[postgis-tickets] r17233 - Use pkg-config to improve dependency detection
Raul raul at rmr.ninja
Mon Feb 11 08:41:36 PST 2019
Author: algunenano
Date: 2019-02-11 08:41:35 -0800 (Mon, 11 Feb 2019)
New Revision: 17233
Removed:
   trunk/raster/macros/
   trunk/configure.ac
   trunk/extensions/address_standardizer/Makefile.in
   trunk/liblwgeom/cunit/cu_geodetic.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwin_geojson.c
   trunk/postgis/lwgeom_in_geojson.c
   trunk/postgis_config.h.in
Closes #4324
Closes https://github.com/postgis/postgis/pull/372
Modified: trunk/configure.ac
--- trunk/configure.ac	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/configure.ac	2019-02-11 16:41:35 UTC (rev 17233)
@@ -314,14 +314,23 @@
 dnl information to be passed in if required.
 dnl ===========================================================================
+CUNIT_CPPFLAGS=""
 CUNIT_LDFLAGS=""
-AC_CHECK_HEADER([CUnit/CUnit.h], [
-	CUNIT_CPPFLAGS="$CPPFLAGS"
-	AC_CHECK_LIB([cunit], [CU_initialize_registry], [CUNIT_LDFLAGS="$LDFLAGS -lcunit"], [AC_MSG_WARN([could not locate CUnit required for unit tests])])
-	AC_MSG_WARN([could not locate CUnit required for unit tests])
+if test ! -z "$PKG_CONFIG"; then
+	PKG_CHECK_MODULES([CUNIT], [cunit],
+			CUNIT_CPPFLAGS="$CPPFLAGS $CUNIT_CFLAGS"
+			CUNIT_LDFLAGS="$LDFLAGS $CUNIT_LIBS"
+		[AC_MSG_WARN([could not locate CUnit required for unit tests])])
+else
+	AC_CHECK_HEADER([CUnit/CUnit.h],
+			CUNIT_CPPFLAGS="$CPPFLAGS"
+			AC_CHECK_LIB([cunit], [CU_initialize_registry], [CUNIT_LDFLAGS="$LDFLAGS -lcunit"], [AC_MSG_WARN([could not locate CUnit required for unit tests])])
+fi
 AC_SUBST([CUNIT_CPPFLAGS])
 AC_SUBST([CUNIT_LDFLAGS])
@@ -693,8 +702,8 @@
 fi
 dnl Extract the linker and include flags
-GEOS_LDFLAGS=`$GEOSCONFIG --ldflags`
-GEOS_CPPFLAGS=-I`$GEOSCONFIG --includes`
+GEOS_LDFLAGS=`$GEOSCONFIG --clibs`
+GEOS_CPPFLAGS=`$GEOSCONFIG --cflags`
 AC_SUBST([GEOS_LDFLAGS])
 AC_SUBST([GEOS_CPPFLAGS])
@@ -727,7 +736,6 @@
 	[SFCGAL_CONFIG="$withval"],
 	[with_sfcgal=auto])
-HAVE_SFCGAL="no"
 if test "x$with_sfcgal" != "xno"; then
   if test "x$with_sfcgal" = "xyes" -o "x$with_sfcgal" = "xauto"; then
@@ -736,7 +744,7 @@
 	if test -x "$SFCGAL_CONFIG"; then
 		SFCGAL_VERSION=`$SFCGAL_CONFIG --version` || AC_MSG_ERROR([cannot determine sfcgal version (tried with $SFCGAL_CONFIG --version)])
 		SFCGAL_LDFLAGS=`$SFCGAL_CONFIG --libs`
-		SFCGAL_CPPFLAGS=`$SFCGAL_CONFIG --cflags`" -DHAVE_SFCGAL"
+		SFCGAL_CPPFLAGS=`$SFCGAL_CONFIG --cflags`
 		SFCGAL_MAJOR_VERSION=`echo $SFCGAL_VERSION | cut -d. -f1 | sed 's/[[^0-9]]//g'`
 		SFCGAL_MINOR_VERSION=`echo $SFCGAL_VERSION | cut -d. -f2 | sed 's/[[^0-9]]//g'`
@@ -753,6 +761,7 @@
 		else
         		SFCGAL="sfcgal"
 			HAVE_SFCGAL="yes"
+                        AC_DEFINE([HAVE_SFCGAL], [1], [Define to 1 if sfcgal is being built])
