[postgis-tickets] r17265 - Quiet debug build warnings about uint64 into %d
Paul Ramsey pramsey at cleverelephant.ca
Wed Feb 20 03:25:53 PST 2019
Author: pramsey
Date: 2019-02-20 15:25:52 -0800 (Wed, 20 Feb 2019)
New Revision: 17265
   trunk/topology/postgis_topology.c
Modified: trunk/topology/postgis_topology.c
--- trunk/topology/postgis_topology.c	2019-02-20 07:28:14 UTC (rev 17264)
+++ trunk/topology/postgis_topology.c	2019-02-20 23:25:52 UTC (rev 17265)
@@ -952,7 +952,7 @@
   pfree(sqldata.data);
-  POSTGIS_DEBUGF(1, "cb_getEdgeById: edge query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getEdgeById: edge query returned %ld rows", SPI_processed);
   *numelems = SPI_processed;
   if ( ! SPI_processed )
@@ -1015,7 +1015,7 @@
-  POSTGIS_DEBUGF(1, "cb_getEdgeByNode: edge query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getEdgeByNode: edge query returned %ld rows", SPI_processed);
@@ -1096,7 +1096,7 @@
-  POSTGIS_DEBUGF(1, "cb_getEdgeByFace: edge query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getEdgeByFace: edge query returned %ld rows", SPI_processed);
@@ -1152,7 +1152,7 @@
-  POSTGIS_DEBUGF(1, "cb_getFaceById: face query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getFaceById: face query returned %ld rows", SPI_processed);
@@ -1214,7 +1214,7 @@
-  POSTGIS_DEBUGF(1, "cb_getRingEdges: edge query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getRingEdges: edge query returned %ld rows", SPI_processed);
@@ -1289,7 +1289,7 @@
-  POSTGIS_DEBUGF(1, "cb_getNodeById: edge query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getNodeById: edge query returned %ld rows", SPI_processed);
@@ -1351,7 +1351,7 @@
-  POSTGIS_DEBUGF(1, "cb_getNodeByFace: edge query returned %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_getNodeByFace: edge query returned %ld rows", SPI_processed);
@@ -1428,7 +1428,7 @@
   POSTGIS_DEBUGF(1, "cb_getEdgeWithinDistance2D: edge query "
-                 "(limited by %d) returned %d rows",
+                 "(limited by %d) returned %ld rows",
                  elems_requested, SPI_processed);
@@ -1531,7 +1531,7 @@
   POSTGIS_DEBUGF(1, "cb_getNodeWithinDistance2D: node query "
@@ -1666,7 +1666,7 @@
   if ( SPI_processed ) topo->be_data->data_changed = true;
-  POSTGIS_DEBUGF(1, "cb_insertEdges query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_insertEdges query processed %ld rows", SPI_processed);
   if ( SPI_processed != (uint64) numelems )
     cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected %d",
@@ -1726,10 +1726,10 @@
-  POSTGIS_DEBUGF(1, "cb_insertFaces query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_insertFaces query processed %ld rows", SPI_processed);
-    cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected %d",
+    cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected %ld",
             (uint64)SPI_processed, numelems);
     return -1;
@@ -1790,7 +1790,7 @@
-  POSTGIS_DEBUGF(1, "cb_updateEdges: update query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_updateEdges: update query processed %ld rows", SPI_processed);
   return SPI_processed;
@@ -1835,7 +1835,7 @@
-  POSTGIS_DEBUGF(1, "cb_updateNodes: update query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_updateNodes: update query processed %ld rows", SPI_processed);
@@ -1908,7 +1908,7 @@
-  POSTGIS_DEBUGF(1, "cb_updateNodesById: update query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_updateNodesById: update query processed %ld rows", SPI_processed);
@@ -1956,7 +1956,7 @@
-  POSTGIS_DEBUGF(1, "cb_updateFacesById: update query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_updateFacesById: update query processed %ld rows", SPI_processed);
@@ -2049,7 +2049,7 @@
-  POSTGIS_DEBUGF(1, "cb_updateEdgesById: update query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_updateEdgesById: update query processed %ld rows", SPI_processed);
@@ -2082,7 +2082,7 @@
-  POSTGIS_DEBUGF(1, "cb_deleteEdges: delete query processed %d rows", SPI_processed);
+  POSTGIS_DEBUGF(1, "cb_deleteEdges: delete query processed %ld rows", SPI_processed);
@@ -2178,7 +2178,7 @@
   if ( spi_result == SPI_OK_DELETE_RETURNING && SPI_processed )
-    POSTGIS_DEBUGF(1, "cb_updateTopoGeomEdgeSplit: deleted %d faces", SPI_processed);
+    POSTGIS_DEBUGF(1, "cb_updateTopoGeomEdgeSplit: deleted %ld faces", SPI_processed);
@@ -2847,7 +2847,7 @@
-  POSTGIS_DEBUGF(1, "cb_deleteFacesById: delete query processed %d rows",
+  POSTGIS_DEBUGF(1, "cb_deleteFacesById: delete query processed %ld rows",
                  SPI_processed);
@@ -2886,7 +2886,7 @@
-  POSTGIS_DEBUGF(1, "cb_deleteNodesById: delete query processed %d rows",
+  POSTGIS_DEBUGF(1, "cb_deleteNodesById: delete query processed %ld rows",
                  SPI_processed);
@@ -2941,7 +2941,7 @@
   POSTGIS_DEBUGF(1, "cb_getNodeWithinBox2D: edge query "
@@ -3030,7 +3030,7 @@
   POSTGIS_DEBUGF(1, "cb_getEdgeWithinBox2D: edge query "
@@ -3114,7 +3114,7 @@
   POSTGIS_DEBUGF(1, "cb_getFaceWithinBox2D: face query "
