[postgis-tickets] r17254 - Update OGC certification scripts to match new SFSQL 1.2 signatures
Paul Ramsey pramsey at cleverelephant.ca
Fri Feb 15 10:53:37 PST 2019
Author: pramsey
Date: 2019-02-15 10:53:36 -0800 (Fri, 15 Feb 2019)
New Revision: 17254
   branches/2.4/extras/ogc_test_suite/1_schema.sql
   branches/2.4/extras/ogc_test_suite/2_queries.sql
   branches/2.4/extras/ogc_test_suite/Makefile
Modified: branches/2.4/extras/ogc_test_suite/1_schema.sql
--- branches/2.4/extras/ogc_test_suite/1_schema.sql	2019-02-15 18:53:11 UTC (rev 17253)
+++ branches/2.4/extras/ogc_test_suite/1_schema.sql	2019-02-15 18:53:36 UTC (rev 17254)
@@ -157,9 +157,9 @@
 -- !#@ ADAPTATION BEGIN
--- We break the schema creation into two steps, first create the
--- attribute table, second use the AddGeometryColumn() function
--- to create and register the geometry column.
+-- We declare the geometry column type using 'GEOMETRY'
+-- as the type with 'POLYGON' and 101 as type modifiers
+-- to enforce the geometry type and SRID.
 -- -- BEGIN ORIGINAL SQL
@@ -176,9 +176,9 @@
 CREATE TABLE lakes (
        fid               INTEGER NOT NULL PRIMARY KEY,
-       name              VARCHAR(64)
+       name              VARCHAR(64),
+       shore             GEOMETRY(Polygon, 101)
-SELECT AddGeometryColumn('lakes','shore','101','POLYGON','2');
 -- -- END   ADAPTED  SQL
@@ -189,9 +189,9 @@
+-- as the type with 'LINESTRING' and 101 as type modifiers
@@ -213,9 +213,9 @@
        name              VARCHAR(64),
        aliases           VARCHAR(64),
-       num_lanes         INTEGER
+       num_lanes         INTEGER,
+       centerline        GEOMETRY(LineString, 101)
-SELECT AddGeometryColumn('road_segments','centerline','101','LINESTRING','2');
@@ -228,9 +228,9 @@
+-- as the type with 'MULTILINESTRING' and 101 as type modifiers
@@ -249,9 +249,9 @@
 CREATE TABLE divided_routes (
        name              VARCHAR(64),
-       num_lanes         INTEGER
+       centerlines       GEOMETRY(multilinestring, 101)
-SELECT AddGeometryColumn('divided_routes','centerlines','101','MULTILINESTRING','2');
@@ -264,9 +264,9 @@
+-- as the type with 'MULTIPOLYGON' and 101 as type modifiers
@@ -283,9 +283,9 @@
 CREATE TABLE forests (
-       name           VARCHAR(64)
+       name           VARCHAR(64),
+       boundary       GEOMETRY(MultiPolygon, 101)
-SELECT AddGeometryColumn('forests','boundary','101','MULTIPOLYGON','2');
@@ -298,9 +298,9 @@
+-- as the type with 'POINT' and 101 as type modifiers
@@ -317,23 +317,22 @@
 CREATE TABLE bridges (
-       name          VARCHAR(64)
+       name          VARCHAR(64),
+       position      GEOMETRY(Point, 101)
-SELECT AddGeometryColumn('bridges','position','101','POINT','2');
 -- -- !#@ ADAPTATION END
 -- Streams
@@ -350,9 +349,9 @@
 CREATE TABLE streams (
-       name            VARCHAR(64)
+       name            VARCHAR(64),
-SELECT AddGeometryColumn('streams','centerline','101','LINESTRING','2');
@@ -370,9 +369,9 @@
+-- as the type with 'POINT', 'POLYGON' and 101 as type modifiers
@@ -390,10 +389,10 @@
 CREATE TABLE buildings (
-       address         VARCHAR(64)
+       address         VARCHAR(64),
