[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 437a08ef394ffab011acf21fafb360ef9a0a449a
Fri May 24 14:57:58 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  437a08ef394ffab011acf21fafb360ef9a0a449a (commit)
       via  b59b781afa9720e609a6f57519adf61f6bf36373 (commit)
      from  ba699027bd39fe1477ccdfe6099c5c687cca7ed5 (commit)
revisions in full, below.
commit 437a08ef394ffab011acf21fafb360ef9a0a449a
Author: Regina Obe <lr at pcorp.us>
Date:   Fri May 24 17:57:54 2019 -0400
    Add in new DISABLE_GEOS_INLINE, but keep old GEOS_ENABLE_INLINE for < 3.8.  Also mark build type as Release
diff --git a/windows/mingw64/scripts/build_check_geos.sh b/windows/mingw64/scripts/build_check_geos.sh
index eaf85a8..a55f0c4 100644
--- a/windows/mingw64/scripts/build_check_geos.sh
+++ b/windows/mingw64/scripts/build_check_geos.sh
@@ -42,9 +42,9 @@ export PATHOLD="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/c/Wind
     cd build${OS_BUILD}${GEOS_VER}
   if [[ "${OS_BUILD}" == "64" ]] ; then
-    cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO  -DGEOS_ENABLE_TESTS=ON -  ../${GEOS_MINOR_VER}cmake
+    cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 CMAKE_BUILD_TYPE=Release -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON  -DGEOS_ENABLE_TESTS=ON -  ../${GEOS_MINOR_VER}cmake
   else
-     cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO  -DGEOS_ENABLE_TESTS=ON -  ../${GEOS_MINOR_VER}cmake
+     cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO CMAKE_BUILD_TYPE=Release -DGEOS_ENABLE_TESTS=ON -DDISABLE_GEOS_INLINE=ON -  ../${GEOS_MINOR_VER}cmake
   fi
   make && make install
   make check
commit b59b781afa9720e609a6f57519adf61f6bf36373
Date:   Wed Mar 20 17:22:29 2019 -0400
    replace apt-get with just apt and add instructions for installing logbt
diff --git a/debian/jenkins_setup.txt b/debian/jenkins_setup.txt
index d0a3315..5e565a1 100644
--- a/debian/jenkins_setup.txt
+++ b/debian/jenkins_setup.txt
@@ -1,8 +1,8 @@
 Setup Jenkins on Debian
 On 64-bit Debian 6
 su root
-apt-get update
-apt-get upgrade #install latest patches
+apt update
+apt upgrade #install latest patches
 wget -q -O - http://pkg.jenkins-ci.org/debian/jenkins-ci.org.key | apt-key add -
 Add to: /etc/apt/sources.list
@@ -21,74 +21,74 @@ echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu precise main" | t
 #to get newer proj 4.9.1 needed to do this
 echo "deb http://ftp.us.debian.org/debian sid main" | tee -a /etc/apt/sources.list
-apt-get update
-apt-get install libproj9 libproj-dev proj-bin proj-data
-apt-get install g++
+apt update
+apt install libproj9 libproj-dev proj-bin proj-data
+apt install g++
 #for address_standardizer
-apt-get install libpcre3-dev
+apt install libpcre3-dev
-apt-get update
-apt-get install jenkins
+apt update
+apt install jenkins
 ##installing java if the above fails
 apt-key adv --keyserver keyserver.ubuntu.com --recv-keys EEA14886
-apt-get update
-apt-get install oracle-java7-installer
+apt update
+apt install oracle-java7-installer
 ## end installing java
 #for building sfcgal
 echo "deb-src http://debian.mirrors.ovh.net/debian/ sid main contrib non-free" | tee -a /etc/apt/sources.list
-sudo apt-get update
-apt-get build-dep sfcgal-bin
-apt-get -b source sfcgal-bin
-apt-get install libcgal-dev libboost-all-dev libmpfr-dev libgmp-dev libopenscenegraph-dev libopenthreads-dev libpq-dev libqt4-dev libqt4-opengl-dev pkg-kde-tools
