[postgis-tickets] r17262 - Put in rounding to fix regression as result of changes in PostgreSQL 12
Regina Obe lr at pcorp.us
Tue Feb 19 05:17:20 PST 2019
Author: robe
Date: 2019-02-19 17:17:20 -0800 (Tue, 19 Feb 2019)
New Revision: 17262
   trunk/regress/core/frechet.sql
   trunk/regress/core/frechet_expected
   trunk/regress/core/hausdorff.sql
   trunk/regress/core/hausdorff_expected
   trunk/regress/core/knn_recheck.sql
   trunk/regress/core/knn_recheck_expected
   trunk/regress/core/lwgeom_regress.sql
   trunk/regress/core/lwgeom_regress_expected
   trunk/regress/core/measures.sql
   trunk/regress/core/measures_expected
   trunk/regress/core/regress_lrs.sql
   trunk/regress/core/regress_lrs_expected
References #4329 for PostGIS 3.0
Modified: trunk/regress/core/frechet.sql
--- trunk/regress/core/frechet.sql	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/frechet.sql	2019-02-20 01:17:20 UTC (rev 17262)
@@ -9,7 +9,7 @@
 -- other linestrings
 SELECT 'frechet_ls_ls_2', st_frechetdistance(
 	'LINESTRING (0 0, 2 0)'::geometry,
-	'LINESTRING (0 1, 1 2, 2 1)'::geometry);
+	'LINESTRING (0 1, 1 2, 2 1)'::geometry)::numeric(12,6);
 -- 2.23606797749979
 -- linestring and multipoint
@@ -21,7 +21,7 @@
 -- another linestring and linestring
 SELECT 'frechet_ls_ls_3', st_frechetdistance(
 	'LINESTRING (0 0, 100 0)'::geometry,
-	'LINESTRING (0 0, 50 50, 100 0)'::geometry);
+	'LINESTRING (0 0, 50 50, 100 0)'::geometry)::numeric(12,6);
 -- 70.7106781186548
 -- rechet with densification
Modified: trunk/regress/core/frechet_expected
--- trunk/regress/core/frechet_expected	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/frechet_expected	2019-02-20 01:17:20 UTC (rev 17262)
@@ -1,5 +1,5 @@
 frechet_ls_ls|1
-frechet_ls_ls_2|2.23606797749979
+frechet_ls_ls_2|2.236068
 frechet_ls_mp|1
-frechet_ls_ls_3|70.7106781186548
+frechet_ls_ls_3|70.710678
 frechetdensify_ls_ls|50
Modified: trunk/regress/core/hausdorff.sql
--- trunk/regress/core/hausdorff.sql	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/hausdorff.sql	2019-02-20 01:17:20 UTC (rev 17262)
@@ -3,7 +3,7 @@
 -- polygon and polygon
 SELECT 'hausdorff_poly_poly', st_hausdorffdistance(
 	'POLYGON((0 0, 0 2, 1 2, 2 2, 2 0, 0 0))'::geometry,
-	'POLYGON((0.5 0.5, 0.5 2.5, 1.5 2.5, 2.5 2.5, 2.5 0.5, 0.5 0.5))'::geometry);
+	'POLYGON((0.5 0.5, 0.5 2.5, 1.5 2.5, 2.5 2.5, 2.5 0.5, 0.5 0.5))'::geometry)::numeric(12,5);
 -- 0.707106781186548
 -- linestring and linestring
@@ -27,7 +27,7 @@
 SELECT 'hausdorff_ls_ls_3', st_hausdorffdistance(
 	'LINESTRING (130 0, 0 0, 0 150)'::geometry,
-	'LINESTRING (10 10, 10 150, 130 10)'::geometry);
+	'LINESTRING (10 10, 10 150, 130 10)'::geometry)::numeric(12,5);
 -- 14.142135623730951
 -- hausdorf with densification
Modified: trunk/regress/core/hausdorff_expected