 		fi
 		if test ! "$POSTGIS_SFCGAL_VERSION" -ge 10301; then
 			AC_MSG_ERROR([PostGIS requires SFCGAL >= 1.3.1 (found $SFCGAL_VERSION)])
@@ -772,7 +781,6 @@
 AC_SUBST([HAVE_SFCGAL])
 dnl Detect gettext
@@ -810,7 +818,18 @@
 LDFLAGS="$LDFLAGS_SAVE"
 CFLAGS="$CFLAGS_SAVE"
+dnl Detect if pkg-config installed
+dnl ===========================================================================
+# check for pkg-config
+PKG_PROG_PKG_CONFIG
+if test -z "$PKG_CONFIG"; then
+   AC_MSG_WARN([Cannot find pkg-config, make sure it is installed in your PATH])
+fi
 dnl Detect the version of PROJ.4 installed
@@ -827,14 +846,20 @@
 			AC_MSG_RESULT([Using user-specified proj directory: $PROJDIR])
 			dnl Add the include directory to PROJ_CPPFLAGS
-			PROJ_CPPFLAGS="-I$PROJDIR/include -DACCEPT_USE_OF_DEPRECATED_PROJ_API_H=1"
-			PROJ_LDFLAGS="-L$PROJDIR/lib"
+			PROJ_CPPFLAGS="-I$PROJDIR/include"
+			PROJ_LDFLAGS="-L$PROJDIR/lib -lproj"
 		else
 			AC_MSG_ERROR([the --with-projdir directory "$PROJDIR" cannot be found])
 		fi
 	fi
+elif test ! -z "$PKG_CONFIG"; then
+	PKG_CHECK_MODULES([PROJ], [proj], [
+                PROJ_CPPFLAGS="$PROJ_CFLAGS"
+                PROJ_LDFLAGS="$PROJ_LIBS"
 fi
 dnl Check that we can find the proj_api.h header file
 CPPFLAGS_SAVE="$CPPFLAGS"
 CPPFLAGS="$PROJ_CPPFLAGS"
@@ -849,8 +874,10 @@
 AC_SUBST([POSTGIS_PROJ_VERSION])
 CPPFLAGS="$CPPFLAGS_SAVE"
-AC_SUBST([PROJ_CPPFLAGS])
-AC_SUBST([PROJ_LDFLAGS])
+dnl For PROJ 6 add the ACCEPT_USE_OF_DEPRECATED_PROJ_API_H definition
+if test "$POSTGIS_PROJ_VERSION" -ge 60 && test "$POSTGIS_PROJ_VERSION" -lt 70; then
+    AC_DEFINE([ACCEPT_USE_OF_DEPRECATED_PROJ_API_H], [1], [Define to use the old PROJ API])
+fi
 dnl Ensure that we are using PROJ >= 4.6.0 (requires pj_set_searchpath)
 if test ! "$POSTGIS_PROJ_VERSION" -ge 46; then
@@ -857,6 +884,9 @@
 	AC_MSG_ERROR([PostGIS requires PROJ >= 4.6.0])
 fi
+AC_SUBST([PROJ_CPPFLAGS])
+AC_SUBST([PROJ_LDFLAGS])
 dnl Ensure we can link against libproj
 LIBS_SAVE="$LIBS"
 LIBS="$PROJ_LDFLAGS"
@@ -880,63 +910,57 @@
 if test "$CHECK_JSON" != "no"; then
-AC_ARG_WITH([jsondir],
-	[AS_HELP_STRING([--with-jsondir=PATH], [specify the json-c installation directory])],
-	[JSONDIR="$withval"], [JSONDIR=])
+    AC_ARG_WITH([jsondir],
+            [AS_HELP_STRING([--with-jsondir=PATH], [specify the json-c installation directory])],
+            [JSONDIR="$withval"], [JSONDIR=])
-if test ! "x$JSONDIR" = "x"; then
-	dnl Make sure that the directory exists
-	if test "x$JSONDIR" = "xyes"; then
-		AC_MSG_ERROR([you must specify a parameter to --with-jsondir, e.g. --with-jsondir=/path/to])
-	else
-		AC_MSG_RESULT([Using user-specified json-c directory: $JSONDIR])
+    if test ! "x$JSONDIR" = "x"; then
+            dnl Make sure that the directory exists
