[postgis-tickets] r17431 - Improve doc Reference Constructors
Martin Davis mtnclimb at gmail.com
Fri May 3 03:05:27 PDT 2019
Author: mdavis
Date: 2019-05-03 15:05:26 -0700 (Fri, 03 May 2019)
New Revision: 17431
   trunk/doc/reference_constructor.xml
Modified: trunk/doc/reference_constructor.xml
--- trunk/doc/reference_constructor.xml	2019-05-02 17:34:38 UTC (rev 17430)
+++ trunk/doc/reference_constructor.xml	2019-05-03 22:05:26 UTC (rev 17431)
@@ -5,7 +5,7 @@
 	<refentry id="ST_Collect">
 	  <refnamediv>
 		<refname>ST_Collect</refname>
-		<refpurpose>Creates a GeometryCollection or Multi* value from a set of other geometries.</refpurpose>
+		<refpurpose>Creates a GeometryCollection or Multi* geometry from a set of geometries.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -28,40 +28,27 @@
 	  <refsection>
 		<title>Description</title>
-		<para> Collects geometries into an appropriate geometry collection type.
-			The output geometry is either a MULTI* or a
-			GEOMETRYCOLLECTION, depending on whether the input geometries have the same or different types
+		<para> Collects geometries into a geometry collection.
+			The result is either a Multi* or a
+			GeometryCollection, depending on whether the input geometries have the same or different types
 			(homogeneous or heterogeneous).
 			The input geometries are left unchanged within the collection.
 			</para>
-		<para>
-			Comes in 3 variants.
-			Variant 1 collects 2 geometries.
-			Variant 2 takes an array of geometries.
-			Variant 3 is an aggregate function that takes a set of geometries.
-			</para>
-		<para>Two-argument and array variants: Returns a geometry which is a collection of the
-			input geometries. </para>
+		<para><emphasis role="bold">Variant 1:</emphasis> accepts two input geometries</para>
+		<para><emphasis role="bold">Variant 2:</emphasis> accepts an array of geometries</para>
+		<para><emphasis role="bold">Variant 3:</emphasis> aggregate function accepting a rowset of geometries.</para>
-		<para>Aggregate variant: Returns a GEOMETRYCOLLECTION or a MULTI geometry
-			from a set of geometries. The function is an "aggregate"
-			function in the terminology of PostgreSQL. That means that it
-			operates on rows of data, in the same way the SUM() and AVG()
-			functions do. For example, "SELECT ST_Collect(GEOM) FROM GEOMTABLE
-			GROUP BY ATTRCOLUMN" returns a separate collection geometry for
-			each distinct value of ATTRCOLUMN.</para>
 		<note><para>
-			If any of the input geometries are collections (MULTI* or GEOMETRYCOLLECTION)
-			ST_Collect will return a GEOMETRYCOLLECTION (since that is the only type
-			which can contain nested collections).
-			To prevent this, use <xref linkend="ST_Dump" /> to expand the
-			input collections to their elements, and then collect the atomic geometries (see example below).
-			</para></note>
+		If any of the input geometries are collections (Multi* or GeometryCollection)
+		ST_Collect returns a GeometryCollection (since that is the only type
+		which can contain nested collections).
+		To prevent this, use <xref linkend="ST_Dump" /> in a subquery to expand the
+		input collections to their atomic elements (see example below).
+		</para></note>
-		<note><para>ST_Collect and ST_Union are superficially similar, but in fact operate very differently.
-		ST_Collect simply aggregates geometries into a collection without changing them in any way.
+		<note><para>ST_Collect and <xref linkend="ST_Union" /> appear similar, but in fact operate quite differently.
+		ST_Collect aggregates geometries into a collection without changing them in any way.
 		ST_Union geometrically merges geometries where they overlap,
 		and splits linestrings at intersections.
 		It may return single geometries when it dissolves boundaries.