--- trunk/regress/core/hausdorff_expected	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/hausdorff_expected	2019-02-20 01:17:20 UTC (rev 17262)
@@ -1,6 +1,6 @@
-hausdorff_poly_poly|0.707106781186548
+hausdorff_poly_poly|0.70711
 hausdorff_ls_ls|1
 hausdorff_ls_ls_2|2
 hausdorff_ls_mp|1
-hausdorff_ls_ls_3|14.142135623731
+hausdorff_ls_ls_3|14.14214
 hausdorffdensify_ls_ls|70
Modified: trunk/regress/core/knn_recheck.sql
--- trunk/regress/core/knn_recheck.sql	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/knn_recheck.sql	2019-02-20 01:17:20 UTC (rev 17262)
@@ -231,7 +231,7 @@
 CREATE INDEX ON TEST_WO USING GIST (GEO);
 analyze test_wo;
 SET enable_seqscan = false;
-SELECT '#3418' As ticket, '0101000020E610000092054CE0D6DDE5BFCDCCCCCCCCAC4A40'::geometry <-> geo, ST_Distance('0101000020E610000092054CE0D6DDE5BFCDCCCCCCCCAC4A40'::geometry, geo)
+SELECT '#3418' As ticket, ('0101000020E610000092054CE0D6DDE5BFCDCCCCCCCCAC4A40'::geometry <-> geo)::numeric(14,7), ST_Distance('0101000020E610000092054CE0D6DDE5BFCDCCCCCCCCAC4A40'::geometry, geo)::numeric(14,7)
 FROM test_wo ORDER BY geo <->
 ('0101000020E610000092054CE0D6DDE5BFCDCCCCCCCCAC4A40'::geometry);
 DROP TABLE test_wo;
Modified: trunk/regress/core/knn_recheck_expected
--- trunk/regress/core/knn_recheck_expected	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/knn_recheck_expected	2019-02-20 01:17:20 UTC (rev 17262)
@@ -103,5 +103,5 @@
 #3nd-3|600001|9749|54.5453|54.5453
 #3nd-3|600001|10041|54.6233|54.6233
 #3573|8
-#3418|0.331823813642119|0.331823813642119
-#3418|0.55|0.55
+#3418|0.3318238|0.3318238
+#3418|0.5500000|0.5500000
Modified: trunk/regress/core/lwgeom_regress.sql
--- trunk/regress/core/lwgeom_regress.sql	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/lwgeom_regress.sql	2019-02-20 01:17:20 UTC (rev 17262)
@@ -153,13 +153,13 @@
 FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('EMPTY') AS geom2;
 --- ST_Angle(points)
-SELECT 'ST_Angle_4_pts', St_Angle(p1,p2,p3,p4)
+SELECT 'ST_Angle_4_pts', St_Angle(p1,p2,p3,p4)::numeric(12,6)
 	FROM ST_GeomFromtext('POINT(0 1)') AS p1, ST_GeomFromtext('POINT(0 0)') AS p2
 	, ST_GeomFromtext('POINT(1 0)') AS p3, ST_GeomFromtext('POINT(2 0)') AS p4;
 	FROM ST_GeomFromtext('POINT(2 0)') AS p1, ST_GeomFromtext('POINT(1 0)') AS p2
 	, ST_GeomFromtext('POINT(1 -1)') AS p3, ST_GeomFromtext('POINT(0 0)') AS p4;
-SELECT 'ST_Angle_3_pts', St_Angle(p1,p2,p3)
+SELECT 'ST_Angle_3_pts', St_Angle(p1,p2,p3)::numeric(12,6)
 SELECT 'ST_Angle_mixed_srid', St_Angle(p1,p2,p3,p4)
@@ -169,7 +169,7 @@
 	FROM ST_GeomFromtext('POINT EMPTY') AS p1, ST_GeomFromtext('POINT(0 0)') AS p2
 	, ST_GeomFromtext('POINT(1 0)',4326) AS p3, ST_GeomFromtext('POINT(2 0)') AS p4;
 --- ST_Angle(lines)
-SELECT 'ST_Angle_2_lines', St_Angle(l1,l2)
