[postgis-tickets] r17271 - Replace VARSIZE(foo)-VARHDRSZ pattern with VARSIZE_ANY_EXHDR(foo)
Paul Ramsey pramsey at cleverelephant.ca
Fri Feb 22 08:51:34 PST 2019
Author: pramsey
Date: 2019-02-22 08:51:34 -0800 (Fri, 22 Feb 2019)
New Revision: 17271
   trunk/extensions/address_standardizer/address_parser.c
   trunk/extensions/address_standardizer/address_standardizer.c
   trunk/postgis/geography_inout.c
   trunk/postgis/gserialized_estimate.c
   trunk/postgis/gserialized_gist_nd.c
   trunk/postgis/lwgeom_export.c
   trunk/postgis/lwgeom_in_geojson.c
   trunk/postgis/lwgeom_in_gml.c
   trunk/postgis/lwgeom_in_kml.c
   trunk/postgis/lwgeom_inout.c
   trunk/postgis/lwgeom_ogc.c
   trunk/postgis/mvt.c
   trunk/raster/rt_pg/rtpg_gdal.c
   trunk/raster/rt_pg/rtpg_inout.c
   trunk/raster/rt_pg/rtpg_wkb.c
macro from standard Pg.
Modified: trunk/extensions/address_standardizer/address_parser.c
--- trunk/extensions/address_standardizer/address_parser.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/extensions/address_standardizer/address_parser.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -22,14 +22,6 @@
 Datum parse_address(PG_FUNCTION_ARGS);
-static char *text2char(text *in)
-    char *out = palloc(VARSIZE(in));
-    memcpy(out, VARDATA(in), VARSIZE(in) - VARHDRSZ);
-    out[VARSIZE(in) - VARHDRSZ] = '\0';
-    return out;
 PG_FUNCTION_INFO_V1(parse_address);
@@ -47,7 +39,7 @@
     DBG("Start standardize_address");
-    str = text2char(PG_GETARG_TEXT_P(0));
+    str = text_to_cstring(PG_GETARG_TEXT_P(0));
     DBG("str='%s'", str);
Modified: trunk/extensions/address_standardizer/address_standardizer.c
--- trunk/extensions/address_standardizer/address_standardizer.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/extensions/address_standardizer/address_standardizer.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -19,14 +19,6 @@
 Datum standardize_address1(PG_FUNCTION_ARGS);
-    return out;
  * The signature for standardize_address follows. The lextab, gaztab and
  * rultab should not change once the reference has been standardized and
@@ -80,11 +72,11 @@
-    lextab = text2char(PG_GETARG_TEXT_P(0));
-    gaztab = text2char(PG_GETARG_TEXT_P(1));
-    rultab = text2char(PG_GETARG_TEXT_P(2));
-    micro  = text2char(PG_GETARG_TEXT_P(3));
-    macro  = text2char(PG_GETARG_TEXT_P(4));
+    lextab = text_to_cstring(PG_GETARG_TEXT_P(0));
+    gaztab = text_to_cstring(PG_GETARG_TEXT_P(1));
+    rultab = text_to_cstring(PG_GETARG_TEXT_P(2));
+    micro  = text_to_cstring(PG_GETARG_TEXT_P(3));
+    macro  = text_to_cstring(PG_GETARG_TEXT_P(4));
     DBG("calling RelationNameGetTupleDesc");
     if (get_call_result_type( fcinfo, NULL, &tuple_desc ) != TYPEFUNC_COMPOSITE ) {
@@ -167,10 +159,10 @@
-    addr   = text2char(PG_GETARG_TEXT_P(3));
+    addr   = text_to_cstring(PG_GETARG_TEXT_P(3));
Modified: trunk/postgis/geography_inout.c