@@ -68,62 +55,70 @@
 		</para></note>
 		<para>Availability: 1.4.0 -  ST_Collect(geomarray) was introduced. ST_Collect was enhanced to handle more geometries faster.</para>
-		  <para>&Z_support;</para>
-		  <para>&curve_support; This method supports Circular Strings
-		    and Curves, but will never return a MULTICURVE or MULTI as one
-		    would expect and PostGIS does not currently support those.</para>
+		<para>&Z_support;</para>
+		<para>&curve_support;</para>
 	  </refsection>
 	  <refsection>
-		<title>Examples</title>
-		<para>Aggregate example</para>
-			<programlisting>SELECT stusps, ST_Collect(f.the_geom) as singlegeom
-	 FROM (SELECT stusps, (ST_Dump(the_geom)).geom As the_geom
-				FROM
-				somestatetable ) As f
-GROUP BY stusps</programlisting>
-		<para>Non-Aggregate example</para>
-			<programlisting>SELECT ST_AsText(ST_Collect(ST_GeomFromText('POINT(1 2)'),
+		<title>Examples - Two-input variant</title>
+		<para>Collect 2D points.</para>
+<programlisting>
+SELECT ST_AsText( ST_Collect( ST_GeomFromText('POINT(1 2)'),
 	ST_GeomFromText('POINT(-2 3)') ));
 st_astext
 MULTIPOINT(1 2,-2 3)
+</programlisting>
---Collect 2 d points
-SELECT ST_AsText(ST_Collect(ST_GeomFromText('POINT(1 2)'),
-		ST_GeomFromText('POINT(1 2)') ) );
-st_astext
-MULTIPOINT(1 2,1 2)
---Collect 3d points
-SELECT ST_AsEWKT(ST_Collect(ST_GeomFromEWKT('POINT(1 2 3)'),
+<para>Collect 3D points.</para>
+<programlisting>
+SELECT ST_AsEWKT( ST_Collect( ST_GeomFromEWKT('POINT(1 2 3)'),
 		ST_GeomFromEWKT('POINT(1 2 4)') ) );
 		st_asewkt
  MULTIPOINT(1 2 3,1 2 4)
+ </programlisting>
- --Example with curves
-SELECT ST_AsText(ST_Collect(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)'),
-ST_GeomFromText('CIRCULARSTRING(220227 150406,2220227 150407,220227 150406)')));
-																st_astext
+<para>Collect curves.</para>
+ <programlisting>
+SELECT ST_AsText( ST_Collect( 'CIRCULARSTRING(220268 150415,220227 150505,220227 150406)',
+		'CIRCULARSTRING(220227 150406,2220227 150407,220227 150406)'));
+		st_astext
- GEOMETRYCOLLECTION(CIRCULARSTRING(220268 150415,220227 150505,220227 150406),
+MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406),
  CIRCULARSTRING(220227 150406,2220227 150407,220227 150406))
+</programlisting>
+		</refsection>
+		<refsection>
+<title>Examples - Array variant</title>
+<para>Using an array constructor for a subquery.</para>
+<programlisting>
+SELECT ST_Collect( ARRAY( SELECT the_geom FROM sometable ) );
+</programlisting>
+<para>Using an array constructor for values.</para>
+<programlisting>
+		ARRAY[ ST_GeomFromText('LINESTRING(1 2, 3 4)'),
+			ST_GeomFromText('LINESTRING(3 4, 4 5)') ] )) As wktcollect;
---New ST_Collect array construct
-SELECT ST_Collect(ARRAY(SELECT the_geom FROM sometable));
-SELECT ST_AsText(ST_Collect(ARRAY[ST_GeomFromText('LINESTRING(1 2, 3 4)'),
-			ST_GeomFromText('LINESTRING(3 4, 4 5)')])) As wktcollect;
 --wkt collect --
 MULTILINESTRING((1 2,3 4),(3 4,4 5))
+</programlisting>
+		</refsection>
+		<refsection>
+		<title>Examples - Aggregate variant</title>
+		<para>Creating multiple collections by grouping geometries in a table.</para>
+<programlisting>
+SELECT stusps, ST_Collect(f.the_geom) as geom
+	 FROM (SELECT stusps, (ST_Dump(the_geom)).geom As the_geom
+				FROM
+				somestatetable ) As f
+	GROUP BY stusps
+</programlisting>
-</programlisting>
 	  </refsection>
 	  <refsection>
 		<title>See Also</title>
@@ -151,6 +146,9 @@
 		<para>Creates a LineString from a MultiPoint geometry.</para>
+		<para>Use <xref linkend="ST_MakeLine" /> to create lines from Point or LineString inputs.</para>
 	  </refsection>
@@ -157,13 +155,13 @@
 	  <refsection>
+		<para>Create a 3D line string from a 3D MultiPoint</para>
+		<programlisting>
+SELECT ST_AsEWKT(  ST_LineFromMultiPoint('MULTIPOINT(1 2 3, 4 5 6, 7 8 9)')  ));
-		<programlisting>
---Create a 3d line string from a 3d multipoint
-SELECT ST_AsEWKT(ST_LineFromMultiPoint(ST_GeomFromEWKT('MULTIPOINT(1 2 3, 4 5 6, 7 8 9)')));
 --result--
 LINESTRING(1 2 3,4 5 6,7 8 9)
-		</programlisting>
+</programlisting>
 	  </refsection>
 	  <!-- Optionally add a "See Also" section -->
@@ -170,10 +168,58 @@
 	  <refsection>
-		<para><xref linkend="ST_AsEWKT" />, <xref linkend="ST_Collect" />, <xref linkend="ST_MakeLine" /></para>
+		<para><xref linkend="ST_AsEWKT" />, <xref linkend="ST_MakeLine" /></para>
 	  </refsection>
 	</refentry>
+	<refentry id="ST_MakeEnvelope">
+		<refnamediv>
+		<refname>ST_MakeEnvelope</refname>
+		<refpurpose>Creates a rectangular Polygon from minimum and maximum coordinates.</refpurpose>
+		</refnamediv>
+		<refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_MakeEnvelope</function></funcdef>
+			<paramdef><type>float</type> <parameter>xmin</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>ymin</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>xmax</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>ymax</parameter></paramdef>
+			<paramdef choice="opt"><type>integer</type> <parameter>srid=unknown</parameter></paramdef>
+		  </funcprototype>
+		 </funcsynopsis>
+		</refsynopsisdiv>
+		<refsection>
+			<title>Description</title>
+			<para>Creates a rectangular Polygon from the minimum and maximum values for X and Y.
