[postgis-tickets] [PostGIS] #4278: ST_3DIntersects / ST_3DDistance solid aware in LWGEOM
PostGIS trac at osgeo.org
Fri Feb 15 17:05:41 PST 2019
  Reporter:  komzpa   |      Owner:  komzpa
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  2.4.x
Resolution:  fixed    |   Keywords:
Changes (by komzpa):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17260" 17260]:
 #!CommitTicketReference repository="" revision="17260"
 Make lwgeom_mindist3d solid aware. Add TIN support.
 Thanks Hugo Mercier for suggesting test cases.
 Closes #4278
 Closes https://github.com/postgis/postgis/pull/373
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4278#comment:6>