+       position        GEOMETRY(Point, 101),
+       footprint       GEOMETRY(Polygon, 101)
-SELECT AddGeometryColumn('buildings','position','101','POINT','2');
-SELECT AddGeometryColumn('buildings','footprint','101','POLYGON','2');
@@ -406,9 +405,9 @@
+-- as the type with 'MULTIPOYLGON' and 101 as type modifiers
@@ -427,9 +426,9 @@
 CREATE TABLE ponds (
        name            VARCHAR(64),
-       type            VARCHAR(64)
+       type            VARCHAR(64),
+       shores          GEOMETRY(MultiPolygon, 101)
-SELECT AddGeometryColumn('ponds','shores','101','MULTIPOLYGON','2');
@@ -442,9 +441,9 @@
@@ -462,9 +461,9 @@
 CREATE TABLE named_places (
-       name            VARCHAR(64)
+       name            VARCHAR(64),
+       boundary        GEOMETRY(Polygon, 101)
-SELECT AddGeometryColumn('named_places','boundary','101','POLYGON','2');
@@ -476,9 +475,9 @@
@@ -493,9 +492,9 @@
 -- -- BEGIN ADAPTED  SQL
 CREATE TABLE map_neatlines (
-       fid             INTEGER NOT NULL PRIMARY KEY
+       fid             INTEGER NOT NULL PRIMARY KEY,
+       neatline        GEOMETRY(Polygon, 101)
-SELECT AddGeometryColumn('map_neatlines','neatline','101','POLYGON','2');
@@ -528,7 +527,7 @@
 INSERT INTO lakes VALUES (101, 'Blue Lake',
-    PolygonFromText('POLYGON((52 18,66 23,73 9,48 6,52 18),(59 18,67 18,67 13,59 13,59 18))', 101)
+    ST_GeomFromText('POLYGON((52 18,66 23,73 9,48 6,52 18),(59 18,67 18,67 13,59 13,59 18))', 101)
@@ -551,19 +550,19 @@
 INSERT INTO road_segments VALUES(102, 'Route 5', NULL, 2,
-    LineStringFromText('LINESTRING( 0 18, 10 21, 16 23, 28 26, 44 31 )' ,101)
+    ST_GeomFromText('LINESTRING( 0 18, 10 21, 16 23, 28 26, 44 31 )' ,101)
 INSERT INTO road_segments VALUES(103, 'Route 5', 'Main Street', 4,
-    LineStringFromText('LINESTRING( 44 31, 56 34, 70 38 )' ,101)
+    ST_GeomFromText('LINESTRING( 44 31, 56 34, 70 38 )' ,101)
 INSERT INTO road_segments VALUES(104, 'Route 5', NULL, 2,
-    LineStringFromText('LINESTRING( 70 38, 72 48 )' ,101)
+    ST_GeomFromText('LINESTRING( 70 38, 72 48 )' ,101)
 INSERT INTO road_segments VALUES(105, 'Main Street', NULL, 4,
-    LineStringFromText('LINESTRING( 70 38, 84 42 )' ,101)
+    ST_GeomFromText('LINESTRING( 70 38, 84 42 )' ,101)
 INSERT INTO road_segments VALUES(106, 'Dirt Road by Green Forest', NULL, 1,
-    LineStringFromText('LINESTRING( 28 26, 28 0 )',101)
+    ST_GeomFromText('LINESTRING( 28 26, 28 0 )',101)
@@ -576,7 +575,7 @@
 INSERT INTO divided_routes VALUES(119, 'Route 75', 4,
-    MultiLineStringFromText('MULTILINESTRING((10 48,10 21,10 0),(16 0,16 23,16 48))', 101)
+    ST_GeomFromText('MULTILINESTRING((10 48,10 21,10 0),(16 0,16 23,16 48))', 101)
@@ -591,7 +590,7 @@
 INSERT INTO forests VALUES(109, 'Green Forest',
-    MultiPolygonFromText('MULTIPOLYGON(((28 26,28 0,84 0,84 42,28 26),(52 18,66 23,73 9,48 6,52 18)),((59 18,67 18,67 13,59 13,59 18)))', 101)
+    ST_GeomFromText('MULTIPOLYGON(((28 26,28 0,84 0,84 42,28 26),(52 18,66 23,73 9,48 6,52 18)),((59 18,67 18,67 13,59 13,59 18)))', 101)
@@ -604,7 +603,7 @@
 INSERT INTO bridges VALUES(110, 'Cam Bridge',
-    PointFromText('POINT( 44 31 )', 101)
+    ST_GeomFromText('POINT( 44 31 )', 101)