+			Input values must be in the spatial reference system specified by the SRID.
+			If no SRID is specified the unknown spatial reference system (SRID 0) is used.</para>
+			<para>Availability: 1.5</para>
+			<para>Enhanced: 2.0: Ability to specify an envelope without specifying an SRID was introduced.</para>
+		</refsection>
+		<refsection>
+		<title>Example: Building a bounding box polygon</title>
+		 <programlisting>
+SELECT ST_AsText( ST_MakeEnvelope(10, 10, 11, 11, 4326) );
+st_asewkt
+POLYGON((10 10, 10 11, 11 11, 11 10, 10 10))
+</programlisting>
+		</refsection>
+		<refsection>
+			<title>See Also</title>
+			<para><xref linkend="ST_MakePoint" />, <xref linkend="ST_MakeLine" />, <xref linkend="ST_MakePolygon" /></para>
+		</refsection>
+	</refentry>
 	<refentry id="ST_MakeLine">
 		<refnamediv>
 		<refname>ST_MakeLine</refname>
@@ -185,18 +231,18 @@
 		<funcsynopsis>
 			<funcprototype>
 				<funcdef>geometry <function>ST_MakeLine</function></funcdef>
-				<paramdef><type>geometry set</type> <parameter>geoms</parameter></paramdef>
+				<paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
+				<paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
-				<paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
-				<paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef>
+				<paramdef><type>geometry[]</type> <parameter>geoms_array</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
-				<paramdef><type>geometry[]</type> <parameter>geoms_array</parameter></paramdef>
+				<paramdef><type>geometry set</type> <parameter>geoms</parameter></paramdef>
 			</funcprototype>
 		</funcsynopsis>
 		</refsynopsisdiv>
@@ -204,16 +250,19 @@
 		<refsection>
-		<para>ST_MakeLine comes in 3 forms: a spatial aggregate that takes
-			rows of point, multipoint, or line geometries and returns a line string, a
-			function that takes an array of point, multipoint, or line, and a regular
-			function that takes two point, multipoint, or line geometries. You
-			might want to use a subselect to order points before feeding them
-			to  the aggregate version of this function.</para>
+		<para>Creates a LineString containing the points of Point, MultiPoint, or LineString geometries.
+		Other geometry types cause an error.
+		</para>
+		To ensure the order of the input geometries use <varname>ORDER BY</varname> in the function call,
+		or a subquery with an <varname>ORDER BY</varname> clause.</para>
-		<para>Inputs other than point, multipoint, or lines are ignored.</para>
 		<para>
-			When adding line components common nodes at the beginning of lines are removed from the output. Common nodes in point and multipoint inputs are not removed.
+		Repeated nodes at the beginning of input LineStrings are collapsed to a single point.
+		Repeated points in Point and MultiPoint inputs are not collapsed.
+		<xref linkend="ST_RemoveRepeatedPoints" /> can be used to collapse repeated points from the output LineString.
 		</para>
@@ -225,248 +274,83 @@
 		</refsection>
 		<refsection>
-		<title>Examples: Spatial Aggregate version</title>
-		<para>This example takes a sequence of GPS points and creates one record for each
-			gps travel where the geometry field is a line string composed of the gps points
-			in the order of the travel.</para>
+			<title>Examples: Two-input variant</title>
-		<programlisting>
--- For pre-PostgreSQL 9.0 - this usually works,
--- but the planner may on occasion choose not to respect the order of the subquery
-SELECT gps.gps_track, ST_MakeLine(gps.the_geom) As newgeom
-	FROM (SELECT gps_track, gps_time, the_geom
-			FROM gps_points ORDER BY gps_track, gps_time) As gps
-	GROUP BY gps.gps_track;</programlisting>
+<para>Create a line composed of two points.</para>
+<programlisting>
+SELECT ST_AsText( ST_MakeLine(ST_MakePoint(1,2), ST_MakePoint(3,4)) );
-		<programlisting>
--- If you are using PostgreSQL 9.0+
--- (you can use the new ORDER BY support for aggregates)
--- this is a guaranteed way to get a correctly ordered linestring
--- Your order by part can order by more than one column if needed