+sudo apt update
+apt build-dep sfcgal-bin
+apt -b source sfcgal-bin
+apt install libcgal-dev libboost-all-dev libmpfr-dev libgmp-dev libopenscenegraph-dev libopenthreads-dev libpq-dev libqt4-dev libqt4-opengl-dev pkg-kde-tools
 #for building gdal with odbc support
-apt-get install unixODBC
-apt-get install unixodbc-dev
+apt install unixODBC
+apt install unixodbc-dev
 #make it the default
-sudo apt-get install oracle-java7-set-default
-apt-get install git
+sudo apt install oracle-java7-set-default
+apt install git
 apt install git2cl  #for building geos distributions
 --to get autoconf etc --
-apt-get install autoconf libtool build-essential
+apt install autoconf libtool build-essential
 #CUnit
-apt-get install libreadline6 libreadline6-dev zlib1g-dev
-apt-get install libcunit1-dev libcunit1-doc libcunit1
-apt-get install docbook
-apt-get install libxml2-dev n xsltproc docbook-xsl docbook-mathml gettext
+apt install libreadline6 libreadline6-dev zlib1g-dev
+apt install libcunit1-dev libcunit1-doc libcunit1
+apt install docbook
+apt install libxml2-dev n xsltproc docbook-xsl docbook-mathml gettext
 apt-cache search json #see latest version
-apt-get install libjson-c-dev
-apt-get install dblatex
-apt-get install imagemagick
-apt-get install libxml2 libxml2-dev
-apt-get install bison
-apt-get install libiconv-hook1
-apt-get install subversion
+apt install libjson-c-dev
+apt install dblatex
+apt install imagemagick
+apt install libxml2 libxml2-dev
+apt install bison
+apt install libiconv-hook1
+apt install subversion
 #(for future translation work)
-apt-get install poxml
-apt-get install curl
-apt-get install python-dev
+apt install poxml
+apt install curl
+apt install python-dev
 #wget https://bitbucket.org/pypa/setuptools/raw/bootstrap/ez_setup.py -O - | sudo python
-apt-get install python-pip
+apt install python-pip
 pip install transifex-client
 #for doxygen build and  graph generation
-apt-get install doxygen graphviz
-apt-get install apache2  #(for displaying docbook etc.)
-apt-get install flex (needed for 1.3)
-apt-get install dbtoepub (publish documentation in epub format)
+apt install doxygen graphviz
+apt install apache2  #(for displaying docbook etc.)
+apt install flex (needed for 1.3)
+apt install dbtoepub (publish documentation in epub format)
 #for building sfcgal, pointcloud
-apt-get install cmake
+apt install cmake
 apt install libboost-dev
@@ -96,15 +96,21 @@ apt install libcgal-dev
 apt install libsfcgal-dev
 #for code coverage
-sudo apt-get install lcov
+sudo apt install lcov
+#for logbt testing
+curl -sSfL https://github.com/mapbox/logbt/archive/v2.0.3.tar.gz | tar --gunzip --extract --strip-components=1 --exclude="*md" --exclude="test*" --directory=/usr/local
+which logbt
+/usr/local/bin/logbt
+logbt --version
-apt-get install latex-cjk-xcjk #for Korean and Chinese doc PDF translations
+apt install latex-cjk-xcjk #for Korean and Chinese doc PDF translations
 --if you need to update jenkins
 aptitude update
-apt-get upgrade
+apt upgrade
 apt install jenkins
 apt --only-upgrade install docker-io
Summary of changes:
 debian/jenkins_setup.txt                    | 90 +++++++++++++++--------------
 windows/mingw64/scripts/build_check_geos.sh |  4 +-
 2 files changed, 50 insertions(+), 44 deletions(-)
hooks/post-receive
