[postgis-tickets] [PostGIS] #4335: ST_VoronoiPolygons chocking on some multipoint inputs (Self-intersection)
PostGIS trac at osgeo.org
Wed Feb 27 07:45:55 PST 2019
 Reporter:  tilt       |      Owner:  strk
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.5.2
Component:  liblwgeom  |    Version:  2.5.x
 Keywords:             |
 On some multipoint configurations ''ST_VoronoiPolygons'' will complain
 about:
 ERROR:  GEOSVoronoiDiagram: TopologyException: Input geom 1 is invalid:
 Self-intersection at or near point 193600.95500000002 469345.18624999997
 at 193600.95500000002 469345.18624999997
 Observations:
 - the multipoint is valid
 - oddly this does not happen when calling ''ST_VoronoiLines''
 - Adding various tolerance values doesn't help.
 - liblwgeom appears to construct a linestring from the points before
 feeding the geom to GEOS which may cause invalidity:
 [https://github.com/postgis/postgis/blob/c72f563bd273e3d00ee5f6ab26a85354eb6988ca/liblwgeom/lwgeom_geos.c#L1840]
 - related issue at [https://gis.stackexchange.com/questions/287053
 /postgis-st-voronoipolygons-gives-topologyexception-input-geom-1-is-
 invalid-se]
 Reproduce with:
 SELECT ST_VoronoiPolygons(ST_GeomFromWKB(
 E'\\001\\354\\003\\000\\000\\027\\000\\000\\000\\001\\351\\003\\000\\000\\354Q\\270\\036\\021\\242\\007A\\354Q\\270\\036\\205\\245\\034A\\\\\\217\\302\\365(\\3345@\\001\\351\\003\\000\\000\\037\\205\\353Q\\024\\242\\007A\\\\\\217\\302\\365\\205\\245\\034A{\\024\\256G\\341\\2725@\\001\\351\\003\\000\\000\\205\\353Q\\270\\030\\242\\007A\\250\\306K7\\206\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\000\\000\\000\\000\\033\\242\\007A\\376\\324x\\351\\204\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\205\\353Q\\270\\030\\242\\007A\\376\\324x\\351\\204\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\012\\327\\243p\\026\\242\\007A\\376\\324x\\351\\204\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\000\\000\\000\\000\\033\\242\\007AT\\343\\245\\233\\203\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\205\\353Q\\270\\030\\242\\007AT\\343\\245\\233\\203\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\012\\327\\243p\\026\\242\\007AT\\343\\245\\233\\203\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\000\\000\\000\\000\\033\\242\\007A\\252\\361\\322M\\202\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\205\\353Q\\270\\030\\242\\007A\\252\\361\\322M\\202\\245\\034A>\\012\\327\\243p\\2355@\\001\\351\\003\\000\\000\\366(\\\\\\217\\022\\242\\007A\\354Q\\270\\036\\210\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000""""\\020\\242\\007AR\\270\\036\\305\\206\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000O\\033\\350\\264\\015\\242\\007AR\\270\\036\\305\\206\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000{\\024\\256G\\013\\242\\007AR\\270\\036\\305\\206\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000""""\\020\\242\\007A\\270\\036\\205k\\205\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000O\\033\\350\\264\\015\\242\\007A\\270\\036\\205k\\205\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000{\\024\\256G\\013\\242\\007A\\270\\036\\205k\\205\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000\\247\\015t\\332\\010\\242\\007A\\270\\036\\205k\\205\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000\\324\\006:m\\006\\242\\007A\\270\\036\\205k\\205\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000{\\024\\256G\\013\\242\\007A\\037\\205\\353\\021\\204\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000\\247\\015t\\332\\010\\242\\007A\\037\\205\\353\\021\\204\\245\\034AA`\\345\\320"\\3335@\\001\\351\\003\\000\\000\\324\\006:m\\006\\242\\007A\\037\\205\\353\\021\\204\\245\\034AA`\\345\\320"\\3335@'
 Version:
 POSTGIS="2.5.0 r16836" [EXTENSION] PGSQL="100" GEOS="3.7.0-CAPI-1.11.0
 673b9939" SFCGAL="1.3.5" PROJ="Rel. 5.2.0, September 15th, 2018"
 GDAL="GDAL 2.4.0dev-4b763dd896-dirty, released 2018/11/19" LIBXML="2.9.4"
 LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4335>