-SELECT gps.gps_track, ST_MakeLine(gps.the_geom ORDER BY gps_time) As newgeom
-	FROM gps_points As gps
-		</refsection>
-		<refsection>
-			<title>Examples: Non-Spatial Aggregate version</title>
-			<para>First example is a simple one off line string composed of 2 points.  The second formulates
-				line strings from 2 points a user draws.  The third is a one-off that joins 2 3d points to create a line in 3d space.</para>
-			<programlisting>
-SELECT ST_AsText(ST_MakeLine(ST_MakePoint(1,2), ST_MakePoint(3,4)));
 	  st_astext
  LINESTRING(1 2,3 4)
+</programlisting>
-SELECT userpoints.id, ST_MakeLine(startpoint, endpoint) As drawn_line
-	FROM userpoints ;
+<para>Create a 3D line from two 3D points.</para>
+<programlisting>
+SELECT ST_AsEWKT( ST_MakeLine(ST_MakePoint(1,2,3), ST_MakePoint(3,4,5) ));
-SELECT ST_AsEWKT(ST_MakeLine(ST_MakePoint(1,2,3), ST_MakePoint(3,4,5)));
 		st_asewkt
  LINESTRING(1 2 3,3 4 5)
-			</programlisting>
+</programlisting>
+<para>Create a line from two disjoint LineStrings.</para>
+<programlisting>
+ select ST_AsText( ST_MakeLine( 'LINESTRING(0 0, 1 1)', 'LINESTRING(2 2, 3 3)' ) );
+          st_astext
+ LINESTRING(0 0,1 1,2 2,3 3)
+</programlisting>
 		</refsection>
 		<refsection>
-			<title>Examples: Using Array version</title>
+			<title>Examples: Array variant</title>
-			<programlisting>
-SELECT ST_MakeLine(ARRAY(SELECT ST_Centroid(the_geom) FROM visit_locations ORDER BY visit_time));
+		<para>Create a line from an array formed by a subquery with ordering.</para>
+<programlisting>
+SELECT ST_MakeLine( ARRAY( SELECT ST_Centroid(the_geom) FROM visit_locations ORDER BY visit_time) );
+</programlisting>
---Making a 3d line with 3 3-d points
-SELECT ST_AsEWKT(ST_MakeLine(ARRAY[ST_MakePoint(1,2,3),
-				ST_MakePoint(3,4,5), ST_MakePoint(6,6,6)]));
+		<para>Create a 3D line from an array of 3D points</para>
+<programlisting>
+          ARRAY[ ST_MakePoint(1,2,3), ST_MakePoint(3,4,5), ST_MakePoint(6,6,6) ]  ));
 		st_asewkt
 LINESTRING(1 2 3,3 4 5,6 6 6)
-			</programlisting>
+</programlisting>
 		</refsection>
-	<!-- TODO: add an example using lines -->
 		<refsection>
-			<title>See Also</title>
-			<para><xref linkend="ST_AsEWKT" />, <xref linkend="ST_AsText" />, <xref linkend="ST_GeomFromText" />, <xref linkend="ST_MakePoint" /></para>
-		</refsection>
-	</refentry>
+		<title>Examples: Aggregate variant</title>
+		<para>This example queries time-based sequences of GPS points from a set of tracks
+		and creates one record for each track.
+		The result geometries are LineStrings composed of the GPS track points in the order of travel.</para>
+<para>Using aggregate <varname>ORDER BY</varname> provides a correctly-ordered linestring.</para>
+		<programlisting>
+SELECT gps.track_id, ST_MakeLine(gps.geom ORDER BY gps_time) As geom
+	FROM gps_points As gps
+	GROUP BY track_id;</programlisting>
-	<refentry id="ST_MakeEnvelope">
-		<refnamediv>
-		<refname>ST_MakeEnvelope</refname>
-		<refpurpose>Creates a rectangular Polygon from the given minimum and maximum ordinates.</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_MakeEnvelope</function></funcdef>
-			<paramdef><type>double precision</type> <parameter>xmin</parameter></paramdef>
-			<paramdef><type>double precision</type> <parameter>ymin</parameter></paramdef>
-			<paramdef><type>double precision</type> <parameter>xmax</parameter></paramdef>
-			<paramdef><type>double precision</type> <parameter>ymax</parameter></paramdef>
-			<paramdef choice="opt"><type>integer </type> <parameter>srid=unknown</parameter></paramdef>
-		  </funcprototype>
-		 </funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<title>Description</title>
-			<para>Creates a rectangular Polygon formed from the minima and maxima. by the given shell. Input
-				values must be in SRS specified by the SRID.  If no SRID is specified the unknown spatial reference system is assumed</para>
-			<para>Availability: 1.5</para>
-			<para>Enhanced: 2.0: Ability to specify an envelope without specifying an SRID was introduced.</para>
+<para>Prior to PostgreSQL 9, ordering in a subquery can be used.