+            if test "x$JSONDIR" = "xyes"; then
+                    AC_MSG_ERROR([you must specify a parameter to --with-jsondir, e.g. --with-jsondir=/path/to])
+            else
+                    AC_MSG_RESULT([Using user-specified json-c directory: $JSONDIR])
-		dnl Add the include directory to JSON_CPPFLAGS
-		JSON_CPPFLAGS="-I$JSONDIR/include"
-		JSON_LDFLAGS="-L$JSONDIR/lib"
-	fi
-fi
+                    AC_CHECK_FILE("$JSONDIR/include/json-c/json.h",
+                                    JSON_CPPFLAGS="-I$JSONDIR/include/json-c"
+                                    AC_CHECK_LIB([json-c], [json_object_get], [HAVE_JSON_C=yes; JSON_LDFLAGS="${JSON_LDFLAGS} -ljson-c"])
+                                    AC_CHECK_FILE("$JSONDIR/include/json/json.h",
+                                        JSON_CPPFLAGS="-I$JSONDIR/include/json"
+                                        AC_CHECK_LIB([json], [json_object_get], [HAVE_JSON=yes; JSON_LDFLAGS="${JSON_LDFLAGS} -ljson"])
+                                    [AC_MSG_ERROR([Could not find header: json.h])])
+            fi
+    elif test ! -z "$PKG_CONFIG"; then
+	PKG_CHECK_MODULES([JSONC], [json-c], [
+                HAVE_JSON_C=yes
+                JSON_CPPFLAGS="$JSONC_CFLAGS"
+                JSON_LDFLAGS="$JSONC_LIBS"
+    fi
-dnl Check that we can find the json/json.h header file
-CPPFLAGS_SAVE="$CPPFLAGS"
-CPPFLAGS="$JSON_CPPFLAGS"
-AC_CHECK_HEADER([json/json.h], [HAVE_JSON=yes], [
-  AC_CHECK_HEADER([json-c/json.h], [HAVE_JSON=yes; HAVE_JSON_C=yes], [])
-CPPFLAGS="$CPPFLAGS_SAVE"
+    if test "$HAVE_JSON" = "yes"; then
+            AC_DEFINE([HAVE_LIBJSON], 1, [Define to 1 if libjson is present])
+    fi
+    if test "$HAVE_JSON_C" = "yes"; then
+            AC_DEFINE([HAVE_LIBJSON_C], 1, [Define to 1 if libjson resides in a json-c subdir])
+            HAVE_JSON=yes
+    fi
-dnl Ensure we can link against libjson
-LIBS_SAVE="$LIBS"
-LIBS="$JSON_LDFLAGS"
-AC_CHECK_LIB([json-c], [json_object_get], [HAVE_JSON=yes; JSON_LDFLAGS="${JSON_LDFLAGS} -ljson-c"], [
-  AC_CHECK_LIB([json], [json_object_get], [HAVE_JSON=yes; JSON_LDFLAGS="${JSON_LDFLAGS} -ljson"], [], [])
-LIBS="$LIBS_SAVE"
+    AC_SUBST([JSON_CPPFLAGS])
+    AC_SUBST([JSON_LDFLAGS])
+    AC_SUBST([HAVE_JSON])
+    AC_SUBST([HAVE_LIBJSON_C])
-if test "$HAVE_JSON" = "yes"; then
-	AC_DEFINE([HAVE_LIBJSON], 1, [Define to 1 if libjson is present])
 fi
-if test "$HAVE_JSON_C" = "yes"; then
-	AC_DEFINE([HAVE_LIBJSON_C], 1, [Define to 1 if libjson resides in a json-c subdir])
-fi
-AC_SUBST([JSON_CPPFLAGS])
-AC_SUBST([JSON_LDFLAGS])
-AC_SUBST([HAVE_JSON])
-fi
-dnl Detect if pkg-config installed
-dnl ===========================================================================
-# check for pkg-config
-PKG_PROG_PKG_CONFIG
-if test -z "$PKG_CONFIG"; then
