[postgis-tickets] [PostGIS] #4408: can't compile --with-wagyu under mingw64
PostGIS trac at osgeo.org
Fri May 31 11:14:29 PDT 2019
  Reporter:  robe     |      Owner:  Algunenano
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by Algunenano):
 * owner:  pramsey => Algunenano
 * version:  2.4.x => trunk
Comment:
 Thanks for testing it.
 I guess that it is failing when linking postgis-3.so, but I'm not certain.
 Can you share the final command that led to this error, please?
 Also, can you include the output of `./configure --with-wagyu`?. Does it
 warn with something like `Could not find a C++ standard library`? I'm
 using a very basic detection system (which was needed for OSX) which might
 require an extra option for mingw.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4408#comment:1>