+However, sometimes the query plan may not respect the order of the subquery.</para>
+		<programlisting>
+SELECT gps.track_id, ST_MakeLine(gps.geom) As geom
+	FROM ( SELECT track_id, gps_time, geom
+			FROM gps_points ORDER BY track_id, gps_time ) As gps
 		</refsection>
 		<refsection>
-		<title>Example: Building a bounding box polygon</title>
-		 <programlisting>
-SELECT ST_AsText(ST_MakeEnvelope(10, 10, 11, 11, 4326));
-st_asewkt
-POLYGON((10 10, 10 11, 11 11, 11 10, 10 10))
-			  </programlisting>
-		</refsection>
-		<refsection>
-			<para><xref linkend="ST_MakePoint" />, <xref linkend="ST_MakeLine" />, <xref linkend="ST_MakePolygon" /></para>
+			<para><xref linkend="ST_RemoveRepeatedPoints" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_AsText" />, <xref linkend="ST_GeomFromText" />, <xref linkend="ST_MakePoint" /></para>
 		</refsection>
 	</refentry>
-	<refentry id="ST_MakePolygon">
-		<refnamediv>
-		<refname>ST_MakePolygon</refname>
-		<refpurpose>Creates a Polygon from a shell and optional list of holes.</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_MakePolygon</function></funcdef>
-			<paramdef><type>geometry</type> <parameter>linestring</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		<funcsynopsis>
-		  <funcprototype>
-			<paramdef><type>geometry</type> <parameter>outerlinestring</parameter></paramdef>
-			<paramdef><type>geometry[]</type> <parameter>interiorlinestrings</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<para>Creates a Polygon formed by the given shell. Input
-				geometries must be closed LINESTRINGS. Comes in 2 variants.</para>
-			<para>Variant 1:  Takes one closed linestring.</para>
-			<para>Variant 2:  Creates a Polygon formed by the given shell and array of
-			holes. You can construct a geometry array using the PostgreSQL array_agg, ARRAY[] and
-			ARRAY() constructs. Input geometries must be closed LINESTRINGS.</para>
-			<note>
-				<para>This function will not accept a MULTILINESTRING.  Use <xref linkend="ST_LineMerge" /> or <xref linkend="ST_Dump" /> to generate line strings.</para>
-			</note>
-		</refsection>
-		<refsection>
-		<title>Examples: Single closed LINESTRING</title>
-		 <programlisting>
---2d line
-SELECT ST_MakePolygon(ST_GeomFromText('LINESTRING(75.15 29.53,77 29,77.6 29.5, 75.15 29.53)'));
---If linestring is not closed
---you can add the start point to close it
-SELECT ST_MakePolygon(ST_AddPoint(foo.open_line, ST_StartPoint(foo.open_line)))
-FROM (
-SELECT ST_GeomFromText('LINESTRING(75.15 29.53,77 29,77.6 29.5)') As open_line) As foo;
---3d closed line
-SELECT ST_MakePolygon(ST_GeomFromText('LINESTRING(75.15 29.53 1,77 29 1,77.6 29.5 1, 75.15 29.53 1)'));
-st_asewkt
-POLYGON((75.15 29.53 1,77 29 1,77.6 29.5 1,75.15 29.53 1))
---measured line --
-SELECT ST_MakePolygon(ST_GeomFromText('LINESTRINGM(75.15 29.53 1,77 29 1,77.6 29.5 2, 75.15 29.53 2)'));
-st_asewkt
-POLYGONM((75.15 29.53 1,77 29 1,77.6 29.5 2,75.15 29.53 2))
-			  </programlisting>
-		</refsection>
-		<refsection>
-			<title>Examples: Outer shell with inner shells</title>
-			<para>Build a donut with an ant hole</para>
-		   <programlisting>
-		ST_ExteriorRing(ST_Buffer(foo.line,10)),
-	ARRAY[ST_Translate(foo.line,1,1),
-		ST_ExteriorRing(ST_Buffer(ST_MakePoint(20,20),1)) ]
-FROM
-	(SELECT ST_ExteriorRing(ST_Buffer(ST_MakePoint(10,10),10,10))
-		As line )
-		As foo;
-		</programlisting>
-		<para>Build province boundaries with holes
-		representing lakes in the province from a set of
-		province polygons/multipolygons and water linestrings.
-		<note><para>The CASE construct is used because feeding a null array into
-		ST_MakePolygon results in NULL.</para></note>
-		<note><para>A left join is used to guarantee we get all provinces back even if they have no lakes.</para></note></para>
-		<programlisting>
-	SELECT p.gid, p.province_name,
-		CASE WHEN
-			array_agg(w.the_geom) IS NULL THEN p.the_geom
-		ELSE  ST_MakePolygon(ST_LineMerge(ST_Boundary(p.the_geom)), array_agg(w.the_geom)) END
-	FROM
-		provinces p LEFT JOIN waterlines w
-			ON (ST_Within(w.the_geom, p.the_geom) AND ST_IsClosed(w.the_geom))
-	GROUP BY p.gid, p.province_name, p.the_geom;
-	--Same example above but utilizing a correlated subquery
-	--and PostgreSQL built-in ARRAY() function that converts a row set to an array
-	SELECT p.gid,  p.province_name, CASE WHEN
-		EXISTS(SELECT w.the_geom
-			FROM waterlines w
-			WHERE ST_Within(w.the_geom, p.the_geom)
-			AND ST_IsClosed(w.the_geom))
-		THEN
-		ST_MakePolygon(ST_LineMerge(ST_Boundary(p.the_geom)),
-			ARRAY(SELECT w.the_geom
-				FROM waterlines w
-				AND ST_IsClosed(w.the_geom)))
-		ELSE p.the_geom END As the_geom
-	FROM
-		provinces p;
-			  </programlisting>
-		</refsection>
-		<refsection>
-			<para>
-				<xref linkend="ST_Boundary" />,
-				<xref linkend="ST_AddPoint" />,
-				<xref linkend="ST_GeometryType" />,
-				<xref linkend="ST_IsClosed" />,
-				<xref linkend="ST_LineMerge" />,
-				<xref linkend="ST_BuildArea" />
-			</para>
-		</refsection>
-	</refentry>
 	<refentry id="ST_MakePoint">
 		<refnamediv>
 		<refname>ST_MakePoint</refname>
@@ -478,25 +362,25 @@
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_MakePoint</function></funcdef>
-			<paramdef><type>double precision</type> <parameter>x</parameter></paramdef>
-			<paramdef><type>double precision</type> <parameter>y</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>x</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>y</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 		<funcsynopsis>
 		  <funcprototype>
-			<paramdef><type>double precision</type> <parameter>z</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>z</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 		<funcsynopsis>
 		  <funcprototype>
-			<paramdef><type>double precision</type> <parameter>m</parameter></paramdef>
+			<paramdef><type>float</type> <parameter>m</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 		</refsynopsisdiv>
@@ -504,18 +388,19 @@
 		<refsection>
-			<para>Creates a 2D, 3DZ or 4D point geometry (geometry with measure).
