[postgis-tickets] [PostGIS] #4400: Isolines generating function
PostGIS trac at osgeo.org
Fri May 17 08:57:54 PDT 2019
 Reporter:  komzpa       |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.0.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 A function that takes a TIN and generates isolines.
 ST_Isolines(TIN, z_interval)
 Outputs a set of isolines per different elevation as multilinestrings,
 clipping triangles at given elevations.
 (implementation hint, per discussion with pramsey, if a triangle is
 horizontal we don't need to output a line segment)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4400>