@@ -618,10 +617,10 @@
 INSERT INTO streams VALUES(111, 'Cam Stream',
-    LineStringFromText('LINESTRING( 38 48, 44 41, 41 36, 44 31, 52 18 )', 101)
+    ST_GeomFromText('LINESTRING( 38 48, 44 41, 41 36, 44 31, 52 18 )', 101)
 INSERT INTO streams VALUES(112, NULL,
-    LineStringFromText('LINESTRING( 76 0, 78 4, 73 9 )', 101)
+    ST_GeomFromText('LINESTRING( 76 0, 78 4, 73 9 )', 101)
@@ -639,12 +638,12 @@
 INSERT INTO buildings VALUES(113, '123 Main Street',
-    PointFromText('POINT( 52 30 )', 101),
-    PolygonFromText('POLYGON( ( 50 31, 54 31, 54 29, 50 29, 50 31) )', 101)
+    ST_GeomFromText('POINT( 52 30 )', 101),
+    ST_GeomFromText('POLYGON( ( 50 31, 54 31, 54 29, 50 29, 50 31) )', 101)
 INSERT INTO buildings VALUES(114, '215 Main Street',
-    PointFromText('POINT( 64 33 )', 101),
-    PolygonFromText('POLYGON( ( 66 34, 62 34, 62 32, 66 32, 66 34) )', 101)
+    ST_GeomFromText('POINT( 64 33 )', 101),
+    ST_GeomFromText('POLYGON( ( 66 34, 62 34, 62 32, 66 32, 66 34) )', 101)
@@ -657,7 +656,7 @@
 INSERT INTO ponds VALUES(120, NULL, 'Stock Pond',
-    MultiPolygonFromText('MULTIPOLYGON( ( ( 24 44, 22 42, 24 40, 24 44) ), ( ( 26 44, 26 40, 28 42, 26 44) ) )', 101)
+    ST_GeomFromText('MULTIPOLYGON( ( ( 24 44, 22 42, 24 40, 24 44) ), ( ( 26 44, 26 40, 28 42, 26 44) ) )', 101)
@@ -673,10 +672,10 @@
 INSERT INTO named_places VALUES(117, 'Ashton',
-    PolygonFromText('POLYGON( ( 62 48, 84 48, 84 30, 56 30, 56 34, 62 48) )', 101)
+    ST_GeomFromText('POLYGON( ( 62 48, 84 48, 84 30, 56 30, 56 34, 62 48) )', 101)
 INSERT INTO named_places VALUES(118, 'Goose Island',
-    PolygonFromText('POLYGON( ( 67 13, 67 18, 59 18, 59 13, 67 13) )', 101)
+    ST_GeomFromText('POLYGON( ( 67 13, 67 18, 59 18, 59 13, 67 13) )', 101)
@@ -689,7 +688,7 @@
 INSERT INTO map_neatlines VALUES(115,
-    PolygonFromText('POLYGON( ( 0 0, 0 48, 84 48, 84 0, 0 0 ) )', 101)
+    ST_GeomFromText('POLYGON( ( 0 0, 0 48, 84 48, 84 0, 0 0 ) )', 101)
Modified: branches/2.4/extras/ogc_test_suite/2_queries.sql
--- branches/2.4/extras/ogc_test_suite/2_queries.sql	2019-02-15 18:53:11 UTC (rev 17253)
+++ branches/2.4/extras/ogc_test_suite/2_queries.sql	2019-02-15 18:53:36 UTC (rev 17254)
@@ -78,24 +78,24 @@
--- Conformance Item T1
--- GEOMETRY_COLUMNS table/view is created/updated properly
+-- Conformance Item T1
+-- GEOMETRY_COLUMNS table/view is created/updated properly
 -- For this test we will check to see that all of the feature tables are
 -- represented by entries in the GEOMETRY_COLUMNS table/view
 -- ANSWER: lakes, road_segments, divided_routes, buildings, forests, bridges,
 --         named_places, streams, ponds, map_neatlines
--- *** ADAPTATION ALERT ***
+-- *** ADAPTATION ALERT ***
 -- Since there are no quotes around the table names in the CREATE TABLEs,
 -- they will be converted to upper case in many DBMSs, and therefore, the
 -- answer to this query may be:
 -- ANSWER: LAKES, ROAD_SEGMENTS, DIVIDED_ROUTES, BUILDINGS, FORESTS, BRIDGES,
 --         NAMED_PLACES, STREAMS, PONDS, MAP_NEATLINES
 -- If the implementer made the adaptation concerning the buildings table
 -- in sqltsch.sql, then the answer here may differ slightly.