-			<varname>ST_MakePoint</varname> while not being OGC compliant is
-			generally faster and more precise than <xref linkend="ST_GeomFromText" />
-			and <xref linkend="ST_PointFromText" />.  It is also easier to use if
-			you have raw coordinates rather than WKT.</para>
+			<para>Creates a 2D, 3D Z or 4D ZM Point geometry.</para>
-			<note><para>For geodetic coordinates, <varname>x</varname> is longitude and <varname>y</varname> is latitude</para></note>
+			<para>Use <xref linkend="ST_MakePointM" /> to make points with XYM coordinates.</para>
-			<note><para>Use <xref linkend="ST_MakePointM" /> if you need to make a point with x, y and m.</para></note>
+			<para>
+			While not OGC-compliant, <varname>ST_MakePoint</varname> is
+			faster and more precise than <xref linkend="ST_GeomFromText" />
+			and <xref linkend="ST_PointFromText" />.
+			It is also easier to use for numeric coordinate values.</para>
+			<note><para>For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</varname> is latitude</para></note>
 		</refsection>
 		<refsection>
@@ -562,39 +447,45 @@
 		<refsection>
-			<para>Creates a point with x, y and measure coordinates. </para>
-			<note><para>Note x is longitude and y is latitude.</para></note>
+			<para>Creates a point with X, Y and M (measure) coordinates. </para>
+			<para>Use <xref linkend="ST_MakePoint" /> to make points with XY, XYZ, or XYZM coordinates.</para>
 		</refsection>
 		<refsection>
-			<para>We use ST_AsEWKT in these examples to show the text representation instead of ST_AsText because ST_AsText does not
-			support returning M.</para>
+			<note><para><xref linkend="ST_AsEWKT" /> is used for text output
+			because <xref linkend="ST_AsText" /> does not support M values.</para></note>
+			<para>Create point with unknown SRID.</para>
 		 <programlisting>
---Return EWKT representation of point with unknown SRID
-SELECT ST_AsEWKT(ST_MakePointM(-71.1043443253471, 42.3150676015829, 10));
+SELECT ST_AsEWKT(  ST_MakePointM(-71.1043443253471, 42.3150676015829, 10)  );
---result
 				   st_asewkt
  POINTM(-71.1043443253471 42.3150676015829 10)
+</programlisting>
---Return EWKT representation of point with measure marked as WGS 84 long lat
-SELECT ST_AsEWKT(ST_SetSRID(ST_MakePointM(-71.1043443253471, 42.3150676015829,10),4326));
+<para>Create point with a measure in the WGS 84 geodetic coordinate system.</para>
+<programlisting>
+SELECT ST_AsEWKT( ST_SetSRID(  ST_MakePointM(-71.104, 42.315, 10),  4326));
 						st_asewkt
-SRID=4326;POINTM(-71.1043443253471 42.3150676015829 10)
+SRID=4326;POINTM(-71.104 42.315 10)
+</programlisting>
---Return a 3d point (e.g. has altitude)
-SELECT ST_MakePoint(1, 2,1.5);
+<para>Get measure of created point.</para>
+<programlisting>
+SELECT ST_M(  ST_MakePointM(-71.104, 42.315, 10)  );
---Get m of point
-SELECT ST_M(ST_MakePointM(-71.1043443253471, 42.3150676015829,10));
 result
 10
-			  </programlisting>
+</programlisting>
 		</refsection>
 		<refsection>
@@ -602,11 +493,148 @@
 		</refsection>
 	</refentry>
+	<refentry id="ST_MakePolygon">
+		<refnamediv>
+		<refname>ST_MakePolygon</refname>
+		<refpurpose>Creates a Polygon from a shell and optional list of holes.</refpurpose>
+		</refnamediv>
+		<refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_MakePolygon</function></funcdef>
+			<paramdef><type>geometry</type> <parameter>linestring</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+		<funcsynopsis>
+		  <funcprototype>
+			<paramdef><type>geometry</type> <parameter>outerlinestring</parameter></paramdef>
+			<paramdef><type>geometry[]</type> <parameter>interiorlinestrings</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+		</refsynopsisdiv>
+		<refsection>
+			<para>Creates a Polygon formed by the given shell and optional array of holes.
+			Input	geometries must be closed LineStrings (rings).</para>
+			<para><emphasis role="bold">Variant 1:</emphasis>  Accepts one shell LineString.</para>
+			<para><emphasis role="bold">Variant 2:</emphasis>  Accepts a shell LineString and an array of
+			inner (hole) LineStrings. A geometry array can be constructed using the PostgreSQL array_agg(), ARRAY[] or
+			ARRAY() constructs.</para>
+			<note><para>This function does not accept MultiLineStrings.
