in
> +++ b/postgis/postgis.sql.in
> @@ -1686,7 +1686,8 @@ CREATE OR REPLACE FUNCTION ST_MakeEnvelope(float8, float8, float8, float8, integ
>         _COST_LOW;
>  -- Availability: 3.0.0
> -CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789 -20037508.342789, 20037508.342789 20037508.342789)'::geometry)
> +-- Changed: 3.1.0 - add margin=0.0 parameter
> +CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789 -20037508.342789, 20037508.342789 20037508.342789)'::geometry, margin float8 DEFAULT 0.0)
>         RETURNS geometry
>         AS 'MODULE_PATHNAME', 'ST_TileEnvelope'
>         LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
> @@ -2853,7 +2854,7 @@ BEGIN
>                         THEN
>                                 --force install in same schema as postgis only if postgis extension is installed
>                                 IF rec.name NOT IN('postgis', 'postgis_topology', 'postgis_tiger_geocoder') AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
> -                                       sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
> +                                       sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
>                                         || quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
>                                 ELSE
>                                         sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged;';
> diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
> index c709b05..8780c90 100644
> --- a/postgis/postgis_before_upgrade.sql
> +++ b/postgis/postgis_before_upgrade.sql
> @@ -187,6 +187,12 @@ SELECT _postgis_drop_function_if_needed
>         'GeometryA geometry, GeometryB geometry'
> +-- FUNCTION st_tileenvelope added a new default argument in 3.1
> +SELECT _postgis_drop_function_if_needed
> +    'st_tileenvelope',
> +    'zoom integer, x integer, y integer, bounds geometry DEFAULT ''0102000020110F00000200000052107C45F81B73C152107C45F81B73C152107C45F81B734152107C45F81B7341''::geometry'
>  -- FUNCTION st_askml changed to add defaults in 3.0 / r17357
>  -- These signatures were superseeded
> diff --git a/regress/core/regress.sql b/regress/core/regress.sql
> index 78ab69b..6f5eea3 100644
> --- a/regress/core/regress.sql
> +++ b/regress/core/regress.sql
> @@ -274,7 +274,17 @@ select '232', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-100, -100, 100
>  select '233', ST_AsEWKT(ST_TileEnvelope(4, 15, 15, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
>  select '234', ST_AsEWKT(ST_TileEnvelope(4, 0, 0, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
>  select '235', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-200, -100, 200, 100, 0)));
> +select '236', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => 0.1));
> +select '237', ST_AsEWKT(ST_TileEnvelope(1, 0, 0, margin => 0.1));
> +select '238', ST_AsEWKT(ST_TileEnvelope(2, 1, 3, margin => 0.5));
> +select '239', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.5));
> +select '240', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.51));
> +select '241', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.4));
> +select '250', ST_AsEWKT(ST_TileEnvelope(10,300,387));
> +select '251', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 0.1));
> +select '252', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 0.5));
> +select '253', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 2));
> +select '254', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => -0.3));
>  -- Drop test table
>  DROP table test;
> diff --git a/regress/core/regress_expected b/regress/core/regress_expected
> index d82fe5c..4b3d7bc 100644
> --- a/regress/core/regress_expected
> +++ b/regress/core/regress_expected
> @@ -203,3 +203,14 @@ ERROR:  ST_TileEnvelope: Invalid tile y value, 1
>  233|POLYGON((87.5 -100,87.5 -87.5,100 -87.5,100 -100,87.5 -100))
>  234|POLYGON((-100 87.5,-100 100,-87.5 100,-87.5 87.5,-100 87.5))
>  235|POLYGON((0 -12.5,0 0,25 0,25 -12.5,0 -12.5))
> +236|SRID=3857;POLYGON((-20037510 -20037510,-20037510 20037510,20037510 20037510,20037510 -20037510,-20037510 -20037510))
> +237|SRID=3857;POLYGON((-22041261 -2003751,-22041261 20037510,2003751 20037510,2003751 -2003751,-22041261 -2003751))
> +238|SRID=3857;POLYGON((-15028132.5 -20037510,-15028132.5 -5009377.5,5009377.5 -5009377.5,5009377.5 -20037510,-15028132.5 -20037510))
> +239|SRID=3857;POLYGON((0 0,0 0,0 0,0 0,0 0))
> +ERROR:  ST_TileEnvelope: Margin must not be less than -50%, margin=-0.510000
> +241|SRID=3857;POLYGON((-4007502 -4007502,-4007502 4007502,4007502 4007502,4007502 -4007502,-4007502 -4007502))
> +250|SRID=3857;POLYGON((-8296781.484375 4852834.453125,-8296781.484375 4891970.21484375,-8257645.72265625 4891970.21484375,-8257645.72265625 4852834.453125,-8296781.484375 4852834.453125))
> +251|SRID=3857;POLYGON((-8300695.06054688 4848920.87695312,-8300695.06054688 4895883.79101562,-8253732.14648438 4895883.79101562,-8253732.14648438 4848920.87695312,-8300695.06054688 4848920.87695312))
> +252|SRID=3857;POLYGON((-8316349.36523438 4833266.57226562,-8316349.36523438 4911538.09570312,-8238077.84179688 4911538.09570312,-8238077.84179688 4833266.57226562,-8316349.36523438 4833266.57226562))
> +253|SRID=3857;POLYGON((-8375053.0078125 4774562.9296875,-8375053.0078125 4970241.73828125,-8179374.19921875 4970241.73828125,-8179374.19921875 4774562.9296875,-8375053.0078125 4774562.9296875))
> +254|SRID=3857;POLYGON((-8285040.75585938 4864575.18164062,-8285040.75585938 4880229.48632812,-8269386.45117188 4880229.48632812,-8269386.45117188 4864575.18164062,-8285040.75585938 4864575.18164062))
> Summary of changes:
>  NEWS                               |  2 ++
>  doc/reference_constructor.xml      |  6 +++++-
>  doc/reference_output.xml           |  4 ++--
>  postgis/lwgeom_functions_basic.c   | 33 +++++++++++++++++++++++++++++----
>  postgis/postgis.sql.in             |  5 +++--
>  postgis/postgis_before_upgrade.sql |  6 ++++++
>  regress/core/regress.sql           | 12 +++++++++++-
>  regress/core/regress_expected      | 11 +++++++++++
>  8 files changed, 69 insertions(+), 10 deletions(-)
> hooks/post-receive
> PostGIS
> postgis-tickets mailing list
> postgis-tickets at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
Raúl Marín Rodríguez
carto.com