 SELECT f_table_name
@@ -103,13 +103,13 @@
--- Conformance Item T2
+-- Conformance Item T2
 -- For this test we will check to see that the correct geometry columns for the
 -- streams table is represented in the GEOMETRY_COLUMNS table/view
 -- ANSWER: centerline
 -- Since there are no quotes around the table name, streams, in it's CREATE TABLE,
 -- it will be converted to upper case in many DBMSs, and therefore, the WHERE
 -- clause may have to be f_table_name = 'STREAMS'.
@@ -122,13 +122,13 @@
--- Conformance Item T3
+-- Conformance Item T3
 -- For this test we will check to see that the correct coordinate dimension
 -- for the streams table is represented in the GEOMETRY_COLUMNS table/view
--- ANSWER: 2
+-- ANSWER: 2
@@ -141,13 +141,13 @@
--- Conformance Item T4
+-- Conformance Item T4
 -- For this test we will check to see that the correct value of srid for
 -- the streams table is represented in the GEOMETRY_COLUMNS table/view
--- ANSWER: 101
+-- ANSWER: 101
@@ -171,7 +171,7 @@
 --           PROJECTION["Traverse_Mercator"], PARAMETER["False_Easting", 500000.0],
 --           PARAMETER["False_Northing", 0.0], PARAMETER["Central_Meridian", -99.0],
 --           PARAMETER["Scale_Factor", 0.9996], PARAMETER["Latitude_of_origin", 0.0],
---           UNIT["Meter", 1.0]]'
+--           UNIT["Meter", 1.0]]'
@@ -187,8 +187,13 @@
+-- -- !#@ ADAPTATION BEGIN
+-- All functions are now prefixed with "ST_" in accordance with SFSQL 1.2
+-- and ISO SQL/MM Part 2
+-- -- !#@ ADAPTATION END
--- Conformance Item T6
+-- Conformance Item T6
 -- Dimension(g Geometry) : Integer
 -- For this test we will determine the dimension of Blue Lake.
@@ -196,13 +201,13 @@
-SELECT Dimension(shore)
+SELECT ST_Dimension(shore)
 FROM lakes
 WHERE name = 'Blue Lake';
--- Conformance Item T7
+-- Conformance Item T7
 -- GeometryType(g Geometry) : String
 -- For this test we will determine the type of Route 75.
@@ -225,7 +230,7 @@
-SELECT GeometryType(centerlines)
+SELECT ST_GeometryType(centerlines)
 FROM divided_routes
 WHERE name = 'Route 75';
@@ -234,7 +239,7 @@
--- Conformance Item T8
+-- Conformance Item T8
 -- AsText(g Geometry) : String
 -- For this test we will determine the WKT representation of Goose Island.
@@ -242,12 +247,12 @@
-SELECT AsText(boundary)
+SELECT ST_AsText(boundary)
 FROM named_places
 WHERE name = 'Goose Island';
--- Conformance Item T9
+-- Conformance Item T9
 -- AsBinary(g Geometry) : Blob
 -- For this test we will determine the WKB representation of Goose Island.
 -- We will test by applying AsText to the result of PolygonFromText to the
@@ -257,12 +262,12 @@
-SELECT AsText(PolygonFromWKB(AsBinary(boundary)))
+SELECT ST_AsText(ST_PolygonFromWKB(ST_AsBinary(boundary)))
 FROM named_places
--- Conformance Item T10
+-- Conformance Item T10
 -- SRID(g Geometry) : Integer
 -- For this test we will determine the SRID of Goose Island.
@@ -270,12 +275,12 @@
-SELECT SRID(boundary)
+SELECT ST_SRID(boundary)
 FROM named_places
--- Conformance Item T11
+-- Conformance Item T11
 -- IsEmpty(g Geometry) : Integer
 -- For this test we will determine whether the geometry of a
 -- segment of Route 5 is empty.
@@ -288,12 +293,12 @@
-SELECT IsEmpty(centerline)
+SELECT ST_IsEmpty(centerline)
 FROM road_segments
 WHERE name = 'Route 5' AND aliases = 'Main Street';
--- Conformance Item T12
+-- Conformance Item T12
 -- IsSimple(g Geometry) : Integer
 -- segment of Blue Lake is simple.
@@ -306,12 +311,12 @@
-SELECT IsSimple(shore)
+SELECT ST_IsSimple(shore)
 FROM lakes
--- Conformance Item T13
+-- Conformance Item T13
 -- Boundary(g Geometry) : Geometry
 -- For this test we will determine the boundary of Goose Island.