+			Use <xref linkend="ST_LineMerge" /> to generate a LineString, or <xref linkend="ST_Dump" /> to extract LineStrings.</para>
+			</note>
+		</refsection>
+		<refsection>
+		<title>Examples: Single input variant</title>
+		<para>Create a Polygon from a 2D LineString.</para>
+		 <programlisting>
+SELECT ST_MakePolygon( ST_GeomFromText('LINESTRING(75 29,77 29,77 29, 75 29)'));
+</programlisting>
+<para>Create a Polygon from an open LineString,
+using <xref linkend="ST_StartPoint" /> and <xref linkend="ST_AddPoint" /> to close it.</para>
+<programlisting>
+SELECT ST_MakePolygon( ST_AddPoint(foo.open_line, ST_StartPoint(foo.open_line)) )
+FROM (
+  SELECT ST_GeomFromText('LINESTRING(75 29,77 29,77 29, 75 29)') As open_line) As foo;
+</programlisting>
+<para>Create a Polygon from a 3D LineString</para>
+<programlisting>
+SELECT ST_AsEWKT( ST_MakePolygon( 'LINESTRING(75.15 29.53 1,77 29 1,77.6 29.5 1, 75.15 29.53 1)'));
+st_asewkt
+POLYGON((75.15 29.53 1,77 29 1,77.6 29.5 1,75.15 29.53 1))
+</programlisting>
+<para>Create a Polygon from a LineString with measures</para>
+<programlisting>
+SELECT ST_AsEWKT( ST_MakePolygon( 'LINESTRINGM(75.15 29.53 1,77 29 1,77.6 29.5 2, 75.15 29.53 2)' ));
+st_asewkt
+POLYGONM((75.15 29.53 1,77 29 1,77.6 29.5 2,75.15 29.53 2))
+</programlisting>
+		</refsection>
+		<refsection>
+			<title>Examples: Outer shell with inner holes variant</title>
+			<para>Create a donut Polygon with an extra hole</para>
+		   <programlisting>
+SELECT ST_MakePolygon( ST_ExteriorRing( ST_Buffer(ring.line,10)),
+	ARRAY[  ST_Translate(ring.line, 1, 1),
+		ST_ExteriorRing(ST_Buffer(ST_MakePoint(20,20),1)) ]
+FROM (SELECT ST_ExteriorRing(
+	ST_Buffer(ST_MakePoint(10,10),10,10)) AS line ) AS ring;
+</programlisting>
+		<para>Create a set of province boundaries with holes
+		representing lakes.  The input is a table of
+		province Polygons/MultiPolygons and a table of water linestrings.
+		Using a LEFT JOIN ensures all provinces are included even if they have no lakes.
+		</para>
+		<note><para>The CASE construct is used because passing a null array into
+		ST_MakePolygon results in a NULL return value.</para></note>
+		<programlisting>
+	SELECT p.gid, p.province_name,
+		CASE WHEN array_agg(w.the_geom) IS NULL
+		THEN p.the_geom
+		ELSE  ST_MakePolygon( ST_LineMerge(ST_Boundary(p.the_geom)), array_agg(w.the_geom)) END
+	FROM
+		provinces p LEFT JOIN waterlines w
+			ON (ST_Within(w.the_geom, p.the_geom) AND ST_IsClosed(w.the_geom))
+	GROUP BY p.gid, p.province_name, p.the_geom;
+</programlisting>
+	<para>Another technique is to utilize a correlated subquery
+	and the ARRAY() constructor that converts a row set to an array.</para>
+<programlisting>
+		CASE WHEN EXISTS( SELECT w.the_geom
+			FROM waterlines w
+			WHERE ST_Within(w.the_geom, p.the_geom)
+			AND ST_IsClosed(w.the_geom))
+		THEN ST_MakePolygon(
+			ST_LineMerge(ST_Boundary(p.the_geom)),
+			ARRAY( SELECT w.the_geom
+				FROM waterlines w
+				AND ST_IsClosed(w.the_geom)))
+		ELSE p.the_geom
+		END AS the_geom
+	FROM provinces p;
+</programlisting>
+		</refsection>
+		<refsection>
+			<para>
+				<xref linkend="ST_Boundary" />,
+				<xref linkend="ST_AddPoint" />,
+				<xref linkend="ST_IsClosed" />,
+				<xref linkend="ST_LineMerge" />,
+				<xref linkend="ST_StartPoint" />,
+				<xref linkend="ST_BuildArea" />
+			</para>
+		</refsection>
+	</refentry>
 	<refentry id="ST_Point">
 	  <refnamediv>
 		<refname>ST_Point</refname>
-		<refpurpose>Creates a Point with the given coordinate values. OGC alias for ST_MakePoint.</refpurpose>
+		<refpurpose>Creates a Point with the given coordinate values. Alias for ST_MakePoint.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -613,8 +641,8 @@
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Point</function></funcdef>
-			<paramdef><type>float </type> <parameter>x_lon</parameter></paramdef>
-			<paramdef><type>float </type> <parameter>y_lat</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -622,8 +650,9 @@
 	  <refsection>
-		<para>Returns an Point with the given coordinate values. SQL-MM alias for ST_MakePoint that takes just an x and y.</para>
+		<para>Returns an Point with the given X and Y coordinate values. This is the SQL-MM alias for <xref linkend="ST_MakePoint" /> that takes just X and Y.</para>
 		<para>&sqlmm_compliant; SQL-MM 3: 6.1.2</para>
@@ -633,19 +662,24 @@
 	  <refsection>
 		<title>Examples: Geometry</title>
-		<programlisting>SELECT ST_SetSRID(ST_Point(-71.1043443253471, 42.3150676015829),4326)</programlisting>
+		<programlisting>SELECT ST_SetSRID( ST_Point( -71.104, 42.315), 4326)</programlisting>
 	  </refsection>
 	  <refsection>
 		<title>Examples: Geography</title>
-		<programlisting>SELECT CAST(ST_SetSRID(ST_Point(-71.1043443253471, 42.3150676015829),4326) As geography);</programlisting>
-		<programlisting>-- the :: is PostgreSQL short-hand for casting.
