[postgis-tickets] [SCM] PostGIS branch master updated. 21451108484d163e0b535bdfc5dcc7c07a0c853e
Wed Dec 11 17:57:46 PST 2019
the project "PostGIS".
       via  21451108484d163e0b535bdfc5dcc7c07a0c853e (commit)
      from  d03a5dfb92e5aa4ba757c7357a873289d46deae9 (commit)
revisions in full, below.
commit 21451108484d163e0b535bdfc5dcc7c07a0c853e
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Dec 11 20:57:40 2019 -0500
    Goofy fix that bessie seems to be happy with.  Closes #4572
diff --git a/postgis/sqldefines.h.in b/postgis/sqldefines.h.in
index e23a88e..7f46244 100644
--- a/postgis/sqldefines.h.in
+++ b/postgis/sqldefines.h.in
@@ -44,7 +44,13 @@
 #define _POSTGIS_SQL_SELECT_POSTGIS_PGSQL_VERSION 'SELECT ''@POSTGIS_PGSQL_VERSION@''::text AS version'
 #ifdef POSTGIS_REVISION
-#define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@ '::text || $rev$POSTGIS_REVISION$rev$::text AS version $$
+* Insert the PostGIS revision.  This is immensely goofy because FreeBSD doesn't recognized
+* PostGIS_REVISION as a variable if anything like ` or $rev$ (sql dollar quoting) abutts it so we need to leave a space on both sides
+* which means we need to then trim it to get rid of the extra spaces we added.
+* Maybe someone smarter can come up with a less goofy solution that makes all OS happy
+#define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT trim('@POSTGIS_SCRIPTS_VERSION@'::text || $rev$ POSTGIS_REVISION $rev$) AS version $$
 #else
 #define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@'::text AS version $$
 #endif
Summary of changes:
 postgis/sqldefines.h.in | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
