[postgis-tickets] [SCM] PostGIS branch master updated. 4dc5be03ba4864446738ff3db2a400e4fddc24e6
Wed Dec 18 12:36:05 PST 2019
the project "PostGIS".
       via  4dc5be03ba4864446738ff3db2a400e4fddc24e6 (commit)
      from  cf616ece98af703489371140229b079f38fdf3ec (commit)
revisions in full, below.
commit 4dc5be03ba4864446738ff3db2a400e4fddc24e6
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Dec 18 21:35:32 2019 +0100
    Add sections for 2.5 releases published prior to 3.0.0
diff --git a/NEWS b/NEWS
index 5aa9c98..da28b3d 100644
--- a/NEWS
+++ b/NEWS
@@ -162,6 +162,65 @@ and GEOS 3.8.0
   - #4509, Update geocoder for tiger 2019 (Regina Obe)
+PostGIS 2.5.3
+2019/08/11
+ * Bug fixes *
+  - #4348, ST_AsMVTGeom (GEOS): Enforce validation at all times (Raúl Marín)
+  - #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
+  - #4326, Fix circular arc distance calculation (Paul Ramsey)
+  - #4380, Simple TIN support to allow viz in QGIS (Paul Ramsey)
+  - #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
+  - #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
+  - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
+  - #4440, Internal type lookups fail over FDW (Paul Ramsey)
+  - #4445, Fix bug in lwgeom_le (Raúl Marín)
+  - #4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)
+  - #4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)
+  - #4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)
+  - #4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)
+  - #4461, ST_AsTWKB doesn't always remove duplicate points (Nicklas Avén)
+  - #4459, Fix ST_Subdivide crash on intermediate EMPTY (Darafei Praliaskouski)
+  - #4470, ST_GeomFromGeoJSON crash on empty rings (Darafei Praliaskouski)
+  - #4420, update path does not exists for address_standardizer extension (Regina Obe)
+PostGIS 2.5.2
+2019/03/11
+ * Bug fixes *
+  - #4231, Support for PostgreSQL 12dev (remove use of pg_constraint.consrc)
+           (Regina Obe, Laurenz Albe)
+  - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
+  - #4249, Fix undefined behaviour in raster intersection (Raúl Marín)
+  - #4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)
+  - #4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)
+  - #4139, Make mixed-dimension ND index build tree correctly.
+  WARNING: REINDEX your ND index on tables that have records with different M/Z
+           dimensions for &&& operator to work predictably.
+           (Darafei Praliaskouski, Arthur Lesuisse, Andrew Gierth, Raúl Marín)
+  - #4262, Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)
+  - #4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
+  - #4276, ST_AsGeoJSON documentation refresh (Darafei Praliaskouski)
+  - #4273, Tighter parsing of WKT (Paul Ramsey)
+  - #4292, ST_AsMVT: parse JSON numeric values with decimals as doubles (Raúl Marín)
+  - #4300, ST_AsMVTGeom: Always return the simplest geometry (Raúl Marín)
+  - #4301, ST_Subdivide: fix endless loop on coordinates near coincident to bounds
+           (Darafei Praliaskouski)
+  - #4261, Use AccessShareLock in spatial_index_read_extent (Paul Ramsey)
+  - #4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)
+  - #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
+  - #4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)
+  - #4290, More robust geography distance (Paul Ramsey)
+  - #4283, Avoid final point duplicates for circle stroking (Paul Ramsey)
+  - #4314, ST_ClipByBox2D: Do not throw when the geometry is invalid (Raúl Marín)
+  - #4313, #4307, PostgreSQL 12 compatibility (Laurenz Albe, Raúl Marín)
+  - #4290, Schema qualify geometry casts in raster functions (Regina Obe)
+  - #4086, Constraint violation loading tiger_data (zcta5 geometry type) (Regina Obe)
 PostGIS 2.5.0
 2018/09/23
 WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
Summary of changes:
 NEWS | 59 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 59 insertions(+)
hooks/post-receive