 -- NOTE: The boundary result is as defined in 3.12.3.2 of 96-015R1.
@@ -334,7 +339,7 @@
-SELECT AsText(Boundary(boundary))
+SELECT ST_AsText(ST_Boundary(boundary))
 FROM named_places
@@ -343,7 +348,7 @@
--- Conformance Item T14
+-- Conformance Item T14
 -- Envelope(g Geometry) : Geometry
 -- For this test we will determine the envelope of Goose Island.
@@ -365,7 +370,7 @@
-SELECT AsText(Envelope(boundary))
+SELECT ST_AsText(ST_Envelope(boundary))
 FROM named_places
@@ -382,7 +387,7 @@
--- Conformance Item T15
+-- Conformance Item T15
 -- X(p Point) : Double Precision
 -- For this test we will determine the X coordinate of Cam Bridge.
@@ -404,7 +409,7 @@
-SELECT X(position)
+SELECT ST_X(position)
 FROM bridges
 WHERE name = 'Cam Bridge';
@@ -413,7 +418,7 @@
--- Conformance Item T16
+-- Conformance Item T16
 -- Y(p Point) : Double Precision
 -- For this test we will determine the Y coordinate of Cam Bridge.
@@ -421,7 +426,7 @@
-SELECT Y(position)
+SELECT ST_Y(position)
 FROM bridges
@@ -434,7 +439,7 @@
--- Conformance Item T17
+-- Conformance Item T17
 -- StartPoint(c Curve) : Point
 -- For this test we will determine the start point of road segment 102.
@@ -442,12 +447,12 @@
-SELECT AsText(StartPoint(centerline))
+SELECT ST_AsText(ST_StartPoint(centerline))
 FROM road_segments
 WHERE fid = 102;
--- Conformance Item T18
+-- Conformance Item T18
 -- EndPoint(c Curve) : Point
 -- For this test we will determine the end point of road segment 102.
@@ -455,12 +460,12 @@
-SELECT AsText(EndPoint(centerline))
+SELECT ST_AsText(ST_EndPoint(centerline))
 FROM road_segments
 WHERE fid = 102;
--- Conformance Item T19
+-- Conformance Item T19
 -- IsClosed(c Curve) : Integer
@@ -472,12 +477,12 @@
-SELECT IsClosed(Boundary(boundary))
+SELECT ST_IsClosed(ST_Boundary(boundary))
 FROM named_places
--- Conformance Item T20
+-- Conformance Item T20
 -- IsRing(c Curve) : Integer
@@ -489,12 +494,12 @@
-SELECT IsRing(Boundary(boundary))
+SELECT ST_IsRing(ST_Boundary(boundary))
 FROM named_places
--- Conformance Item T21
+-- Conformance Item T21
 -- Length(c Curve) : Double Precision
 -- For this test we will determine the length of road segment 106.
@@ -502,7 +507,7 @@
-SELECT Length(centerline)
+SELECT ST_Length(centerline)
 FROM road_segments
 WHERE fid = 106;
@@ -515,7 +520,7 @@
--- Conformance Item T22
+-- Conformance Item T22
 -- NumPoints(l LineString) : Integer
 -- For this test we will determine the number of points in road segment 102.
@@ -523,12 +528,12 @@
-SELECT NumPoints(centerline)
+SELECT ST_NumPoints(centerline)
 FROM road_segments
 WHERE fid = 102;
--- Conformance Item T23
+-- Conformance Item T23
 -- PointN(l LineString, n Integer) : Point
 -- For this test we will determine the 1st point in road segment 102.
@@ -536,7 +541,7 @@
-SELECT AsText(PointN(centerline, 1))
+SELECT ST_AsText(ST_PointN(centerline, 1))
 FROM road_segments
 WHERE fid = 102;
@@ -549,7 +554,7 @@
--- Conformance Item T24
+-- Conformance Item T24
 -- Centroid(s Surface) : Point
 -- For this test we will determine the centroid of Goose Island.
@@ -557,12 +562,12 @@
-SELECT AsText(Centroid(boundary))
+SELECT ST_AsText(ST_Centroid(boundary))
 FROM named_places
--- Conformance Item T25
+-- Conformance Item T25
 -- PointOnSurface(s Surface) : Point
 -- For this test we will determine a point on Goose Island.