+SELECT 'ST_Angle_2_lines', St_Angle(l1,l2)::numeric(12,6)
 	FROM ST_GeomFromtext('LINESTRING(0 1,0 0)') AS l1
 	, ST_GeomFromtext('LINESTRING(1 0, 2 0)') AS l2;
Modified: trunk/regress/core/lwgeom_regress_expected
--- trunk/regress/core/lwgeom_regress_expected	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/lwgeom_regress_expected	2019-02-20 01:17:20 UTC (rev 17262)
@@ -27,12 +27,12 @@
 ERROR:  Operation on mixed SRID geometries
 ERROR:  Argument must be POINT geometries
 ERROR:  parse error - invalid geometry
-ST_Angle_4_pts|4.71238898038469
-ST_Angle_4_pts|0.785398163397448
-ST_Angle_3_pts|1.5707963267949
+ST_Angle_4_pts|4.712389
+ST_Angle_4_pts|0.785398
+ST_Angle_3_pts|1.570796
 ERROR:  Empty geometry
-ST_Angle_2_lines|4.71238898038469
+ST_Angle_2_lines|4.712389
 #3965|25|25
 #3971|t
 #4071|2|3|4
Modified: trunk/regress/core/measures.sql
--- trunk/regress/core/measures.sql	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/measures.sql	2019-02-20 01:17:20 UTC (rev 17262)
@@ -5,9 +5,9 @@
 select '115', ST_3DPerimeter('MULTIPOLYGON( ((0 0 0, 10 0 0, 10 10 0, 0 10 0, 0 0 0)),( (0 0 0, 10 0 0, 10 10 0, 0 10 0, 0 0 0),(5 5 0, 7 5 0, 7 7  0, 5 7 0, 5 5 0) ) ,( (0 0 1, 10 0 1, 10 10 1, 0 10 1, 0 0 1),(5 5 1, 7 5 1, 7 7 1, 5 7 1, 5 5 1),(1 1 1,2 1 1, 2 2 1, 1 2 1, 1 1 1) ) )'::GEOMETRY) as value;
-select '116', ST_length2d('MULTILINESTRING((0 0, 1 1),(0 0, 1 1, 2 2) )'::GEOMETRY) as value;
-select '117', ST_3dlength('MULTILINESTRING((0 0, 1 1),(0 0, 1 1, 2 2) )'::GEOMETRY) as value;
-select '118', ST_3dlength('MULTILINESTRING((0 0 0, 1 1 1),(0 0 0, 1 1 1, 2 2 2) )'::GEOMETRY) as value;
+select '116', ST_length2d('MULTILINESTRING((0 0, 1 1),(0 0, 1 1, 2 2) )'::GEOMETRY)::numeric(12,6) as value;
+select '117', ST_3dlength('MULTILINESTRING((0 0, 1 1),(0 0, 1 1, 2 2) )'::GEOMETRY)::numeric(12,6) as value;
+select '118', ST_3dlength('MULTILINESTRING((0 0 0, 1 1 1),(0 0 0, 1 1 1, 2 2 2) )'::GEOMETRY)::numeric(12,6) as value;
 select '134', ST_Distance('POINT(1 2)', 'POINT(1 2)');
 select '135', ST_Distance('POINT(5 0)', 'POINT(10 12)');
@@ -47,7 +47,7 @@
 select 'st_maxdistance_136', st_maxdistance('POINT(0 0)', ST_translate('POINT(0 0)', 5, 12, 0));
 -- postgis-users/2006-May/012174.html
-select 'st_maxdistance_dist', st_maxdistance(a,b), st_maxdistance(b,a) from (
+select 'st_maxdistance_dist', st_maxdistance(a,b)::numeric(12,6), st_maxdistance(b,a)::numeric(12,6) from (
 	select 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry as a,
 		'POLYGON((11 0, 11 10, 20 10, 20 0, 11 0),
 			(15 5, 15 8, 17 8, 17 5, 15 5))'::geometry as b
@@ -118,7 +118,7 @@
 select 'distancepoly3',
 		ST_Distance(a, b),
-			st_maxdistance(a, b),
+			st_maxdistance(a, b)::numeric(12,6),
 				st_astext(st_shortestline(a,b)),
 					st_astext(st_shortestline(b,a)),
 						st_astext(st_longestline(a,b)),