-   AC_MSG_WARN([Cannot find pkg-config, make sure it is installed in your PATH])
-fi
 dnl Detect if protobuf-c installed
@@ -1111,16 +1135,15 @@
                     [Disable the address_standardizer extension])],
+HAVE_PCRE=no
+ADDRESS_STANDARDIZER=""
 if test "x$with_address_standardizer" != "xno"; then
     dnl Detect the version of PCRE installed
-    LDFLAGS="$LDFLAGS_SAVE"
-    CFLAGS="$CFLAGS_SAVE"
-    CHECK_PCRE=yes
-    HAVE_PCRE=no
-    ADDRESS_STANDARDIZER="address_standardizer"
     AC_ARG_WITH([pcredir],
         [AS_HELP_STRING([--with-pcredir=PATH], [specify the PCRE installation directory])],
         [PCREDIR="$withval"], [PCREDIR=""])
@@ -1133,43 +1156,42 @@
             if test -d "$PCREDIR"; then
                 AC_MSG_RESULT([Using user-specified PCRE directory: $PCREDIR])
-                dnl Add the include directory to PCRE_CPPFLAGS
-                PCRE_CPPFLAGS="-I$PCREDIR/include"
-                PCRE_LDFLAGS="-L$PCREDIR/lib"
+                AC_CHECK_FILE("$PCREDIR/include/pcre.h",
+                            PCRE_CPPFLAGS="-I$PCREDIR/include"
+                            PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
+                            HAVE_PCRE=yes
+                            ADDRESS_STANDARDIZER="address_standardizer"
+                        [AC_MSG_ERROR([Could not find header: pcre.h])])
             else
                 AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
             fi
         fi
+	PKG_CHECK_MODULES([PCRE], [libpcre], [
+                PCRE_CPPFLAGS="$PCRE_CFLAGS"
+                PCRE_LDFLAGS="$PCRE_LIBS"
+                HAVE_PCRE=yes
+            ], [AC_MSG_ERROR([libpcre could not be found])])
     fi
-    dnl Check that we can find the pcre.h header file
-    CPPFLAGS_SAVE="$CPPFLAGS"
-    CPPFLAGS="$PCRE_CPPFLAGS"
-    AC_CHECK_HEADER([pcre.h], [HAVE_PCRE=yes], [ADDRESS_STANDARDIZER=""])
-    AC_SUBST([PCRE])
-    AC_SUBST([HAVE_PCRE])
-    AC_SUBST([ADDRESS_STANDARDIZER])
-    dnl Return the PCRE version number
-    AC_DEFINE_UNQUOTED([PCRE_VERSION], [$PCRE_VERSION], [PCRE library version])
-    AC_SUBST([PCRE_VERSION])
-    CPPFLAGS="$CPPFLAGS_SAVE"
     AC_SUBST([PCRE_CPPFLAGS])
     AC_SUBST([PCRE_LDFLAGS])
 else
     AC_MSG_RESULT([ADDRESS_STANDARDIZER support: disabled])
 fi
+AC_SUBST([HAVE_PCRE])
+AC_SUBST([ADDRESS_STANDARDIZER])
 CPPFLAGS="$PGSQL_CPPFLAGS $GEOS_CPPFLAGS $PROJ_CPPFLAGS $PROTOBUF_CPPFLAGS $XML2_CPPFLAGS $SFCGAL_CPPFLAGS $JSON_CPPFLAGS $PCRE_CPPFLAGS $CPPFLAGS"
 dnl AC_MSG_RESULT([CPPFLAGS: $CPPFLAGS])
-SHLIB_LINK="$PGSQL_LDFLAGS $GEOS_LDFLAGS $PROJ_LDFLAGS -lgeos_c -lproj $JSON_LDFLAGS $PROTOBUF_LDFLAGS $XML2_LDFLAGS $SFCGAL_LDFLAGS $PCRE_LDFLAGS $EXCLUDELIBS_LDFLAGS $LDFLAGS"
+SHLIB_LINK="$PGSQL_LDFLAGS $GEOS_LDFLAGS $PROJ_LDFLAGS $JSON_LDFLAGS $PROTOBUF_LDFLAGS $XML2_LDFLAGS $SFCGAL_LDFLAGS $EXCLUDELIBS_LDFLAGS $LDFLAGS"