 -- NOTE: For this test we will have to uses the Contains function
@@ -576,12 +581,12 @@
-SELECT Contains(boundary, PointOnSurface(boundary))
+SELECT ST_Contains(boundary, ST_PointOnSurface(boundary))
 FROM named_places
--- Conformance Item T26
+-- Conformance Item T26
 -- Area(s Surface) : Double Precision
 -- For this test we will determine the area of Goose Island.
@@ -589,7 +594,7 @@
-SELECT Area(boundary)
+SELECT ST_Area(boundary)
 FROM named_places
@@ -602,7 +607,7 @@
--- Conformance Item T27
+-- Conformance Item T27
 -- ExteriorRing(p Polygon) : LineString
 -- For this test we will determine the exteroir ring of Blue Lake.
@@ -610,12 +615,12 @@
-SELECT AsText(ExteriorRing(shore))
+SELECT ST_AsText(ST_ExteriorRing(shore))
 FROM lakes
--- Conformance Item T28
+-- Conformance Item T28
 -- NumInteriorRings(p Polygon) : Integer
 -- For this test we will determine the number of interior rings of Blue Lake.
@@ -623,12 +628,12 @@
-SELECT NumInteriorRings(shore)
+SELECT ST_NumInteriorRings(shore)
 FROM lakes
--- Conformance Item T29
+-- Conformance Item T29
 -- InteriorRingN(p Polygon, n Integer) : LineString
 -- For this test we will determine the first interior ring of Blue Lake.
@@ -636,7 +641,7 @@
-SELECT AsText(InteriorRingN(shore, 1))
+SELECT ST_AsText(ST_InteriorRingN(shore, 1))
 FROM lakes
@@ -649,7 +654,7 @@
--- Conformance Item T30
+-- Conformance Item T30
 -- NumGeometries(g GeometryCollection) : Integer
 -- For this test we will determine the number of geometries in Route 75.
@@ -657,12 +662,12 @@
-SELECT NumGeometries(centerlines)
+SELECT ST_NumGeometries(centerlines)
 FROM divided_routes
--- Conformance Item T31
+-- Conformance Item T31
 -- GeometryN(g GeometryCollection, n Integer) : Geometry
 -- For this test we will determine the second geometry in Route 75.
@@ -685,7 +690,7 @@
-SELECT AsText(GeometryN(centerlines, 2))
+SELECT ST_AsText(ST_GeometryN(centerlines, 2))
 FROM divided_routes
@@ -702,7 +707,7 @@
--- Conformance Item T32
+-- Conformance Item T32
 -- IsClosed(mc MultiCurve) : Integer
 -- For this test we will determine if the geometry of Route 75 is closed.
@@ -714,12 +719,12 @@
-SELECT IsClosed(centerlines)
+SELECT ST_IsClosed(centerlines)
 FROM divided_routes
--- Conformance Item T33
+-- Conformance Item T33
 -- Length(mc MultiCurve) : Double Precision
 -- For this test we will determine the length of Route 75.
 -- NOTE: This makes no semantic sense in our example...
@@ -728,7 +733,7 @@
-SELECT Length(centerlines)
+SELECT ST_Length(centerlines)
 FROM divided_routes
@@ -741,7 +746,7 @@
--- Conformance Item T34
+-- Conformance Item T34
 -- Centroid(ms MultiSurface) : Point
 -- For this test we will determine the centroid of the ponds.
@@ -749,12 +754,12 @@
-SELECT AsText(Centroid(shores))
+SELECT ST_AsText(ST_Centroid(shores))
 FROM ponds
 WHERE fid = 120;
--- Conformance Item T35
+-- Conformance Item T35
 -- PointOnSurface(ms MultiSurface) : Point
 -- For this test we will determine a point on the ponds.
@@ -768,12 +773,12 @@
-SELECT Contains(shores, PointOnSurface(shores))
+SELECT ST_Contains(shores, ST_PointOnSurface(shores))
 FROM ponds
 WHERE fid = 120;
--- Conformance Item T36
+-- Conformance Item T36
 -- Area(ms MultiSurface) : Double Precision
 -- For this test we will determine the area of the ponds.
@@ -781,7 +786,7 @@
-SELECT Area(shores)
+SELECT ST_Area(shores)
 FROM ponds
 WHERE fid = 120;
@@ -794,7 +799,7 @@
--- Conformance Item T37
+-- Conformance Item T37
 -- Equals(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of Goose Island is equal
 -- to the same geometry as consructed from it's WKT representation.