--- trunk/postgis/geography_inout.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/geography_inout.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -260,7 +260,7 @@
 	if (PG_NARGS() >4 && !PG_ARGISNULL(4))
 		prefix_text = PG_GETARG_TEXT_P(4);
-		if ( VARSIZE(prefix_text)-VARHDRSZ == 0 )
+		if ( VARSIZE_ANY_EXHDR(prefix_text) == 0 )
 			prefix = "";
@@ -267,12 +267,12 @@
 		else
 			/* +2 is one for the ':' and one for term null */
-			prefix_buf = palloc(VARSIZE(prefix_text)-VARHDRSZ+2);
-			memcpy(prefix_buf, VARDATA(prefix_text),
-			       VARSIZE(prefix_text)-VARHDRSZ);
+			prefix_buf = palloc(VARSIZE_ANY_EXHDR(prefix_text)+2);
+			memcpy(prefix_buf, VARDATA_ANY(prefix_text),
+			       VARSIZE_ANY_EXHDR(prefix_text));
 			/* add colon and null terminate */
-			prefix_buf[VARSIZE(prefix_text)-VARHDRSZ] = ':';
-			prefix_buf[VARSIZE(prefix_text)-VARHDRSZ+1] = '\0';
+			prefix_buf[VARSIZE_ANY_EXHDR(prefix_text)] = ':';
+			prefix_buf[VARSIZE_ANY_EXHDR(prefix_text)+1] = '\0';
 			prefix = prefix_buf;
@@ -281,15 +281,15 @@
 	if (PG_NARGS() >5 && !PG_ARGISNULL(5))
 		id_text = PG_GETARG_TEXT_P(5);
-		if ( VARSIZE(id_text)-VARHDRSZ == 0 )
+		if ( VARSIZE_ANY_EXHDR(id_text) == 0 )
 			id = "";
 		else
-			id_buf = palloc(VARSIZE(id_text)-VARHDRSZ+1);
-			memcpy(id_buf, VARDATA(id_text), VARSIZE(id_text)-VARHDRSZ);
-			prefix_buf[VARSIZE(id_text)-VARHDRSZ+1] = '\0';
+			id_buf = palloc(VARSIZE_ANY_EXHDR(id_text)+1);
+			memcpy(id_buf, VARDATA(id_text), VARSIZE_ANY_EXHDR(id_text));
+			prefix_buf[VARSIZE_ANY_EXHDR(id_text)+1] = '\0';
 			id = id_buf;
@@ -389,7 +389,7 @@
 	if (PG_NARGS() >3 && !PG_ARGISNULL(3))
 		prefix_text = PG_GETARG_TEXT_P(3);
 			prefix = "";
@@ -396,12 +396,12 @@
 		else
-			prefixbuf = palloc(VARSIZE(prefix_text)-VARHDRSZ+2);
+			prefixbuf = palloc(VARSIZE_ANY_EXHDR(prefix_text)+2);
 			memcpy(prefixbuf, VARDATA(prefix_text),
-			prefixbuf[VARSIZE(prefix_text)-VARHDRSZ] = ':';
-			prefixbuf[VARSIZE(prefix_text)-VARHDRSZ+1] = '\0';
+			prefixbuf[VARSIZE_ANY_EXHDR(prefix_text)] = ':';
+			prefixbuf[VARSIZE_ANY_EXHDR(prefix_text)+1] = '\0';
 			prefix = prefixbuf;
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/gserialized_estimate.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -304,7 +304,7 @@
 	int mode = 2;
 	char *modestr;
-	if (VARSIZE(txt) - VARHDRSZ <= 0)
+	if (VARSIZE_ANY_EXHDR(txt) <= 0)
 		return mode;
 	modestr = (char*)VARDATA(txt);
 	if ( modestr[0] == 'N' )
Modified: trunk/postgis/gserialized_gist_nd.c
--- trunk/postgis/gserialized_gist_nd.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/gserialized_gist_nd.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -141,7 +141,7 @@
 inline bool
 gidx_is_unknown(const GIDX *a)
-	size_t size = VARSIZE(a) - VARHDRSZ;
+	size_t size = VARSIZE_ANY_EXHDR(a);
 	/* "unknown" gidx objects have a too-small size of one float */
 	if (size <= 0.0)
 		return true;
