[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 661f127ceedbd3733a841f98901bda9c89c96158
Thu Dec 19 01:48:21 PST 2019
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  661f127ceedbd3733a841f98901bda9c89c96158 (commit)
      from  dbda007059161f849144d25543f061f81c2dc499 (commit)
revisions in full, below.
commit 661f127ceedbd3733a841f98901bda9c89c96158
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Dec 19 10:47:13 2019 +0100
    Add --ticket-refs option to utils/check_news.sh
    It's off by default because it doesn't pass at the moment
    (missing ref to ticket #1003)
diff --git a/utils/check_news.sh b/utils/check_news.sh
index bac8f6f..cf13fed 100755
--- a/utils/check_news.sh
+++ b/utils/check_news.sh
@@ -2,24 +2,46 @@
 RD=`dirname $0`/.. # root source dir
+usage() {
+  echo "Usage: $0 [-v] [--ticket-refs] [<sourcedir>]"
+  echo "Sourcedir defaults to one directory above this script"
+### COMMAND LINE PARSING
 VERBOSE=no
+TICKET_REFS=no
+while [ $# -gt 0 ]; do
+  if [ "$1" = "--help" ]; then
+    usage
+    exit 0
+  elif [ "$1" = "-v" ]; then
+    VERBOSE=yes
+  elif [ "$1" = "--ticket-refs" ]; then
+    TICKET_REFS="yes"
+  else
+    echo "ERROR: unrecognized extra argument $1" >&2
+    usage >&2
+    exit 1
+  fi
+  shift
+done
-if test "$1" = "-v"; then
-  VERBOSE=yes
-fi
+cd ${RD}
 # Extract dates from NEWS file and check they
 # are sorted correctly
 pdate=$(date '+%Y/%m/%d') # most recent timestamp
 prel=Unreleased
-grep -B1 '^[0-9]\{4\}/[0-9]\{2\}/[0-9]\{2\}' ${RD}/NEWS |
+grep -B1 '^[0-9]\{4\}/[0-9]\{2\}/[0-9]\{2\}' NEWS |
   while read rel; do
     read date
     read sep
     ts=$( date -d "${date}" '+%s' )
     pts=$( date -d "${pdate}" '+%s' )
     if test $ts -gt $pts; then
-      echo "${rel} (${date}) appears after earlier published release ${prel}"
+      echo "FAIL: ${rel} (${date}) appears after ${prel} (${pdate})" >&2
       exit 1
     fi
     if test "${VERBOSE}" = yes; then
@@ -28,7 +50,28 @@ grep -B1 '^[0-9]\{4\}/[0-9]\{2\}/[0-9]\{2\}' ${RD}/NEWS |
     pts=${ts}
     prel=${rel}
   done
+test $? = 0 || exit 1
+echo "PASS: NEWS file entries are in good order"
-echo "NEWS file entries are in good order"
+if test "${TICKET_REFS}" = "yes"; then
+  # If git is available, check that every ticket reference in
+  # commit logs is also found in the NEWS file
+  if which git > /dev/null && test -e .git; then
+    git log --grep '#[0-9]\+' |
+      grep -i ' #[0-9]\+' |
+      sed -En 's|#([0-9]+)|\a#\1\n|;/\n/!b;s|.*\a||;P;D' |
+      sort -u |
+    while read ref; do
+      if ! grep -qw '${ref}' NEWS; then
+        echo "FAIL: Reference to commit-logged ticket ref ${ref} missing from NEWS" >&2
+        exit 1
+      fi
+    done
+    test $? = 0 || exit 1
+    echo "PASS: All ticket references in commits log found in NEWS"
+  else
+    echo "SKIP: GIT history cannot be checked (missing git or missing ${RD}/.git)"
+  fi
+fi
 exit 0
Summary of changes:
 utils/check_news.sh | 55 +++++++++++++++++++++++++++++++++++++++++++++++------
 1 file changed, 49 insertions(+), 6 deletions(-)
hooks/post-receive