@@ -807,12 +812,12 @@
-SELECT Equals(boundary, PolygonFromText('POLYGON( ( 67 13, 67 18, 59 18, 59 13, 67 13) )',1))
+SELECT ST_Equals(boundary, ST_PolygonFromText('POLYGON( ( 67 13, 67 18, 59 18, 59 13, 67 13) )',101))
 FROM named_places
--- Conformance Item T38
+-- Conformance Item T38
 -- Disjoint(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of Route 75 is disjoint
 -- from the geometry of Ashton.
@@ -825,12 +830,12 @@
-SELECT Disjoint(centerlines, boundary)
+SELECT ST_Disjoint(centerlines, boundary)
 FROM divided_routes, named_places
 WHERE divided_routes.name = 'Route 75' AND named_places.name = 'Ashton';
--- Conformance Item T39
+-- Conformance Item T39
 -- Touch(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of Cam Stream touches
 -- the geometry of Blue Lake.
@@ -857,7 +862,7 @@
-SELECT Touches(centerline, shore)
+SELECT ST_Touches(centerline, shore)
 FROM streams, lakes
 WHERE streams.name = 'Cam Stream' AND lakes.name = 'Blue Lake';
@@ -866,7 +871,7 @@
--- Conformance Item T40
+-- Conformance Item T40
 -- Within(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of the house at 215 Main Street
 -- is within Ashton.
@@ -895,7 +900,7 @@
-SELECT Within(footprint, boundary)
+SELECT ST_Within(footprint, boundary)
 FROM named_places, buildings
 WHERE named_places.name = 'Ashton' AND buildings.address = '215 Main Street';
@@ -904,7 +909,7 @@
--- Conformance Item T41
+-- Conformance Item T41
 -- Overlap(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of Green Forest overlaps
 -- the geometry of Ashton.
@@ -931,7 +936,7 @@
-SELECT Overlaps(forests.boundary, named_places.boundary)
+SELECT ST_Overlaps(forests.boundary, named_places.boundary)
 FROM forests, named_places
 WHERE forests.name = 'Green Forest' AND named_places.name = 'Ashton';
@@ -940,7 +945,7 @@
--- Conformance Item T42
+-- Conformance Item T42
 -- Cross(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of road segment 102 crosses
 -- the geometry of Route 75.
@@ -969,7 +974,7 @@
-SELECT Crosses(road_segments.centerline, divided_routes.centerlines)
+SELECT ST_Crosses(road_segments.centerline, divided_routes.centerlines)
 FROM road_segments, divided_routes
 WHERE road_segments.fid = 102 AND divided_routes.name = 'Route 75';
@@ -978,7 +983,7 @@
--- Conformance Item T43
+-- Conformance Item T43
 -- Intersects(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of road segment 102 intersects
@@ -1005,7 +1010,7 @@
-SELECT Intersects(road_segments.centerline, divided_routes.centerlines)
+SELECT ST_Intersects(road_segments.centerline, divided_routes.centerlines)
@@ -1014,7 +1019,7 @@
--- Conformance Item T44
+-- Conformance Item T44
 -- Contains(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine if the geometry of Green Forest contains
@@ -1041,7 +1046,7 @@
-SELECT Contains(forests.boundary, named_places.boundary)
+SELECT ST_Contains(forests.boundary, named_places.boundary)
@@ -1050,7 +1055,7 @@
--- Conformance Item T45
+-- Conformance Item T45
 -- Relate(g1 Geometry, g2 Geometry, PatternMatrix String) : Integer
 -- For this test we will determine if the geometry of Green Forest relates to
 -- the geometry of Ashton using the pattern "TTTTTTTTT".
@@ -1077,7 +1082,7 @@
-SELECT Relate(forests.boundary, named_places.boundary, 'TTTTTTTTT')
+SELECT ST_Relate(forests.boundary, named_places.boundary, 'TTTTTTTTT')
@@ -1094,7 +1099,7 @@
--- Conformance Item T46
+-- Conformance Item T46
 -- Distance(g1 Geometry, g2 Geometry) : Double Precision
 -- For this test we will determine the distance between Cam Bridge and Ashton.
