[postgis-tickets] r17437 - Simple TIN support to allow viz in QGIS
Paul Ramsey pramsey at cleverelephant.ca
Tue May 14 02:33:40 PDT 2019
Author: pramsey
Date: 2019-05-14 14:33:40 -0700 (Tue, 14 May 2019)
New Revision: 17437
   branches/2.5/NEWS
   branches/2.5/liblwgeom/lwgeom.c
   branches/2.5/postgis/lwgeom_geos.c
References #4380
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2019-05-14 19:43:46 UTC (rev 17436)
+++ branches/2.5/NEWS	2019-05-14 21:33:40 UTC (rev 17437)
@@ -6,6 +6,7 @@
   - #4348, ST_AsMVTGeom (GEOS): Enforce validation at all times (Raúl Marín)
   - #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
   - #4326, Fix circular arc distance calculation (Paul Ramsey)
+  - #4380, Simple TIN support to allow viz in QGIS (Paul Ramsey)
 PostGIS 2.5.2
Modified: branches/2.5/liblwgeom/lwgeom.c
--- branches/2.5/liblwgeom/lwgeom.c	2019-05-14 19:43:46 UTC (rev 17436)
+++ branches/2.5/liblwgeom/lwgeom.c	2019-05-14 21:33:40 UTC (rev 17437)
@@ -1606,6 +1606,7 @@
 		/* No-op! Cannot remote points */
 		case POINTTYPE:
+		case TRIANGLETYPE:
 			return;
 		case LINETYPE:
@@ -1705,6 +1706,7 @@
 		/* Can process most multi* types as generic collection */
 		case MULTILINETYPE:
 		case MULTIPOLYGONTYPE:
+		case TINTYPE:
 		case COLLECTIONTYPE:
 		/* Curve types we mostly ignore, but allow the linear */
 		/* portions to be processed by recursing into them */
@@ -1749,8 +1751,9 @@
 	switch (geom->type)
-		/* No-op! Cannot simplify points */
+		/* No-op! Cannot simplify points or triangles */
 		case POINTTYPE:
 			return;
 		case LINETYPE:
@@ -1809,6 +1812,7 @@
 		case MULTIPOINTTYPE:
 		case MULTILINETYPE:
+		case TINTYPE:
 			uint32_t i, j = 0;
@@ -2154,6 +2158,7 @@
 			return;
 		case CIRCSTRINGTYPE:
 		case LINETYPE:
 			LWLINE *ln = (LWLINE*)(geom);
@@ -2207,6 +2212,7 @@
 		case MULTILINETYPE:
+		case TINTYPE:
 		case COMPOUNDTYPE:
Modified: branches/2.5/postgis/lwgeom_geos.c
--- branches/2.5/postgis/lwgeom_geos.c	2019-05-14 19:43:46 UTC (rev 17436)
+++ branches/2.5/postgis/lwgeom_geos.c	2019-05-14 21:33:40 UTC (rev 17437)
@@ -754,12 +754,14 @@
 	double	tolerance;
 	GEOSGeometry *g1, *g3;
 	GSERIALIZED *result;
+	uint32_t type;
 	geom1 = PG_GETARG_GSERIALIZED_P(0);
 	tolerance = PG_GETARG_FLOAT8(1);
 	/* Empty.Simplify() == Empty */
-	if ( gserialized_is_empty(geom1) )
+	type = gserialized_get_type(geom1);
+	if ( gserialized_is_empty(geom1) || type == TINTYPE || type == TRIANGLETYPE )
 		PG_RETURN_POINTER(geom1);
 	initGEOS(lwpgnotice, lwgeom_geos_error);