Modified: trunk/postgis/lwgeom_export.c
--- trunk/postgis/lwgeom_export.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/lwgeom_export.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -233,7 +233,7 @@
 		else
-			len = VARSIZE(prefix_text)-VARHDRSZ;
+			len = VARSIZE_ANY_EXHDR(prefix_text);
 			prefix_buf = palloc(len + 2); /* +2 is one for the ':' and one for term null */
 			memcpy(prefix_buf, VARDATA(prefix_text), len);
@@ -252,7 +252,7 @@
 		else
-			len = VARSIZE(gml_id_text)-VARHDRSZ;
+			len = VARSIZE_ANY_EXHDR(gml_id_text);
 			gml_id_buf = palloc(len+1);
 			memcpy(gml_id_buf, VARDATA(gml_id_text), len);
 			gml_id_buf[len] = '\0';
@@ -355,7 +355,7 @@
 			prefix = "";
@@ -362,12 +362,12 @@
 		else
 			prefix = prefixbuf;
@@ -581,7 +581,7 @@
 		defid_text = PG_GETARG_TEXT_P(4);
-		if ( VARSIZE(defid_text)-VARHDRSZ == 0 )
+		if ( VARSIZE_ANY_EXHDR(defid_text) == 0 )
 			defid = "";
@@ -588,12 +588,12 @@
 		else
-			defidbuf = palloc(VARSIZE(defid_text)-VARHDRSZ+2);
+			defidbuf = palloc(VARSIZE_ANY_EXHDR(defid_text)+2);
 			memcpy(defidbuf, VARDATA(defid_text),
-			       VARSIZE(defid_text)-VARHDRSZ);
+			       VARSIZE_ANY_EXHDR(defid_text));
-			defidbuf[VARSIZE(defid_text)-VARHDRSZ] = ':';
-			defidbuf[VARSIZE(defid_text)-VARHDRSZ+1] = '\0';
+			defidbuf[VARSIZE_ANY_EXHDR(defid_text)] = ':';
+			defidbuf[VARSIZE_ANY_EXHDR(defid_text)+1] = '\0';
 			defid = defidbuf;
Modified: trunk/postgis/lwgeom_in_geojson.c
--- trunk/postgis/lwgeom_in_geojson.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/lwgeom_in_geojson.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -51,7 +51,7 @@
 static char*
 text2cstring(const text *textptr)
-	size_t size = VARSIZE(textptr) - VARHDRSZ;
+	size_t size = VARSIZE_ANY_EXHDR(textptr);
 	char *str = lwalloc(size+1);
 	memcpy(str, VARDATA(textptr), size);
 	str[size]='\0';
Modified: trunk/postgis/lwgeom_in_gml.c
--- trunk/postgis/lwgeom_in_gml.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/lwgeom_in_gml.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -108,7 +108,7 @@
 	if (PG_ARGISNULL(0)) PG_RETURN_NULL();
 	xml_input = PG_GETARG_TEXT_P(0);
 	xml = text_to_cstring(xml_input);
-	xml_size = VARSIZE(xml_input) - VARHDRSZ;
+	xml_size = VARSIZE_ANY_EXHDR(xml_input);
 	/* Zero for undefined */
 	root_srid = PG_GETARG_INT32(1);
Modified: trunk/postgis/lwgeom_in_kml.c
--- trunk/postgis/lwgeom_in_kml.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/lwgeom_in_kml.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -86,7 +86,7 @@
 	/* Begin to Parse XML doc */
 	xmlInitParser();
Modified: trunk/postgis/lwgeom_inout.c
--- trunk/postgis/lwgeom_inout.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/lwgeom_inout.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -374,7 +374,7 @@
 	LWGEOM *lwgeom;
 	uint8_t *wkb = (uint8_t*)VARDATA(bytea_wkb);