@@ -1102,7 +1107,7 @@
-SELECT Distance(position, boundary)
+SELECT ST_Distance(position, boundary)
 FROM bridges, named_places
 WHERE bridges.name = 'Cam Bridge' AND named_places.name = 'Ashton';
@@ -1115,7 +1120,7 @@
--- Conformance Item T47
+-- Conformance Item T47
 -- Intersection(g1 Geometry, g2 Geometry) : Geometry
 -- For this test we will determine the intersection between Cam Stream and
 -- Blue Lake.
@@ -1139,7 +1144,7 @@
-SELECT AsText(Intersection(centerline, shore))
+SELECT ST_AsText(ST_Intersection(centerline, shore))
 FROM streams, lakes
@@ -1148,7 +1153,7 @@
--- Conformance Item T48
+-- Conformance Item T48
 -- Difference(g1 Geometry, g2 Geometry) : Geometry
 -- For this test we will determine the difference between Ashton and
 -- Green Forest.
@@ -1175,7 +1180,7 @@
-SELECT AsText(Difference(named_places.boundary, forests.boundary))
+SELECT ST_AsText(ST_Difference(named_places.boundary, forests.boundary))
 FROM named_places, forests
 WHERE named_places.name = 'Ashton' AND forests.name = 'Green Forest';
@@ -1184,7 +1189,7 @@
--- Conformance Item T49
+-- Conformance Item T49
 -- Union(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine the union of Blue Lake and Goose Island
@@ -1199,9 +1204,6 @@
 -- will match the official answer.
 -- Test script uses 'Ashton' as the place name where it means
 -- to use 'Goose Island'.
--- Specification uses 'Union()' as a function name, but UNION
--- is a SQL reserved work.  Function name adapted to 'GeomUnion()'
--- for out implementation.
@@ -1213,7 +1215,7 @@
-SELECT AsText(GeomUnion(shore, boundary))
+SELECT ST_AsText(ST_Union(shore, boundary))
 FROM lakes, named_places
 WHERE lakes.name = 'Blue Lake' AND named_places.name = 'Goose Island';
@@ -1222,7 +1224,7 @@
--- Conformance Item T50
+-- Conformance Item T50
 -- SymmetricDifference(g1 Geometry, g2 Geometry) : Integer
 -- For this test we will determine the symmetric difference of Blue Lake
 -- and Goose Island
@@ -1249,7 +1251,7 @@
-SELECT AsText(SymmetricDifference(shore, boundary))
+SELECT ST_AsText(ST_SymmetricDifference(shore, boundary))
@@ -1258,7 +1260,7 @@
--- Conformance Item T51
+-- Conformance Item T51
 -- Buffer(g Geometry, d Double Precision) : Geometry
 -- For this test we will make a 15 meter buffer about Cam Bridge.
 -- NOTE: This test we count the number of buildings contained in
@@ -1293,7 +1295,7 @@
 SELECT count(*)
 FROM buildings, bridges
-WHERE Contains(Buffer(bridges.position, 15.0), buildings.footprint);
+WHERE ST_Contains(ST_Buffer(bridges.position, 15.0), buildings.footprint);
@@ -1300,7 +1302,7 @@
--- Conformance Item T52
+-- Conformance Item T52
 -- ConvexHull(g Geometry) : Geometry
 -- For this test we will determine the convex hull of Blue Lake
@@ -1326,7 +1328,7 @@
-SELECT AsText(ConvexHull(shore))
+SELECT ST_AsText(ST_ConvexHull(shore))
 FROM lakes
 WHERE lakes.name = 'Blue Lake';
@@ -1334,7 +1336,6 @@
Modified: branches/2.4/extras/ogc_test_suite/Makefile
--- branches/2.4/extras/ogc_test_suite/Makefile	2019-02-15 18:53:11 UTC (rev 17253)
+++ branches/2.4/extras/ogc_test_suite/Makefile	2019-02-15 18:53:36 UTC (rev 17254)
@@ -1,8 +1,8 @@
 TESTDB=ogc_test_suite
 all:
+	dropdb --if-exists $(TESTDB) > /dev/null
 	createdb $(TESTDB) > /dev/null
-	createlang plpgsql $(TESTDB)
-	psql $(TESTDB) < ../../postgis.sql >/dev/null 2>&1
+	psql $(TESTDB) < ../../postgis/postgis.sql >/dev/null 2>&1
 	psql -a -f 1_schema.sql $(TESTDB) > 1_output.txt 2>&1
 	psql -a -f 2_queries.sql $(TESTDB) > 2_output.txt 2>&1
 	@echo "---------------------------------------"