@@ -129,7 +129,7 @@
 select 'distancepoly4',
 		ST_Distance(a, b),
@@ -140,7 +140,7 @@
 select 'distancepoly5',
 		ST_Distance(a, b),
@@ -151,7 +151,7 @@
 select 'distancepoly6',
 		ST_Distance(a, b),
@@ -163,8 +163,8 @@
 --3D Distance functions
 SELECT '3dDistancetest1',
-	ST_3DDistance(a,b),
-		ST_3DMaxDistance(a,b),
+	ST_3DDistance(a,b)::numeric(12,6),
+		ST_3DMaxDistance(a,b)::numeric(12,6),
 			ST_3DDWithin(a,b,5),
 				ST_3DDFullyWithin(a,b,5),
 					ST_ASEWKT(ST_3DShortestline(a,b)),
@@ -175,7 +175,7 @@
 SELECT '3dDistancetest2',
 	ST_3DDistance(a,b),
@@ -185,8 +185,8 @@
 	) as foo;
 SELECT '3dDistancetest3',
 					ST_ASEWKT(ST_SnapToGrid(ST_3DShortestline(a,b), 1e-14)),
@@ -197,7 +197,7 @@
 SELECT '3dDistancetest4',
 	ST_3DDistance(a,b),
Modified: trunk/regress/core/measures_expected
--- trunk/regress/core/measures_expected	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/measures_expected	2019-02-20 01:17:20 UTC (rev 17262)
@@ -1,9 +1,9 @@
 113|291
 114|140
 115|140
-116|4.24264068711929
-117|4.24264068711929
-118|5.19615242270663
+116|4.242641
+117|4.242641
+118|5.196152
 134|0
 135|13
 136|13
@@ -16,7 +16,7 @@
 st_maxdistance_134|0
 st_maxdistance_135|13
 st_maxdistance_136|13
-st_maxdistance_dist|22.3606797749979|22.3606797749979
+st_maxdistance_dist|22.360680|22.360680
 st_longestline_134|LINESTRING(1 2,1 2)
 st_longestline_135|LINESTRING(5 0,10 12)
 st_longestline_136|LINESTRING(0 0,5 12)
@@ -24,15 +24,15 @@
 distancetest1|1|50|LINESTRING(17 18,17 19)|LINESTRING(17 19,17 18)|LINESTRING(29 39,-1 -1)|LINESTRING(-1 -1,29 39)
 distancetest2|0|50|0.0000000000|0.0000000000|0.0000000000|0.0000000000|LINESTRING(-40 -20,-10 20)|LINESTRING(-10 20,-40 -20)
 distancepoly1|1|50|LINESTRING(17 18,17 19)|LINESTRING(17 19,17 18)|LINESTRING(29 39,-1 -1)|LINESTRING(-1 -1,29 39)
-distancepoly2|0|26.1725046566048|LINESTRING(17 14,17 14)|LINESTRING(17 14,17 14)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
-distancepoly3|0|26.9072480941474|LINESTRING(17 19,17 19)|LINESTRING(17 19,17 19)|LINESTRING(17 19,-1 -1)|LINESTRING(-1 -1,17 19)
-distancepoly4|0|28.3196045170126|LINESTRING(16 19,16 19)|LINESTRING(16 19,16 19)|LINESTRING(18 20,-1 -1)|LINESTRING(-1 -1,18 20)
-distancepoly5|0|26.1725046566048|LINESTRING(17 12,17 12)|LINESTRING(17 12,17 12)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
-distancepoly6|0|32.5269119345812|LINESTRING(2 2,2 2)|LINESTRING(2 2,2 2)|LINESTRING(2 2,25 25)|LINESTRING(25 25,2 2)
-3dDistancetest1|6.40312423743285|6.40312423743285|f|f|LINESTRING(1 1 1,3 2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
-3dDistancetest2|0|1.73205080756888|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1 1 1)|LINESTRING(1 1 1,0 0 0)
