[postgis-tickets] r17528 - Throw on invalid characters when decoding geohash
Raul raul at rmr.ninja
Thu Jun 13 04:56:03 PDT 2019
Author: algunenano
Date: 2019-06-13 04:56:02 -0700 (Thu, 13 Jun 2019)
New Revision: 17528
   branches/2.5/NEWS
   branches/2.5/liblwgeom/cunit/cu_algorithm.c
   branches/2.5/liblwgeom/lwalgorithm.c
References #4406
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2019-06-13 11:55:19 UTC (rev 17527)
+++ branches/2.5/NEWS	2019-06-13 11:56:02 UTC (rev 17528)
@@ -9,6 +9,7 @@
   - #4380, Simple TIN support to allow viz in QGIS (Paul Ramsey)
   - #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
   - #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
+  - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
 PostGIS 2.5.2
Modified: branches/2.5/liblwgeom/cunit/cu_algorithm.c
--- branches/2.5/liblwgeom/cunit/cu_algorithm.c	2019-06-13 11:55:19 UTC (rev 17527)
+++ branches/2.5/liblwgeom/cunit/cu_algorithm.c	2019-06-13 11:56:02 UTC (rev 17528)
@@ -1038,6 +1038,23 @@
 	lwfree(ewkt);
+static void
+test_geohash_bbox(void)
+	double lat[2], lon[2];
+	/* SELECT ST_GeoHash(ST_SetSRID(ST_MakePoint(-126,48),4326)) */
+	decode_geohash_bbox("c0w3hf1s70w3hf1s70w3", lat, lon, 100);
+	CU_ASSERT_DOUBLE_EQUAL(lat[0], 48, 1e-11);
+	CU_ASSERT_DOUBLE_EQUAL(lat[1], 48, 1e-11);
+	CU_ASSERT_DOUBLE_EQUAL(lon[0], -126, 1e-11);
+	CU_ASSERT_DOUBLE_EQUAL(lon[1], -126, 1e-11);
+	cu_error_msg_reset();
+	decode_geohash_bbox("@@@@@@", lat, lon, 100);
+	ASSERT_STRING_EQUAL(cu_error_msg, "decode_geohash_bbox: Invalid character '@'");
 static void test_lwgeom_simplify(void)
 	LWGEOM *l;
@@ -1503,6 +1520,7 @@
 	PG_ADD_TEST(suite,test_geohash_precision);
 	PG_ADD_TEST(suite,test_geohash);
 	PG_ADD_TEST(suite,test_geohash_point_as_int);
+	PG_ADD_TEST(suite, test_geohash_bbox);
 	PG_ADD_TEST(suite,test_isclosed);
 	PG_ADD_TEST(suite,test_lwgeom_simplify);
 	PG_ADD_TEST(suite,test_lw_arc_center);
Modified: branches/2.5/liblwgeom/lwalgorithm.c
--- branches/2.5/liblwgeom/lwalgorithm.c	2019-06-13 11:55:19 UTC (rev 17527)
+++ branches/2.5/liblwgeom/lwalgorithm.c	2019-06-13 11:56:02 UTC (rev 17528)
@@ -709,6 +709,7 @@
 ** set in them will be the southwest and northeast coordinates of the bounding
 ** box accordingly. A precision less than 0 indicates that the entire length
 ** of the GeoHash should be used.
+** It will call `lwerror` if an invalid character is found
 void decode_geohash_bbox(char *geohash, double *lat, double *lon, int precision)
@@ -731,6 +732,13 @@
 	for (i = 0; i < precision; i++)
 		c = tolower(geohash[i]);
+		/* Valid characters are all digits and letters except a, i, l and o */
+		if (!(((c >= '0') && (c <= '9')) ||
+		      ((c >= 'b') && (c <= 'z') && (c != 'i') && (c != 'l') && (c != 'o'))))
+			lwerror("%s: Invalid character '%c'", __func__, geohash[i]);
+			return;
 		cd = strchr(base32, c) - base32;
 		for (j = 0; j < 5; j++)