-	lwgeom = lwgeom_from_wkb(wkb, VARSIZE(bytea_wkb)-VARHDRSZ, LW_PARSER_CHECK_ALL);
+	lwgeom = lwgeom_from_wkb(wkb, VARSIZE_ANY_EXHDR(bytea_wkb), LW_PARSER_CHECK_ALL);
 	if (  ( PG_NARGS()>1) && ( ! PG_ARGISNULL(1) ))
@@ -403,7 +403,7 @@
 	LWGEOM *lwgeom;
 	uint8_t *twkb = (uint8_t*)VARDATA(bytea_twkb);
-	lwgeom = lwgeom_from_twkb(twkb, VARSIZE(bytea_twkb)-VARHDRSZ, LW_PARSER_CHECK_ALL);
+	lwgeom = lwgeom_from_twkb(twkb, VARSIZE_ANY_EXHDR(bytea_twkb), LW_PARSER_CHECK_ALL);
 	if ( lwgeom_needs_bbox(lwgeom) )
 		lwgeom_add_bbox(lwgeom);
@@ -443,7 +443,7 @@
 			variant = variant | WKB_NDR;
-	wkb_size= VARSIZE(geom) - VARHDRSZ;
+	wkb_size= VARSIZE_ANY_EXHDR(geom);
 	/* Create WKB hex string */
 	lwgeom = lwgeom_from_gserialized(geom);
Modified: trunk/postgis/lwgeom_ogc.c
--- trunk/postgis/lwgeom_ogc.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/lwgeom_ogc.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -830,7 +830,7 @@
 	LWGEOM *lwgeom;
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/postgis/mvt.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -1183,7 +1183,7 @@
 		NULL
-	size_t len = VARSIZE(ba) - VARHDRSZ;
+	size_t len = VARSIZE_ANY_EXHDR(ba);
 	VectorTile__Tile *tile = vector_tile__tile__unpack(&allocator, len, (uint8_t*)VARDATA(ba));
 	mvt_agg_context *ctx = palloc(sizeof(mvt_agg_context));
 	memset(ctx, 0, sizeof(mvt_agg_context));
Modified: trunk/raster/rt_pg/rtpg_gdal.c
--- trunk/raster/rt_pg/rtpg_gdal.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/raster/rt_pg/rtpg_gdal.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -77,7 +77,7 @@
 	/* get data */
 	bytea_data = (bytea *) PG_GETARG_BYTEA_P(0);
 	data = (uint8_t *) VARDATA(bytea_data);
-	data_len = VARSIZE(bytea_data) - VARHDRSZ;
+	data_len = VARSIZE_ANY_EXHDR(bytea_data);
 	/* process srid */
 	/* NULL srid means try to determine SRID from bytea */
@@ -321,7 +321,7 @@
 		PG_RETURN_NULL();
 	SET_VARSIZE(result, result_size);
-	memcpy(VARDATA(result), gdal, VARSIZE(result) - VARHDRSZ);
+	memcpy(VARDATA(result), gdal, VARSIZE_ANY_EXHDR(result));
 	/* free gdal mem buffer */
 	CPLFree(gdal);
Modified: trunk/raster/rt_pg/rtpg_inout.c
--- trunk/raster/rt_pg/rtpg_inout.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/raster/rt_pg/rtpg_inout.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -142,7 +142,7 @@
 	result_size = wkb_size + VARHDRSZ;
 	result = (bytea *)palloc(result_size);
-	memcpy(VARDATA(result), wkb, VARSIZE(result) - VARHDRSZ);
+	memcpy(VARDATA(result), wkb, VARSIZE_ANY_EXHDR(result));
 	/* Free raster objects used */
 	rt_raster_destroy(raster);
Modified: trunk/raster/rt_pg/rtpg_wkb.c
--- trunk/raster/rt_pg/rtpg_wkb.c	2019-02-21 20:44:29 UTC (rev 17270)
+++ trunk/raster/rt_pg/rtpg_wkb.c	2019-02-22 16:51:34 UTC (rev 17271)
@@ -81,7 +81,7 @@
 	result = (char *)palloc(result_size);
@@ -153,7 +153,7 @@
 	raster = rt_raster_from_wkb(data, data_len);
 	PG_FREE_IF_COPY(bytea_data, 0);