 AC_SUBST([SHLIB_LINK])
 dnl AC_MSG_RESULT([SHLIB_LINK: $SHLIB_LINK])
@@ -1526,6 +1548,7 @@
 if test "x$HAVE_WAGYU" = "xyes"; then
     AC_MSG_RESULT([  C++ compiler:         ${CXX} ${CXXFLAGS}])
 fi
+AC_MSG_RESULT([  CPPFLAGS:             $CPPFLAGS])
 AC_MSG_RESULT([  SQL preprocessor:     ${SQLPP}])
 AC_MSG_RESULT()
 AC_MSG_RESULT([ -------------- Additional Info ------------- ])
@@ -1612,3 +1635,34 @@
 AC_MSG_WARN()
 fi
+    if test ! "x$PROJDIR" = "x"; then
+        AC_MSG_WARN()
+        AC_MSG_WARN([ | You are building using --with-projdir. This option isn't standard and    |])
+        AC_MSG_WARN([ | might be incompatible with future releases of PROJ.                      |])
+        AC_MSG_WARN([ | You can instead adjust the PKG_CONFIG_PATH environment variable if you   |])
+        AC_MSG_WARN([ | installed software in a non-standard prefix.                             |])
+        AC_MSG_WARN([ | Alternatively, you may set the environment variables PROJ_CFLAGS and     |])
+        AC_MSG_WARN([ | PROJ_LIBS to avoid the need to call pkg-config.                          |])
+    fi
+        AC_MSG_WARN()
+        AC_MSG_WARN([ | You are building using --with-jsondir. This option isn't standard and    |])
+        AC_MSG_WARN([ | might be incompatible with future releases of json-c.                    |])
+        AC_MSG_WARN([ | Alternatively, you may set the environment variables JSONC_CFLAGS and    |])
+        AC_MSG_WARN([ | JSONC_LIBS to avoid the need to call pkg-config.                         |])
+    fi
+    if test ! "x$PCREDIR" = "x"; then
+        AC_MSG_WARN()
+        AC_MSG_WARN([ | You are building using --with-pcredir. This option isn't standard and    |])
+        AC_MSG_WARN([ | might be incompatible with future releases of libpcre.                   |])
+        AC_MSG_WARN([ | Alternatively, you may set the environment variables PCRE_CFLAGS and     |])
+        AC_MSG_WARN([ | PCRE_LIBS to avoid the need to call pkg-config.                          |])
+    fi
+fi
\ No newline at end of file
Modified: trunk/extensions/address_standardizer/Makefile.in
--- trunk/extensions/address_standardizer/Makefile.in	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/extensions/address_standardizer/Makefile.in	2019-02-11 16:41:35 UTC (rev 17233)
@@ -52,7 +52,7 @@
 DOCS = README.address_standardizer
 PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@
-SHLIB_LINK = @SHLIB_LINK@ -lpcre
+SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
 EXTRA_CLEAN = usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
 REGRESS = test-init-extensions test-parseaddress test-standardize_address_1 test-standardize_address_2
Modified: trunk/liblwgeom/cunit/cu_geodetic.c