-3dDistancetest3|4.09994192757944|6.48074069840786|t|f|LINESTRING(1 1 1,0.61904761904762 -0.19047619047619 4.90476190476191)|POINT(1 1 1)|LINESTRING(1 1 1,5 2 6)
-3dDistancetest4|2|10.0498756211209|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1 3)|LINESTRING(5 7 8,1 1 1)
+distancepoly2|0|26.172505|LINESTRING(17 14,17 14)|LINESTRING(17 14,17 14)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
+distancepoly3|0|26.907248|LINESTRING(17 19,17 19)|LINESTRING(17 19,17 19)|LINESTRING(17 19,-1 -1)|LINESTRING(-1 -1,17 19)
+distancepoly4|0|28.319605|LINESTRING(16 19,16 19)|LINESTRING(16 19,16 19)|LINESTRING(18 20,-1 -1)|LINESTRING(-1 -1,18 20)
+distancepoly5|0|26.172505|LINESTRING(17 12,17 12)|LINESTRING(17 12,17 12)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
+distancepoly6|0|32.526912|LINESTRING(2 2,2 2)|LINESTRING(2 2,2 2)|LINESTRING(2 2,25 25)|LINESTRING(25 25,2 2)
+3dDistancetest1|6.403124|6.403124|f|f|LINESTRING(1 1 1,3 2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
+3dDistancetest2|0|1.732051|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1 1 1)|LINESTRING(1 1 1,0 0 0)
+3dDistancetest3|4.099942|6.480741|t|f|LINESTRING(1 1 1,0.61904761904762 -0.19047619047619 4.90476190476191)|POINT(1 1 1)|LINESTRING(1 1 1,5 2 6)
+3dDistancetest4|2|10.049876|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1 3)|LINESTRING(5 7 8,1 1 1)
 3dDistancetest5|2|10|t|f|LINESTRING(5 0 5,5 2 5)|POINT(5 0 5)|LINESTRING(11 0 5,5 0 13)
 3dDistancetest6|0
 3dDistancetest7|0
Modified: trunk/regress/core/regress_lrs.sql
--- trunk/regress/core/regress_lrs.sql	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/regress_lrs.sql	2019-02-20 01:17:20 UTC (rev 17262)
@@ -35,7 +35,7 @@
 --- line_locate_point
-SELECT 'line_locate_point_1', ST_LineLocatePoint('LINESTRING(709243.393033887 163969.752725768,708943.240904444 163974.593889146,708675.634380651 163981.832927298)', 'POINT(705780 15883)');
+SELECT 'line_locate_point_1', ST_LineLocatePoint('LINESTRING(709243.393033887 163969.752725768,708943.240904444 163974.593889146,708675.634380651 163981.832927298)', 'POINT(705780 15883)')::numeric(12,6);
 --- postgis-users/2006-January/010613.html
 select 'line_locate_point_2', ST_LineLocatePoint(ST_geomfromtext('LINESTRING(-1953743.873 471070.784,-1953735.105 471075.419,-1953720.034 471081.649)', 6269), ST_geomfromtext('POINT(-1953720.034 471081.649)', 6269));
Modified: trunk/regress/core/regress_lrs_expected
--- trunk/regress/core/regress_lrs_expected	2019-02-19 03:46:45 UTC (rev 17261)
+++ trunk/regress/core/regress_lrs_expected	2019-02-20 01:17:20 UTC (rev 17262)
@@ -20,7 +20,7 @@
 #4155.1|MULTILINESTRING Z ((2 2 2,5 5 5))
 #4155.2|TIN Z EMPTY
 #4155.3|MULTIPOLYGON Z EMPTY
-line_locate_point_1|0.528602749909894
+line_locate_point_1|0.528603
 line_locate_point_2|1
 line_locate_point_3|0
 line_locate_point_4|0