-SELECT ST_SetSRID(ST_Point(-71.1043443253471, 42.3150676015829),4326)::geography;</programlisting>
+		<programlisting>SELECT CAST(ST_SetSRID( ST_Point( -71.104, 42.315), 4326) AS geography);</programlisting>
-        <programlisting>--If your point coordinates are in a different spatial reference from WGS-84 long lat, then you need to transform before casting
--- This example we convert a point in Pennsylvania State Plane feet to WGS 84 and then geography
-SELECT ST_Transform(ST_SetSRID(ST_Point(3637510, 3014852),2273),4326)::geography;</programlisting>
+		<para>PostgreSQL also provides the <varname>::</varname> short-hand for casting</para>
+		<programlisting>
+SELECT ST_SetSRID( ST_Point( -71.104, 42.315), 4326)::geography;</programlisting>
+<para>If the point coordinates are not in a geodetic coordinate system (such as WGS84),
+then they must be reprojected before casting to a geography.
+In this example a point in Pennsylvania State Plane feet (SRID 2273)
+is projected to WGS84 (SRID 4326).</para>
+<programlisting>
+SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geography;</programlisting>
 	  </refsection>
@@ -660,7 +694,7 @@
 	  <refnamediv>
 		<refname>ST_Polygon</refname>
-		<refpurpose>Creates a Polygon from a LineString, with a specified SRID.</refpurpose>
+		<refpurpose>Creates a Polygon from a LineString with a specified SRID.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -667,7 +701,7 @@
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Polygon</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>aLineString</parameter></paramdef>
+			<paramdef><type>geometry </type> <parameter>lineString</parameter></paramdef>
 			<paramdef><type>integer </type> <parameter>srid</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
@@ -676,12 +710,17 @@
 	  <refsection>
-		<para>Returns a polygon built from the specified linestring and SRID.</para>
+		<para>Returns a polygon built from the given LineString
+		and sets the spatial reference system from the <varname>srid</varname>.</para>
-		<!-- optionally mention that this function uses indexes if appropriate -->
-		<note>
-		  <para>ST_Polygon is similar to first version of ST_MakePolygon except it also sets the spatial ref sys (SRID) of the polygon. Will not work with MULTILINESTRINGS
-			so use LineMerge to merge multilines.  Also does not create polygons with holes.  Use ST_MakePolygon for that.</para>
+		<para>ST_Polygon is similar to <xref linkend="ST_MakePolygon" /> Variant 1
+		with the addition of setting the SRID.</para>
+		<para>To create polygons with holes
+		use <xref linkend="ST_MakePolygon" /> Variant 2 and then <xref linkend="ST_SetSRID" />.
+		</para>
 		</note>
 		<para>&sfs_compliant;</para>
@@ -690,23 +729,23 @@
 	  </refsection>
 	  <refsection>
+<para>Create a 2D polygon.</para>
 		<programlisting>
---a 2d polygon
-SELECT ST_Polygon(ST_GeomFromText('LINESTRING(75.15 29.53,77 29,77.6 29.5, 75.15 29.53)'), 4326);
+SELECT ST_AsText( ST_Polygon('LINESTRING(75 29, 77 29, 77 29, 75 29)'::geometry, 4326) );
---result--
-POLYGON((75.15 29.53,77 29,77.6 29.5,75.15 29.53))
---a 3d polygon
-SELECT ST_AsEWKT(ST_Polygon(ST_GeomFromEWKT('LINESTRING(75.15 29.53 1,77 29 1,77.6 29.5 1, 75.15 29.53 1)'), 4326));
+-- result --
+POLYGON((75 29, 77 29, 77 29, 75 29))
+</programlisting>
+<para>Create a 3D polygon.</para>
+<programlisting>
+SELECT ST_AsEWKT( ST_Polygon( ST_GeomFromEWKT('LINESTRING(75 29 1, 77 29 2, 77 29 3, 75 29 1)'), 4326) );
-result
-SRID=4326;POLYGON((75.15 29.53 1,77 29 1,77.6 29.5 1,75.15 29.53 1))
-			</programlisting>
+-- result --
+SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
+</programlisting>
 	  </refsection>