--- trunk/liblwgeom/cunit/cu_geodetic.c	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/liblwgeom/cunit/cu_geodetic.c	2019-02-11 16:41:35 UTC (rev 17233)
@@ -1373,7 +1373,6 @@
 	CU_ASSERT_DOUBLE_EQUAL(a1, 12341436880.106982993974659, 0.1);
 	/* spheroid: Planimeter -E -p 20 -r --input-string "3 -2;4 -2;4 -1;3 -1" */
 #if PROJ_GEODESIC
-	// printf("XXXXX %d\n", PJ_VERSION);
 	a2 = lwgeom_area_spheroid(lwg, &s);
 	CU_ASSERT_DOUBLE_EQUAL(a2, 12286884908.946891319597874, 0.1);
 #endif
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/liblwgeom/liblwgeom.h.in	2019-02-11 16:41:35 UTC (rev 17233)
@@ -32,10 +32,11 @@
 #include <stdarg.h>
 #include <stdio.h>
 #include <stdint.h>
-#define ACCEPT_USE_OF_DEPRECATED_PROJ_API_H 1
+#include "../postgis_config.h"
 #include "proj_api.h"
-#if defined(PJ_VERSION) && PJ_VERSION >= 490
+#if POSTGIS_PROJ_VERSION >= 49
 /* Enable new geodesic functions */
 #define PROJ_GEODESIC 1
 #else
Modified: trunk/liblwgeom/lwin_geojson.c
--- trunk/liblwgeom/lwin_geojson.c	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/liblwgeom/lwin_geojson.c	2019-02-11 16:41:35 UTC (rev 17233)
@@ -33,17 +33,11 @@
 #define JSON_C_VERSION_013 (13 << 8)
-#ifdef HAVE_LIBJSON_C
-#include <json-c/json.h>
+#include <json.h>
 #if !defined(JSON_C_VERSION_NUM) || JSON_C_VERSION_NUM < JSON_C_VERSION_013
-#include <json-c/json_object_private.h>
+#include <json_object_private.h>
 #endif
-#else
-#include <json/json.h>
-#if !defined(JSON_C_VERSION_NUM) || JSON_C_VERSION_NUM < JSON_C_VERSION_013
-#include <json/json_object_private.h>
-#endif
-#endif
 #ifndef JSON_C_VERSION
 /* Adds support for libjson < 0.10 */
Modified: trunk/postgis/lwgeom_in_geojson.c
--- trunk/postgis/lwgeom_in_geojson.c	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/postgis/lwgeom_in_geojson.c	2019-02-11 16:41:35 UTC (rev 17233)
@@ -32,13 +32,10 @@
 #include "liblwgeom.h"
 #include "lwgeom_export.h"
-# ifdef HAVE_LIBJSON_C
-#  include <json-c/json.h>
-# else
-#  include <json/json.h>
-# endif
+#if defined(HAVE_LIBJSON) || defined(HAVE_LIBJSON_C)
+#include <json.h>
 /* We don't include <utils/builtins.h> to avoid collisions with json-c/json.h */
 static text*
 cstring2text(const char *cstring)
Modified: trunk/postgis_config.h.in
--- trunk/postgis_config.h.in	2019-02-06 22:38:52 UTC (rev 17232)
+++ trunk/postgis_config.h.in	2019-02-11 16:41:35 UTC (rev 17233)
@@ -113,6 +113,9 @@
 /* Define to 1 if wagyu is being built */
 #undef HAVE_WAGYU
+/* Define to 1 if sfcgal is being built */
+#undef HAVE_SFCGAL
 /* Define to the sub-directory in which libtool stores uninstalled libraries.
 #undef LT_OBJDIR
@@ -156,6 +159,9 @@
 /* PROJ library version */
 #undef POSTGIS_PROJ_VERSION
+/* PROJ 6: Flag to use the old API */
+#undef ACCEPT_USE_OF_DEPRECATED_PROJ_API_H
 /* PostGIS Raster build date */
 #undef POSTGIS_RASTER_BUILD_DATE
